Phishing attempts
b19wll
Phishing attempts
Post by b19wll »
Hello
we seem to be getting a lot of phishing attempts let through the filter, is there something I can do to combat this? Also a lot of word docs are coming through as invoices and the .doc has a link in them, how can I stop these?
Will
Re: Phishing attempts
Do you have a Spam Report on one of them you can share?
b19wll
Post by b19wll »
Here ia s a report
cached not
score=3.271
3.6 required
0.00 BAYES_50 Bayesian spam probability is 40 to 60%
1.00 BOTNET Relay might be a spambot or virusbot
2.17 DCC_CHECK Listed in DCC (http://rhyolite.com/anti-spam/dcc/)
0.10 RDNS_NONE Delivered to trusted network by a host with no rDNS
This one has obviously flown under your radar (although barely)...
Here are some options... you can use them all or in combination
1) Keep feeding the Bayesian filter to increase the spam probability
2) If you are not using greylisting, you may want to consider using it
3) If it is from the same sources, just blacklist at domain or ip level system wide (From: somespammer.net To: default)
4) Lower your spam threshold a little more (increases risk of marking legit emails as spam)
5) Override some of the rules listed in your spam report to increase their score in local.cf
6) Install ScamNailer (http://www.scamnailer.info/)
b19wll
Post by b19wll »
Thanks for the pointers
Would it be realistic for scamnailer to be incuded in the EFA build?
Will
