ef3 to ef5
ef3 to ef5
Is there a direct upgrade path from ef3 to ef5?
Re: ef3 to ef5
Do I need to upgrade from ef3->ef4, then ef4->ef5, or is there a direct upgrade from ef3->ef5 ?
Re: ef3 to ef5
For the amount of work involved, you're probably better off installing a brand new clean efa5 installation.
What is so important that you want to preserve from your efa3 installation?
Re: ef3 to ef5
It's not super important, but it would be nice to preserve the black and white lists, and possibly the greylist info (not sure if that is actually needed).pdwalker wrote: 21 May 2025 12:07 For the amount of work involved, you're probably better off installing a brand new clean efa5 installation.
