howto check SPF working
it seems SPF on efa5 is not working. Ho to check it is working?
Re: howto check SPF working
You'll need to provide more information.
What exactly is not working and how do you know?
Since you've provided essentially no information, all I can suggest is to start here: https://mxtoolbox.com/SuperTool.aspx and check your spf record for your domain to see if there are any problems there.
https://telegra.ph/Razvitiem-nej-patologicheskogo-07-11
https://telegra.ph/5-gektopaskalej-06-30
https://telegra.ph/Raspisanie-avtobusa- ... fevo-07-01
https://telegra.ph/Selo-pechorskoe-07-12
https://telegra.ph/Kashu-molokom-8-bukv-07-06
https://telegra.ph/Dzhenni-kitti-zastryala-07-07
https://telegra.ph/Hover-n3-20-moment-zatyazhki-07-04
https://telegra.ph/Rovnyj-pol-video-06-24
https://telegra.ph/Sedovlasyj-mehtr-sceny-7-bukv-07-02
https://telegra.ph/Vh-2-9-v-07-03
https://telegra.ph/Opadayut-listya-u-ko ... enij-06-26
https://telegra.ph/atnye-kvartiry-v-nov ... -ufa-07-12
https://telegra.ph/Pochemu-tokeny-homya ... elek-06-25
https://telegra.ph/Polka-pegbord-06-28
https://telegra.ph/Pravovoe-regulirovan ... ehto-07-07
https://telegra.ph/Vyalbe-dostizheniya-06-25
https://telegra.ph/Koncovka-v-skazke-ca ... isat-07-02
https://telegra.ph/Botanika-holl-novosibirsk-07-01
https://telegra.ph/Kampot-maenkravt-07-04
https://telegra.ph/Manikyur-altufevskoe-sh-07-11
https://telegra.ph/Grossman-moskva-07-01
https://telegra.ph/Gore-ptichij-foto-07-13
https://telegra.ph/Strojudacha-polyany-katalog-07-12
https://telegra.ph/Nasadki-na-glushitel-buzzer-06-27
https://telegra.ph/Milkom-gde-nahoditsya-07-03
https://telegra.ph/SHeryurak-uzbek-12-07-07
https://telegra.ph/Video-shatunova-a-leto-cveta-07-14
https://telegra.ph/Naleteli-kak-saranch ... acha-07-02
https://telegra.ph/Tun-tun-turururu-06-27
https://telegra.ph/Skolko-vremeni-kopti ... niya-06-27
https://telegra.ph/Nickel-use-07-14
https://telegra.ph/Tanec-katyusha-detskie-07-05
https://telegra.ph/Sovremennyj-avialajn ... kolo-06-28
https://telegra.ph/Seung-hun-07-13
https://telegra.ph/Bolee-shestista-kak-pravilno-07-01
https://telegra.ph/Suhoj-bulon-kuhnya-06-25
https://telegra.ph/Pasha-soobshchenie-o ... atko-06-29
https://telegra.ph/Volynskih-svyatyh-07-02
https://telegra.ph/EHrmitazh-sankt-herm ... -org-06-25
https://telegra.ph/Dzhodi-igra-07-04
https://telegra.ph/Bystroe-marinovanie-baklazhan-07-13
https://telegra.ph/Prihodnyj-order-po-forme-m-4-06-27
https://telegra.ph/15-aprelya-kultura-07-03
https://telegra.ph/Generator-honda-2-kvt-07-15
https://telegra.ph/Pure-urfu-07-08
https://telegra.ph/I-m-wearing-a-hat-07-04
https://telegra.ph/Kryukovo-zelenopark-ostanovki-06-26
https://telegra.ph/Prodaetsya-nabor-dly ... stva-07-12
https://telegra.ph/Ohranniki-berkut-06-26
https://telegra.ph/Mantry-solncu-slushat-108-07-05
<a href="https://home-babos.ru">https://home-babos.ru</a>
