if i have a pre-build minimal VPS install of centos-6, is it then possible to install EFA ?
and how do i start ?
thank you,
regards
Angelo
install EFA
Re: install EFA
It is possible I created an prepare script.. but not tested in detail so if things go wrong you will need to have some knowledge your self to fix the issues
https://github.com/E-F-A/v3/blob/master ... ut-ks.bash
Re: install EFA
ok, thx.
if i run in to problem's and i find a fix i'll post them so you can update your script.
Angelo
Angelo
Re: install EFA
Oh note that the script now still points to the development version of efa:
You might want to use the final version, so change the line in the script to:
I just changed it so if you grabbed it earlier it is best to grab the new one or change the line.
/usr/bin/wget -q -O /usr/src/EFA/build.bash -o /var/log/EFA/wget.log https://raw.githubusercontent.com/E-F-A/v3/master/build/build.bash --no-check-certificate
/usr/bin/wget -q -O /usr/src/EFA/build.bash -o /var/log/EFA/wget.log https://raw.githubusercontent.com/E-F-A/v3/3.0.0.6/build/build.bash --no-check-certificate
Re: install EFA
worked like a charm
thx
Here are some minor issues i ran in to :
FYI :
System data :
Kernel Linux 2.6.32-042stab094.7
Virtuozzo version Virtuozzo release 4.6.0
After build script :
ssh root access was disabled, this is a problem because i'm running a VPS. (edited sshd_conf via recovery to allow access)
keyboard layout, not able to change to Belgian. left as US layout, fine by me
During boot up and EFA script run :
Starting dnsmasq:
dnsmasq: setting capabilities failed: Operation not permitted
DNS not working -- no updates on clamav (start script pauzed for about 5min)
after reboot :
dnsmasq won't start in a VPS system (googled it, named is fine by me)
changed to named
chkconfig dnsmasq off
chkconfig named on
keyboard layout seams to be changed to Belgian. The menu was not reflecting the change.
sshd_config : changed back to not permit root login
mail seams to flow now.
thx
FYI :
System data :
Starting dnsmasq:
after reboot :
changed to named
chkconfig named on
Re: install EFA
I built last night with 3.0.0.7 install script, but ran into the problem of /etc/fstab mounting things, I did this in OpenVZ (2.6.32-042stab104.1) which uses simfs, not sure if Virtuozzo is the same, I thought it was, you just have to pay for Parelles horid support.angelo wrote: FYI :
System data :
I am trying to get it in a state I will be happy with as a template so customers can deploy, ssh in as root, do the initial config, then the init script edits root login and restarts sshd
Re: install EFA
is it possible to update EFA without the kernel check because i'm running within a VPS ?
thank you.
Angelo
thank you.
Angelo
Re: install EFA
from 3.0.0.7 to 3.0.0.8 you can try an manual update.
* not I never tested this just from the top of my head
STAGING="/tmp/EFA-Staging"
cd $STAGING
wget http://dl.efa-project.org/update/EFA-Update-3.0.0.7-3.0.0.8.tar.gz
tar xzvf http://dl.efa-project.org/update/EFA-Update-3.0.0.7-3.0.0.8.tar.gz
rm -f /var/EFA/update/EFA-Version-Upgrade
cp $STAGING/EFA-Version-Upgrade /var/EFA/update/EFA-Version-Upgrade
chmod 700 /var/EFA/update/EFA-Version-Upgrade
