Thats my best guess, in mailwatch I see dmarc fired off 3:27a sent a bunch of reports until about 3:31a. I also checked exchange logs, nothing went out in that hour except an auto responder to a junk mail.
I disabled opendmarc using this snippet i found in another post. Will request removal and keep an eye out. Probably will turn it back on after a week or two if its quite.
sudo systemctl stop opendmarc
sudo systemctl disable opendmarc
sudo mv /etc/cron.daily/eFa-Daily-DMARC ~
sudo mv /etc/cron.weekly/eFa-Weekly-DMARC ~
