Does anyone know if it is possible [and ultimately how] I can have EFA verify emails against an Active Directory server for a select number of the mail domains configured on the system?
ie.
abc.com > EFA > Destination Server [Postfix]
xyz.com > EFA > [AD lookup] > Destination Server 1 [Exchange 2007]
qrs.com > EFA > [AD lookup] > Destination Server 2 [Exchange 2010]
etc.
Or am I asking too much for AD lookups?
Matthew
AD Integration for select domains
Re: AD Integration for select domains
Do You want to check if email is correct?
I think that's possible:
http://blog.widmo.biz/postfix-check-use ... tory-ldap/
Just use more files:
And ask each domain. If it possible to filter query to one domain? I don't know...
http://forums.opensuse.org/showthread.p ... th-postfix
check_recipient_access ldap:/etc/postfix/ldap-users-domain_1.cf, ldap:/etc/postfix/ldap-users-domain_2.cf, hash:/etc/postfix/recipient_access,http://forums.opensuse.org/showthread.p ... th-postfix
Thanks for the reply.
That is very helpful thank you.
My concern is though with this section:
If it checks each of the domains against the ldap servers listed, and the domain in question has no associated ldap lookup, will the email address be deemed as invalid and therefore rejected. Or will it realise that the ldap lookups do not contain the domain being checked, and allow all addresses to pass [like the default configuration does]
4) Modify your /etc/postfix/main.cf to achieve this one:
smtpd_recipient_restrictions = permit_sasl_authenticated,
permit_mynetworks,
reject_unauth_destination,
reject_non_fqdn_recipient,
check_recipient_access ldap:/etc/postfix/ldap-users.cf, hash:/etc/postfix/recipient_access,
reject
if found in ldap:/etc/postfix/ldap-users.cf or hash:/etc/postfix/recipient_access, it will pass email,
and if not found it will drop it, cause of
reject on end of config.
You can remove reject, but it doesn't have any sense
>>> reject <<< You can remove reject, but it doesn't have any sense
