We have a problem where email is blocked with "Bad content" (Blocked File: Y) because of the filename length.
While the filename itself isn't long, the "Path to message" is much longer.
i.e. "New document.doc" vs "20250128/45gtsmw4hFzqgP/New document.doc"
How is this handled?
How can I change the accepted filename length?
Thank you
"Path to message" vs filename length issue
Re: "Path to message" vs filename length issue
Could it be something on /etc/MailScanner/filename.rules.conf:
And change deny to allow?
systemctl restart mailscanner
BR
deny .{150,} Very long filename, possible OE attack Very long filenames are good signs of attacks against Microsoft e-mail packagessystemctl restart mailscanner
BR
Thanks for the info.
It looks like changing the value to 240 did help. The service did not like it when I set it to 250 though.
I do still want to have control over extremely long files, so I keep it at deny for a while. We'll see how it behaves.
This will resolve my issue, but does not fix the bug with the extraction path being added to the filename before the regex test.
P.S.> Outlook Express is dead for years
, rest in piece
CMIIW,
Is it because Linux filename limit is 255 characters?
So, when you limit it with 240 then you have 15 characters left for pathname...
BR
BR
IIRC File name and path length hare independent.
Most operating systems have a limit of 255 characters for the filename.
On linux, the maximum path length is defined by PATH_MAX which is in most cases set to 4096.
I am not sure why it crashes when I set the regex value to 255, but I assume the register is overflowing and 254 would work. (I haven't tested it yet).
It may also be that it adds the file extension's length to it.
Never the less 240 seems to be working for me so far.
