Update to 3.0.0.5 is pending.
Your system has an updated kernel, but you are not running
on the latest kernel. Please restart your system and run
EFA-Update after restart.Code: Select all
EFA-Update -checkCode: Select all
grep -m 1 CentOS /boot/grub/menu.lst | sed 's/.*(//' | sed 's/)//'
and:
uname -a
[EFA] Getting latest version number from http://dl.efa-project.org
[EFA] You are running EFA version EFA-3.0.0.4
[EFA] Latest version update is EFA-3.0.0.5
2.6.32-431.29.2.el6.x86_64.debug
Linux <hostname> 2.6.32-431.29.2.el6.x86_64 #1 SMP Tue Sep 9 21:36:05 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
yum list installed | grep -i kernelCode: Select all
abrt-addon-kerneloops.x86_64
dracut-kernel.noarch
kernel.x86_64 2.6.32-431.5.1.el6 @updates
kernel.x86_64 2.6.32-431.11.2.el6 @updates
kernel.x86_64 2.6.32-431.17.1.el6 @updates
kernel.x86_64 2.6.32-431.20.3.el6 @updates
kernel.x86_64 2.6.32-431.29.2.el6 @updates
kernel-debug.x86_64 2.6.32-431.11.2.el6 @updates
kernel-debug.x86_64 2.6.32-431.17.1.el6 @updates
kernel-debug.x86_64 2.6.32-431.20.3.el6 @updates
kernel-debug.x86_64 2.6.32-431.29.2.el6 @updates
kernel-debuginfo.x86_64
kernel-debuginfo-common-x86_64.x86_64
kernel-devel.x86_64 2.6.32-431.5.1.el6 @updates
kernel-devel.x86_64 2.6.32-431.11.2.el6 @updates
kernel-devel.x86_64 2.6.32-431.17.1.el6 @updates
kernel-devel.x86_64 2.6.32-431.20.3.el6 @updates
kernel-devel.x86_64 2.6.32-431.29.2.el6 @updates
kernel-firmware.noarch
kernel-headers.x86_64
libreport-plugin-kerneloops.x86_64
yum remove kernel-debug.x86_64
