EFA5 Greylisting toggle, does not change main.cf
e-d-i-t
Post by e-d-i-t »
My batchedSMTP mail connection failed as port 2501 was not replying when greylisting is off.
So when I looked in mail.log I saw it was still probing port 2501 for greylisting.
MAIN.CF
smtpd_recipient_restrictions = permit_sasl_authenticated, permit_mynetworks, reject_unauth_destination, reject_non_fqdn_recipient, reject_unknown_recipient_domain, check_recipient_access hash:/etc/postfix/recipient_access, check_policy_service inet:127.0.0.1:2501, reject_unverified_recipient
And I changed this manually to:
Re: EFA5 Greylisting toggle, does not change main.cf
This is strange. I am able to toggle greylisting via eFa-Configure and the check_policy_service inet:127.0.0.1:2501 appears and drops off like is should. Looking at the code I don't see anything obvious that would cause this to happen.
e-d-i-t
Post by e-d-i-t »
Maybe because I was still using an updated version of a beta now being 5.0.0.8?
Do I need to re-install fresh since 5 is live?
I can always do a fresh new virtual machine install to check if it alters the main.cf in postfix.
Shouldn't have to, the updates are cumulative, so switching from beta to release shouldn't have caused this sort of issue.
