spf not working
spf not working
Tried a couple of days, but do not get any further...
As SPF worked fine in efa 4 , but I do not get it work at v5.0.
Anything seems to be configured correctly, but I do not have any entries in Spam Report except "SPF_HELO_PASS".
Tested with mails and invalid SPF, but nothing noticed or done.
Any idea what to check - maybe a litte HowTo?
Re: spf not working
does anyone use SPF and has a working config to display here?
Re: spf not working
Can nobody help here?
Am I the only one for whom this doesn't work?
Re: spf not working
Hi JOP,
Where are you trying to make SPF work?
Postfix?
Sendmail?
SpamAssassin?
Somewhere else?
Before anyone can help you, you will need to help yourself a little
Postfix?
Sendmail?
SpamAssassin?
Somewhere else?
Re: spf not working
thank you for your answer, where should i enable it?
Where the best place to enable it?
Re: spf not working
In the EFA portal, go to the "Tools And Links" section and click on "Update SpamAssassin Rule Descriptions"
Then search the results and see if you have the following rules...
SPF_FAIL SPF: sender does not match SPF record (fail)
SPF_HELO_FAIL SPF: HELO does not match SPF record (fail)
SPF_HELO_NEUTRAL SPF: HELO does not match SPF record (neutral)
SPF_HELO_NONE SPF: HELO does not publish an SPF Record
SPF_HELO_PASS SPF: HELO matches SPF record
SPF_HELO_SOFTFAIL SPF: HELO does not match SPF record (softfail)
SPF_NEUTRAL SPF: sender does not match SPF record (neutral)
SPF_NONE SPF: sender does not publish an SPF Record
SPF_PASS SPF: sender matches SPF record
SPF_SOFTFAIL SPF: sender does not match SPF record (softfail)
Re: spf not working
thank you, got this
but no SPF entries in mail header with known bad senders.
Re: spf not working
the only entry in mail header of each mail is:
0.00 SPF_HELO_NONE SPF: HELO does not publish an SPF Record
Re: spf not working
In that case, unless you changed some setting that broke SA (SpamAssassin)'s ability to do SPF checks, it appears that incoming emails are meeting the SPF requirements.
Note that if you enabled SPF checks in Postfix so that non-compliant emails are rejected, those emails will never reach SA. This could also be by you're not seeing those SA tags.
Re: spf not working
I did not modify the postfix configuration.
Re: spf not working
in the file /etc/mail/spamassassin/init.pre, make sure you have the following code:
# SPF - perform SPF verification.
loadplugin Mail::SpamAssassin::Plugin::SPF
Re: spf not working
Then it should be working well.
Check your log files for errors.
Re: spf not working
Postfix, MailScanner and Spamassassin all log to: /var/log/maillog
Re: spf not working
If there are no errors, then everything is working as configured.
Re: spf not working
I don't understand your point.
You asked for help and I offered you some to the limit of my abilities.
Re: spf not working
https://telegra.ph/Pogoda-baryatino-kal ... a-14-07-15
https://telegra.ph/Zayavlenie-na-attest ... 2025-07-02
https://telegra.ph/Novosti-kurska-7-okt ... goda-06-30
https://telegra.ph/Grm-alfa-156-06-29
https://telegra.ph/Kak-v-sims-vygnat-pe ... doma-07-11
https://telegra.ph/Lodochnyj-motor-rr-07-07
https://telegra.ph/Mednyj-kuporos-dlya- ... osok-06-30
https://telegra.ph/Volery-dlya-laek-06-27
https://telegra.ph/Biologiya-8-klass-pa ... pekt-07-06
https://telegra.ph/Pozdravlenie-s-dnem- ... slez-07-12
https://telegra.ph/orum-molodyh-malchikov-07-06
https://telegra.ph/Malina-v-molochnom-s ... naya-06-26
https://telegra.ph/Torgservis-moskva-07-12
https://telegra.ph/Tyanut-ruku-na-uroke-06-30
https://telegra.ph/The-action-is-conditioned-07-14
https://telegra.ph/kij-voenkomat-moskva-adres-07-09
https://telegra.ph/Ukazannyj-redirect-uri-07-01
https://telegra.ph/Pogodu-v-mordovskom-kameshkire-07-07
https://telegra.ph/Kanon-mnogim-soderzh ... itat-07-14
https://telegra.ph/Seven-hotel-stambul-07-11
https://telegra.ph/Muzhchina-kasaetsya-gubami-07-14
https://telegra.ph/Invalidy-obsluzhivan ... nike-07-12
https://telegra.ph/Spusk-po-ldu-na-lyzhah-5-bukv-07-03
https://telegra.ph/Pas-de-pa-pesnya-07-04
https://telegra.ph/Dialog-primer-shkolniki-06-30
https://telegra.ph/Ajsbergi-marshruty-07-07
https://telegra.ph/Nomer-lyskovskoj-crb-07-12
https://telegra.ph/Zaporozhec-trudy-07-05
https://telegra.ph/YUni-34-07-13
https://telegra.ph/Ottok-podzheludochnoj-zhelezy-06-30
https://telegra.ph/Volosy-veroniki-ficdzherald-06-28
https://telegra.ph/3-ka-boka-06-29
https://telegra.ph/Peshki-edyat-korolya-06-29
https://telegra.ph/Alpaza-07-14
https://telegra.ph/Germetik-dvigatelya-aga-otzyvy-07-08
https://telegra.ph/Tradicionnye-predmety-nanajcev-07-14
https://telegra.ph/Novosti-losta-vologda-07-08
https://telegra.ph/nnaya-ptica-07-11
https://telegra.ph/Article-the-is-not-used-with-07-14
https://telegra.ph/Povyshen-horoshij-ho ... chit-07-11
https://telegra.ph/Kondicionery-primorskij-kraj-06-24
https://telegra.ph/CHto-ehto-proizoshlo ... niem-07-11
https://telegra.ph/SHurupovert-akkumuly ... 7dwe-07-13
https://telegra.ph/Pugv-1h1-chernyj-06-25
https://telegra.ph/Vtoroj-ehtap-hamster-07-13
https://telegra.ph/Fatalist-kavabanga-06-28
https://telegra.ph/Razgovor-o-vazhnom-2 ... brya-06-28
https://telegra.ph/Tushenaya-kapusta-s-opyatami-06-27
https://telegra.ph/CHernyj-tank-igra-07-03
https://telegra.ph/Sensa-gta-5-rp-07-04
<a href="https://home-babos.ru">https://home-babos.ru</a>
Re: spf not working
One more thing you can try
In the MailScanner portal under "Tools & Links", run the "MailScanner Lint" and "Spamassassin Lint" and check for errors or warnings in each one.
