Getting SASL to work
mattch
Post by mattch »
I followed this post from 2017, but I think some things change since then. EFA-4.0.4
https://forum.efa-project.org/viewtopi ... 85#p11085
Make sure you've already ran the LetsEncrypt setup (option 15)...
-enable HTTPS, redirect is fine, open port 80.
1) /etc/postfix/main.cf
smtpd_sasl_path = smtpd
smtpd_sasl_auth_enable = yes
2) Create a sasl user in the db.
saslpasswd2 -c -u adomain.com username
# ie username@adomain.com
sasldblistusers2
# to verify the user is in the db.
(you can skip this)
testsaslauthd -u username@adomain.com -p secret
or
testsaslauthd -u username@adomain.com -p secret -s smtp
# testing it with testsaslauthd, it always says "NO authentication failed". idk how to fix that
# HOWever, testing AUTH LOGIN through an smtp session, it is authenticating ok.
3) Last step took me about a day and a half to figure out :clap: :lol: :idea:
systemctl start saslauthd
systemctl enable saslauthd
systemctl restart postfix
# enable sasl lol
4) Test with your favorite smtp tester, using AUTH LOGIN
it seems like most of the steps from the 2017 post were added in recent versions. such as;
-uncomment in master.cf
-and /etc/sasl2/smtpd.conf
My intention for enabling sasl is to allow an external service to relay through using auth login, for alerts and stuff. The regular relay based on ip address (menu 7/menu 1) works fine but im moving my external service to azure which totally blocks outbound port 25, must use tls/587.
Next step is configure my external service (postfix) to relay through efa using login.
mattch
Re: Getting SASL to work
Post by mattch »
Well.... I am halfway there :lol:
I did my 'auth login' test using port 25 :doh:
Port 25 authenticates ok but not on 587
testing on port 587 i get:
535 5.7.8 Error: authentication failed: UGFzc3dvcmQ6
i tested with openssl:
> openssl s_client -starttls smtp -connect server:587 -crlf -ign_eof
250 SMTPUTF8
ehlo dude
250-server
250-PIPELINING
250-SIZE 133169152
250-ETRN
250-AUTH PLAIN LOGIN
250-ENHANCEDSTATUSCODES
250-8BITMIME
250-DSN
250 SMTPUTF8
auth login
334 VXNlcm5hbWU6
xxxxx
334 UGFzc3dvcmQ6
xxxxx
Anyone have a suggestion on where to look to get authentication working on port 587? :pray:
It seems like it is not looking towards the sasl database but idk.
Thank you!!
deajan
Post by deajan »
So I'll answer this for anyone who may actually need this.
So first: saslauthd is compiled without sasldb support on RHEL9 (yes, sounds crazy, was already that way on RHEL7).
Because of this, all testsaslauthd tests will fail, regardless of what you configure.
Step 1: Install cyrus sasl auth mecanisms
dnf install cyrus-sasl*
Step 2: Configure /etc/sasl2/smtpd.conf like this:
pwcheck_method: auxprop
auxprop_plugin: sasldb
mech_list: plain login CRAM-MD5 DIGEST-MD5
This file is used by postfix when using cyrus sasl (default), and will tell postfix what auth mechanisms are allowed, and what kind of backend we use (here, we use a standard berkleyDB file for user/passwords).
Step 3: Create a user
saslpasswd2 -c -u domain.tld username
You can search your users with
sasldblistusers2
Step 4. Make sure postfix can read the sasldb2 file
chown postfix /etc/sasl2/sasldb2
Step 5: Configure postfix
Open /etc/postfix/main.cf and add the following lines
# NPF-MOD for SASL auth
smtpd_sasl_path = sasl2/smtpd.conf
smtpd_sasl_local_domain =
smtpd_sasl_security_options = noanonymous
broken_sasl_auth_clients = yes
smtpd_forbid_unauth_pipelining = yes
smtpd_discard_ehlo_keywords = chunking, silent-discard
smtpd_sasl_type = cyrus
Step 6: Verify if someone overrides the smtpd_sasl settings
This one drove me nuts. I had to enable debugging in postfix to realize that postfix still used dovecot sasl (try to auth against IMAP server) instead of cyrus (sasldb).
Open /etc/postfix/master.cf and search for
-o smtpd_sasl_type=dovecot
under the submission line.
If you have that setting enabled, comment it out.
Step 7: Restart postfix
Step 8: Test postfix
Prepare your login string as base64 string with the following (the \0 are mandatory)
echo -ne "\0username@domain.tld\0password"|base64
Now open telnet like this and test your auth
telnet localhost 587
Escape character is '^]'.
220 smtp.myserverdomain.tld ESMTP Postfix
EHLO me
250-smtp.myserverdomain.tld
250-PIPELINING
250-SIZE 133169152
250-ETRN
250-STARTTLS
250-AUTH GSS-SPNEGO GSSAPI SCRAM-SHA-256 SCRAM-SHA-1 GS2-KRB5 GS2-IAKERB DIGEST-MD5 CRAM-MD5 NTLM LOGIN PLAIN
250-AUTH=GSS-SPNEGO GSSAPI SCRAM-SHA-256 SCRAM-SHA-1 GS2-KRB5 GS2-IAKERB DIGEST-MD5 CRAM-MD5 NTLM LOGIN PLAIN
250-8BITMIME
250-DSN
250 SMTPUTF8
AUTH PLAIN
334
<THE BASE64 STRING>
235 2.7.0 Authentication successful
QUIT
221 2.0.0 Bye
Keep in mind that users created via the webinterface of e-F-a are not available in sasldb, nor in dovecot, so any user you want to authenticate must actually be created in shell.
novyjtop
Post by novyjtop »
https://telegra.ph/Gruzovoj-gazel-3-tonny-07-01
https://telegra.ph/Lyuft-v-rulevoj-ford-06-27
https://telegra.ph/CHto-izvestno-o-permi-07-01
https://telegra.ph/Bzmzh-molochnaya-pro ... ehto-07-11
https://telegra.ph/Prigovorki-primery-5-07-05
https://telegra.ph/Kak-ustanavlivat-zad ... echi-07-01
https://telegra.ph/Vote-breaktudo-awards-07-11
https://telegra.ph/Dezrinit-gormonalnye-kapli-06-29
https://telegra.ph/EHksperimentator-izm ... rnya-06-29
https://telegra.ph/Colossus-build-06-25
https://telegra.ph/Grafik-pereseleniya- ... acii-07-11
https://telegra.ph/Video-futbola-portugalii-07-01
https://telegra.ph/ZHiteli-tajga-zhivotnye-06-25
https://telegra.ph/Remen-generatora-zam ... nter-07-15
https://telegra.ph/Krasnodar-bmv-upalo-07-06
https://telegra.ph/Luchshie-nizkoroslye ... plic-06-24
https://telegra.ph/Kak-pishetsya-slovo- ... stna-07-13
https://telegra.ph/Ot-chego-tabletki-te ... ciya-07-13
https://telegra.ph/Vyezd-za-granicu-vo-vremya-07-02
https://telegra.ph/Geodezist-chto-nuzhn ... assa-07-14
https://telegra.ph/Kak-stykovat-ugly-na-otlivah-06-28
https://telegra.ph/Primeneniya-gabionov-06-24
https://telegra.ph/CHto-takoe-pogovorka-4-klass-07-03
https://telegra.ph/Poteri-v-rabote-transformatora-06-27
https://telegra.ph/Doplata-pensii-kak-p ... lugi-07-07
https://telegra.ph/113-sosh-omsk-07-08
https://telegra.ph/Matematika-5-klass-z ... 1-88-07-07
https://telegra.ph/Zakirova-drkb-07-13
https://telegra.ph/Matematika-2-klass-p ... r-16-06-26
https://telegra.ph/Pochemu-zhenshchina- ... hiny-07-14
https://telegra.ph/Tulip-dress-06-30
https://telegra.ph/Kak-sdelat-strelbu-v-blyustaks-07-14
https://telegra.ph/Svoj-dvizhok-dlya-igr-07-12
https://telegra.ph/Luchshee-vremya-yanvar-06-30
https://telegra.ph/Esli-mama-na-rabote-pesnya-07-15
https://telegra.ph/599-evro-07-05
https://telegra.ph/Pogoda-v-rovnom-na-r ... skoj-07-14
https://telegra.ph/Zadaniya-na-temu-litosfera-06-28
https://telegra.ph/Vopros-k-slovu-yadro-06-30
https://telegra.ph/Utilita-ehto-sistemn ... amma-06-30
https://telegra.ph/Gde-pogulyat-v-nizhn ... enyu-07-04
https://telegra.ph/Semena-cha-06-28
https://telegra.ph/Mirovye-sudi-rk-07-01
https://telegra.ph/Gorkogo-13-syktyvkar-07-12
https://telegra.ph/Biografii-uralochki-07-07
https://telegra.ph/Salon-kitti-brass-06-28
https://telegra.ph/D-atv-06-28
https://telegra.ph/Proverochnaya-rabota ... isel-06-30
https://telegra.ph/Kak-diztoplivo-perev ... onny-07-04
https://telegra.ph/Dzhin-smehsh-07-02
<a href="https://home-babos.ru">https://home-babos.ru</a>
