Versions
drewmorris
Versions
Just a quick question... I noticed the announcement about 3.0.0.6 but I noticed on the download page the images are all 3.0.0.5... is there a reason for this? Shouldn't these be updated?
Re: Versions
3.0.0.6 was an emergency update, and I just havn't had the time to create new VM images
drewmorris
Re: Versions
So does using the 3.0.0.5 with the automatic updates turned on achieve the same result?
Re: Versions
Yep, it will automatically update to the latest version.
