Can you help me figure out how to configure the Daily report ?
Please it's very urgent .
Daily report configuration
Re: Daily report configuration
Are your users set to receive a daily report in MailWatch?
Yes ,when I try to generate the report manually tells me there are 0 mail in quanrantina
So, are you able to see anything in your quarantine using MailWatch?
you see the mails in quarantine
Hmm... Are any errors (especially a database connection error) reported when you execute the quarantine report script from the command line?
It would be useful to see what the output is when you run the script. I think it is likely that you don't have the correct filters on the users or that the format of the username is incorrect.vbarbieri wrote:Yes ,when I try to generate the report manually tells me there are 0 mail in quanrantina
