Hi.
When I reboot efa it takes a lot of time for mariadb to settle down and relay info is missing.
Is there a task to RE-parse relay info and insert it to db?
What will happen after lets say 1 year of usage? Will reboot make mariadb go crazy for a long time to re-read relay info?
reboot and mariadb usage
Re: reboot and mariadb usage
Queries are like this (DB MAILSCANNER):
SELECT id from `maillog` where messageid='<dfgdfgfd3d928a7874dsfdfs89f9afdeac38d6@domain.com>' and to_address LIKE '%user123@otherdomain.com%' LIMIT 1
OK, so it would be wise to add "daily" in:
/etc/logrotate.d/rsyslog
Like this:
Because weekly files are too large and when cron tries to RE-read all relay info it takes a looong time...
Like this:
/var/log/cron
/var/log/maillog
/var/log/messages
/var/log/secure
/var/log/spooler
missingok
sharedscripts
daily
postrotate
/usr/bin/systemctl -s HUP kill rsyslog.service >/dev/null 2>&1 || true
endscript
