SFTP broken after running EFA 5.0.0 install script
Bugs in eFa 5
Mail2GoCa
Post by Mail2GoCa »
Good day.
SFTP access to the CentOS 9 server is broken after running the install script for EFA 5.0.0
I have not looked into every line of code in the script to see why yet because I thought perhaps somebody here would know.
Anybody?
Mail2GoCa
Re: SFTP broken after running EFA 5.0.0 install script
Post by Mail2GoCa »
The next few posts constitute a screen dump of what took place during the execution of the install script.
Before the script was run, sftp was working.
After the script, sftp is broken.
[root@efa ~]# sudo bash build.bash
2024.07.14-12:18:36 - =============  EFA 4 (EL 8) / 5 (EL 9) BUILD SCRIPT STARTING  ============
2024.07.14-12:18:36 - Good you are root.
2024.07.14-12:18:36 - Good you are running CentOS 9 Stream or similar flavor
2024.07.14-12:18:36 - Checking network connectivity
2024.07.14-12:18:37 - OK - https://mirrors.efa-project.org is reachable
2024.07.14-12:18:37 - Installing perl
Last metadata expiration check: 3:36:08 ago on Sun 14 Jul 2024 08:42:29 AM GMT.
Dependencies resolved.
 Package                       Arch    Version                 Repository  Size
Installing:
 perl                          x86_64  4:5.32.1-481.el9        appstream  8.2 k
Installing dependencies:
 annobin                       x86_64  12.31-2.el9             appstream  1.0 M
 cpp                           x86_64  11.4.1-3.el9            appstream   11 M
 dwz                           x86_64  0.14-3.el9              appstream  128 k
 efi-srpm-macros               noarch  4-9.el9                 appstream   23 k
 fonts-srpm-macros             noarch  1:2.0.5-7.el9.1         appstream   28 k
 gcc                           x86_64  11.4.1-3.el9            appstream   32 M
 gcc-c++                       x86_64  11.4.1-3.el9            appstream   13 M
 gcc-plugin-annobin            x86_64  11.4.1-3.el9            appstream   47 k
 ghc-srpm-macros               noarch  1.5.0-6.el9             appstream  8.8 k
 glibc-devel                   x86_64  2.34-113.el9            appstream   35 k
 glibc-headers                 x86_64  2.34-113.el9            appstream  540 k
 go-srpm-macros                noarch  3.2.0-3.el9             appstream   27 k
 kernel-headers                x86_64  5.14.0-474.el9          appstream  3.1 M
 kernel-srpm-macros            noarch  1.0-13.el9              appstream   16 k
 libdatrie                     x86_64  0.2.13-4.el9            appstream   33 k
 libmpc                        x86_64  1.2.1-4.el9             appstream   62 k
 libpkgconf                    x86_64  1.7.3-10.el9            baseos      36 k
 libstdc++-devel               x86_64  11.4.1-3.el9            appstream  2.4 M
 libthai                       x86_64  0.1.28-8.el9            appstream  208 k
 libxcrypt-devel               x86_64  4.4.18-3.el9            appstream   29 k
 llvm-libs                     x86_64  18.1.6-3.el9            appstream   50 M
 lua-srpm-macros               noarch  1-6.el9                 appstream  9.5 k
 make                          x86_64  1:4.3-8.el9             baseos     536 k
 ocaml-srpm-macros             noarch  6-6.el9                 appstream  8.8 k
 openblas-srpm-macros          noarch  2-11.el9                appstream  8.4 k
 perl-Algorithm-Diff           noarch  1.2010-4.el9            appstream   48 k
 perl-Archive-Tar              noarch  2.38-6.el9              appstream   72 k
 perl-Archive-Zip              noarch  1.68-6.el9              appstream  112 k
 perl-Attribute-Handlers       noarch  1.01-481.el9            appstream   27 k
 perl-AutoLoader               noarch  5.74-481.el9            appstream   21 k
 perl-AutoSplit                noarch  5.74-481.el9            appstream   21 k
 perl-B                        x86_64  1.80-481.el9            appstream  180 k
 perl-Benchmark                noarch  1.23-481.el9            appstream   26 k
 perl-CPAN                     noarch  2.29-3.el9              appstream  557 k
 perl-CPAN-Meta                noarch  2.150010-460.el9        appstream  202 k
 perl-CPAN-Meta-Requirements   noarch  2.140-461.el9           appstream   32 k
 perl-CPAN-Meta-YAML           noarch  0.018-461.el9           appstream   27 k
 perl-Carp                     noarch  1.50-460.el9            appstream   30 k
 perl-Class-Struct             noarch  0.66-481.el9            appstream   22 k
 perl-Compress-Bzip2           x86_64  2.28-5.el9              appstream   70 k
 perl-Compress-Raw-Bzip2       x86_64  2.101-5.el9             appstream   35 k
 perl-Compress-Raw-Lzma        x86_64  2.101-3.el9             appstream   51 k
 perl-Compress-Raw-Zlib        x86_64  2.101-5.el9             appstream   61 k
 perl-Config-Extensions        noarch  0.03-481.el9            appstream   12 k
 perl-Config-Perl-V            noarch  0.33-4.el9              appstream   22 k
 perl-DBM_Filter               noarch  0.06-481.el9            appstream   31 k
 perl-DB_File                  x86_64  1.855-4.el9             appstream   82 k
 perl-Data-Dumper              x86_64  2.174-462.el9           appstream   56 k
 perl-Data-OptList             noarch  0.110-17.el9            appstream   27 k
 perl-Data-Section             noarch  0.200007-14.el9         appstream   26 k
 perl-Devel-PPPort             x86_64  3.62-4.el9              appstream  212 k
 perl-Devel-Peek               x86_64  1.28-481.el9            appstream   32 k
 perl-Devel-SelfStubber        noarch  1.06-481.el9            appstream   14 k
 perl-Devel-Size               x86_64  0.83-10.el9             appstream   32 k
 perl-Digest                   noarch  1.19-4.el9              appstream   26 k
 perl-Digest-MD5               x86_64  2.58-4.el9              appstream   37 k
 perl-Digest-SHA               x86_64  1:6.02-461.el9          appstream   62 k
 perl-Digest-SHA1              x86_64  2.13-34.el9             appstream   53 k
 perl-DirHandle                noarch  1.05-481.el9            appstream   12 k
 perl-Dumpvalue                noarch  2.27-481.el9            appstream   18 k
 perl-DynaLoader               x86_64  1.47-481.el9            appstream   25 k
 perl-Encode                   x86_64  4:3.08-462.el9          appstream  1.7 M
 perl-Encode-devel             x86_64  4:3.08-462.el9          appstream   42 k
 perl-English                  noarch  1.11-481.el9            appstream   13 k
 perl-Env                      noarch  1.04-460.el9            appstream   20 k
 perl-Errno                    x86_64  1.30-481.el9            appstream   14 k
 perl-Exporter                 noarch  5.74-461.el9            appstream   32 k
 perl-ExtUtils-CBuilder        noarch  1:0.280236-4.el9        appstream   49 k
 perl-ExtUtils-Command         noarch  2:7.60-3.el9            appstream   15 k
 perl-ExtUtils-Constant        noarch  0.25-481.el9            appstream   46 k
 perl-ExtUtils-Embed           noarch  1.35-481.el9            appstream   17 k
 perl-ExtUtils-Install         noarch  2.20-4.el9              appstream   45 k
 perl-ExtUtils-MM-Utils        noarch  2:7.60-3.el9            appstream   13 k
 perl-ExtUtils-MakeMaker       noarch  2:7.60-3.el9            appstream  300 k
 perl-ExtUtils-Manifest        noarch  1:1.73-4.el9            appstream   35 k
 perl-ExtUtils-Miniperl        noarch  1.09-481.el9            appstream   15 k
 perl-ExtUtils-ParseXS         noarch  1:3.40-460.el9          appstream  186 k
 perl-Fcntl                    x86_64  1.13-481.el9            appstream   20 k
 perl-File-Basename            noarch  2.85-481.el9            appstream   17 k
 perl-File-Compare             noarch  1.100.600-481.el9       appstream   13 k
 perl-File-Copy                noarch  2.34-481.el9            appstream   20 k
 perl-File-DosGlob             x86_64  1.12-481.el9            appstream   19 k
 perl-File-Fetch               noarch  1.00-4.el9              appstream   31 k
 perl-File-Find                noarch  1.37-481.el9            appstream   25 k
 perl-File-HomeDir             noarch  1.006-4.el9             appstream   60 k
 perl-File-Path                noarch  2.18-4.el9              appstream   36 k
 perl-File-Temp                noarch  1:0.231.100-4.el9       appstream   60 k
 perl-File-Which               noarch  1.23-10.el9             appstream   22 k
 perl-File-stat                noarch  1.09-481.el9            appstream   17 k
 perl-FileCache                noarch  1.10-481.el9            appstream   14 k
 perl-FileHandle               noarch  2.03-481.el9            appstream   15 k
 perl-Filter                   x86_64  2:1.60-4.el9            appstream   91 k
 perl-Filter-Simple            noarch  0.96-460.el9            appstream   28 k
 perl-FindBin                  noarch  1.51-481.el9            appstream   14 k
 perl-GDBM_File                x86_64  1.18-481.el9            appstream   22 k
 perl-Getopt-Long              noarch  1:2.52-4.el9            appstream   61 k
 perl-Getopt-Std               noarch  1.12-481.el9            appstream   15 k
 perl-HTTP-Tiny                noarch  0.076-462.el9           appstream   54 k
 perl-Hash-Util                x86_64  0.23-481.el9            appstream   34 k
 perl-Hash-Util-FieldHash      x86_64  1.20-481.el9            appstream   38 k
 perl-I18N-Collate             noarch  1.02-481.el9            appstream   14 k
 perl-I18N-LangTags            noarch  0.44-481.el9            appstream   54 k
 perl-I18N-Langinfo            x86_64  0.19-481.el9            appstream   22 k
 perl-IO                       x86_64  1.43-481.el9            appstream   88 k
 perl-IO-Compress              noarch  2.102-4.el9             appstream  270 k
 perl-IO-Compress-Lzma         noarch  2.101-4.el9             appstream   78 k
 perl-IO-Socket-IP             noarch  0.41-5.el9              appstream   43 k
 perl-IO-Socket-SSL            noarch  2.073-2.el9             appstream  217 k
 perl-IO-Zlib                  noarch  1:1.11-4.el9            appstream   20 k
 perl-IPC-Cmd                  noarch  2:1.04-461.el9          appstream   40 k
 perl-IPC-Open3                noarch  1.21-481.el9            appstream   22 k
 perl-IPC-SysV                 x86_64  2.09-4.el9              appstream   43 k
 perl-IPC-System-Simple        noarch  1.30-6.el9              appstream   41 k
 perl-Importer                 noarch  0.026-4.el9             appstream   40 k
 perl-JSON-PP                  noarch  1:4.06-4.el9            appstream   67 k
 perl-Locale-Maketext          noarch  1.29-461.el9            appstream   95 k
 perl-Locale-Maketext-Simple   noarch  1:0.21-481.el9          appstream   17 k
 perl-MIME-Base64              x86_64  3.16-4.el9              appstream   31 k
 perl-MIME-Charset             noarch  1.012.2-15.el9          appstream   49 k
 perl-MRO-Compat               noarch  0.13-15.el9             appstream   20 k
 perl-Math-BigInt              noarch  1:1.9998.18-460.el9     appstream  190 k
 perl-Math-BigInt-FastCalc     x86_64  0.500.900-460.el9       appstream   28 k
 perl-Math-BigRat              noarch  0.2614-460.el9          appstream   39 k
 perl-Math-Complex             noarch  1.59-481.el9            appstream   46 k
 perl-Memoize                  noarch  1.03-481.el9            appstream   56 k
 perl-Module-Build             noarch  2:0.42.31-9.el9         appstream  263 k
 perl-Module-CoreList          noarch  1:5.20210320-3.el9      appstream   82 k
 perl-Module-CoreList-tools    noarch  1:5.20210320-3.el9      appstream   19 k
 perl-Module-Load              noarch  1:0.36-4.el9            appstream   18 k
 perl-Module-Load-Conditional  noarch  0.74-4.el9              appstream   23 k
 perl-Module-Loaded            noarch  1:0.08-481.el9          appstream   13 k
 perl-Module-Metadata          noarch  1.000037-460.el9        appstream   36 k
 perl-Module-Signature         noarch  0.88-1.el9              appstream   84 k
 perl-Mozilla-CA               noarch  20200520-6.el9          appstream   13 k
 perl-NDBM_File                x86_64  1.15-481.el9            appstream   22 k
 perl-NEXT                     noarch  0.67-481.el9            appstream   21 k
 perl-Net                      noarch  1.02-481.el9            appstream   25 k
 perl-Net-Ping                 noarch  2.74-5.el9              appstream   50 k
 perl-Net-SSLeay               x86_64  1.94-1.el9              appstream  414 k
 perl-ODBM_File                x86_64  1.16-481.el9            appstream   22 k
 perl-Object-HashBase          noarch  0.009-7.el9             appstream   26 k
 perl-Opcode                   x86_64  1.48-481.el9            appstream   36 k
 perl-POSIX                    x86_64  1.94-481.el9            appstream   96 k
 perl-Package-Generator        noarch  1.106-23.el9            appstream   24 k
 perl-Params-Check             noarch  1:0.38-461.el9          appstream   23 k
 perl-Params-Util              x86_64  1.102-5.el9             appstream   34 k
 perl-PathTools                x86_64  3.78-461.el9            appstream   88 k
 perl-Perl-OSType              noarch  1.010-461.el9           appstream   24 k
 perl-PerlIO-via-QuotedPrint   noarch  0.09-4.el9              appstream   23 k
 perl-Pod-Checker              noarch  4:1.74-4.el9            appstream   33 k
 perl-Pod-Escapes              noarch  1:1.07-460.el9          appstream   21 k
 perl-Pod-Functions            noarch  1.13-481.el9            appstream   13 k
 perl-Pod-Html                 noarch  1.25-481.el9            appstream   26 k
 perl-Pod-Perldoc              noarch  3.28.01-461.el9         appstream   87 k
 perl-Pod-Simple               noarch  1:3.42-4.el9            appstream  225 k
 perl-Pod-Usage                noarch  4:2.01-4.el9            appstream   41 k
 perl-Safe                     noarch  2.41-481.el9            appstream   25 k
 perl-Scalar-List-Utils        x86_64  4:1.56-462.el9          appstream   71 k
 perl-Search-Dict              noarch  1.07-481.el9            appstream   13 k
 perl-SelectSaver              noarch  1.02-481.el9            appstream   11 k
 perl-SelfLoader               noarch  1.26-481.el9            appstream   21 k
 perl-Socket                   x86_64  4:2.031-4.el9           appstream   56 k
 perl-Software-License         noarch  0.103014-12.el9         appstream  140 k
 perl-Storable                 x86_64  1:3.21-460.el9          appstream   96 k
 perl-Sub-Exporter             noarch  0.987-27.el9            appstream   73 k
 perl-Sub-Install              noarch  0.928-28.el9            appstream   23 k
 perl-Symbol                   noarch  1.08-481.el9            appstream   14 k
 perl-Sys-Hostname             x86_64  1.23-481.el9            appstream   17 k
 perl-Sys-Syslog               x86_64  0.36-461.el9            appstream   48 k
 perl-Term-ANSIColor           noarch  5.01-461.el9            appstream   49 k
 perl-Term-Cap                 noarch  1.17-460.el9            appstream   23 k
 perl-Term-Complete            noarch  1.403-481.el9           appstream   13 k
 perl-Term-ReadLine            noarch  1.17-481.el9            appstream   19 k
 perl-Term-Size-Perl           x86_64  0.031-12.el9            appstream   22 k
 perl-Term-Table               noarch  0.015-8.el9             appstream   36 k
 perl-Test                     noarch  1.31-481.el9            appstream   28 k
 perl-Test-Harness             noarch  1:3.42-461.el9          appstream  295 k
 perl-Test-Simple              noarch  3:1.302183-4.el9        appstream  626 k
 perl-Text-Abbrev              noarch  1.02-481.el9            appstream   12 k
 perl-Text-Balanced            noarch  2.04-4.el9              appstream   48 k
 perl-Text-Diff                noarch  1.45-13.el9             appstream   42 k
 perl-Text-Glob                noarch  0.11-15.el9             appstream   14 k
 perl-Text-ParseWords          noarch  3.30-460.el9            appstream   17 k
 perl-Text-Tabs+Wrap           noarch  2013.0523-460.el9       appstream   24 k
 perl-Text-Template            noarch  1.59-5.el9              appstream   61 k
 perl-Thread                   noarch  3.05-481.el9            appstream   18 k
 perl-Thread-Queue             noarch  3.14-460.el9            appstream   22 k
 perl-Thread-Semaphore         noarch  2.13-481.el9            appstream   15 k
 perl-Tie                      noarch  4.6-481.el9             appstream   31 k
 perl-Tie-File                 noarch  1.06-481.el9            appstream   43 k
 perl-Tie-Memoize              noarch  1.1-481.el9             appstream   14 k
 perl-Tie-RefHash              noarch  1.40-4.el9              appstream   24 k
 perl-Time                     noarch  1.03-481.el9            appstream   18 k
 perl-Time-HiRes               x86_64  4:1.9764-462.el9        appstream   58 k
 perl-Time-Local               noarch  2:1.300-7.el9           appstream   34 k
 perl-Time-Piece               x86_64  1.3401-481.el9          appstream   40 k
 perl-URI                      noarch  5.09-3.el9              appstream  121 k
 perl-Unicode-Collate          x86_64  1.29-4.el9              appstream  760 k
 perl-Unicode-Normalize        x86_64  1.27-461.el9            appstream   91 k
 perl-Unicode-UCD              noarch  0.75-481.el9            appstream   78 k
 perl-User-pwent               noarch  1.03-481.el9            appstream   20 k
 perl-autodie                  noarch  2.34-4.el9              appstream   97 k
 perl-autouse                  noarch  1.11-481.el9            appstream   13 k
 perl-base                     noarch  2.27-481.el9            appstream   16 k
 perl-bignum                   noarch  0.51-460.el9            appstream   43 k
 perl-blib                     noarch  1.07-481.el9            appstream   12 k
 perl-constant                 noarch  1.33-461.el9            appstream   24 k
 perl-debugger                 noarch  1.56-481.el9            appstream  133 k
 perl-deprecate                noarch  0.04-481.el9            appstream   14 k
 perl-devel                    x86_64  4:5.32.1-481.el9        appstream  676 k
 perl-diagnostics              noarch  1.37-481.el9            appstream  210 k
 perl-doc                      noarch  5.32.1-481.el9          appstream  4.6 M
 perl-encoding                 x86_64  4:3.00-462.el9          appstream   63 k
 perl-encoding-warnings        noarch  0.13-481.el9            appstream   16 k
 perl-experimental             noarch  0.022-6.el9             appstream   22 k
 perl-fields                   noarch  2.27-481.el9            appstream   16 k
 perl-filetest                 noarch  1.03-481.el9            appstream   14 k
 perl-if                       noarch  0.60.800-481.el9        appstream   14 k
 perl-inc-latest               noarch  2:0.500-20.el9          appstream   25 k
 perl-interpreter              x86_64  4:5.32.1-481.el9        appstream   71 k
 perl-less                     noarch  0.03-481.el9            appstream   13 k
 perl-lib                      x86_64  0.65-481.el9            appstream   14 k
 perl-libnet                   noarch  3.13-4.el9              appstream  130 k
 perl-libnetcfg                noarch  4:5.32.1-481.el9        appstream   16 k
 perl-libs                     x86_64  4:5.32.1-481.el9        appstream  2.2 M
 perl-local-lib                noarch  2.000024-13.el9         appstream   68 k
 perl-locale                   noarch  1.09-481.el9            appstream   13 k
 perl-macros                   noarch  4:5.32.1-481.el9        appstream   10 k
 perl-meta-notation            noarch  5.32.1-481.el9          appstream  9.3 k
 perl-mro                      x86_64  1.23-481.el9            appstream   28 k
 perl-open                     noarch  1.12-481.el9            appstream   16 k
 perl-overload                 noarch  1.31-481.el9            appstream   45 k
 perl-overloading              noarch  0.02-481.el9            appstream   12 k
 perl-parent                   noarch  1:0.238-460.el9         appstream   15 k
 perl-perlfaq                  noarch  5.20201107-4.el9        appstream  375 k
 perl-ph                       x86_64  5.32.1-481.el9          appstream   44 k
 perl-podlators                noarch  1:4.14-460.el9          appstream  114 k
 perl-sigtrap                  noarch  1.09-481.el9            appstream   15 k
 perl-sort                     noarch  2.04-481.el9            appstream   13 k
 perl-srpm-macros              noarch  1-41.el9                appstream  9.1 k
 perl-subs                     noarch  1.03-481.el9            appstream   11 k
 perl-threads                  x86_64  1:2.25-460.el9          appstream   58 k
 perl-threads-shared           x86_64  1.61-460.el9            appstream   45 k
 perl-utils                    noarch  5.32.1-481.el9          appstream   55 k
 perl-vars                     noarch  1.05-481.el9            appstream   13 k
 perl-version                  x86_64  7:0.99.28-4.el9         appstream   63 k
 perl-vmsish                   noarch  1.04-481.el9            appstream   14 k
 pkgconf                       x86_64  1.7.3-10.el9            baseos      41 k
 pkgconf-m4                    noarch  1.7.3-10.el9            baseos      15 k
 pkgconf-pkg-config            x86_64  1.7.3-10.el9            baseos      11 k
 pyproject-srpm-macros         noarch  1.12.0-1.el9            appstream   14 k
 python-srpm-macros            noarch  3.9-54.el9              appstream   18 k
 python3-pyparsing             noarch  2.4.7-9.el9             baseos     150 k
 qt5-srpm-macros               noarch  5.15.9-1.el9            appstream  8.8 k
 redhat-rpm-config             noarch  207-1.el9               appstream   72 k
 rust-srpm-macros              noarch  17-4.el9                appstream   10 k
 sombok                        x86_64  2.4.0-16.el9            appstream   48 k
 systemtap-sdt-devel           x86_64  5.1-3.el9               appstream   75 k
 unzip                         x86_64  6.0-56.el9              baseos     182 k
 zip                           x86_64  3.0-35.el9              baseos     266 k
Installing weak dependencies:
 perl-CPAN-DistnameInfo        noarch  0.12-23.el9             appstream   15 k
 perl-Encode-Locale            noarch  1.05-21.el9             appstream   20 k
 perl-Term-Size-Any            noarch  0.002-35.el9            appstream   14 k
 perl-TermReadKey              x86_64  2.38-11.el9             appstream   37 k
 perl-Unicode-LineBreak        x86_64  2019.001-11.el9         appstream  125 k
Transaction Summary
Install  266 Packages
Total download size: 137 M
Installed size: 446 M
Downloading Packages:
(1/266): libpkgconf-1.7.3-10.el9.x86_64.rpm     137 kB/s |  36 kB     00:00
(2/266): pkgconf-1.7.3-10.el9.x86_64.rpm        145 kB/s |  41 kB     00:00
(3/266): pkgconf-m4-1.7.3-10.el9.noarch.rpm     289 kB/s |  15 kB     00:00
(4/266): pkgconf-pkg-config-1.7.3-10.el9.x86_64 207 kB/s |  11 kB     00:00
(5/266): python3-pyparsing-2.4.7-9.el9.noarch.r 1.0 MB/s | 150 kB     00:00
(6/266): unzip-6.0-56.el9.x86_64.rpm            1.2 MB/s | 182 kB     00:00
(7/266): make-4.3-8.el9.x86_64.rpm              1.0 MB/s | 536 kB     00:00
(8/266): zip-3.0-35.el9.x86_64.rpm              1.8 MB/s | 266 kB     00:00
(9/266): dwz-0.14-3.el9.x86_64.rpm              1.3 MB/s | 128 kB     00:00
(10/266): efi-srpm-macros-4-9.el9.noarch.rpm    433 kB/s |  23 kB     00:00
(11/266): fonts-srpm-macros-2.0.5-7.el9.1.noarc 556 kB/s |  28 kB     00:00
(12/266): annobin-12.31-2.el9.x86_64.rpm        2.3 MB/s | 1.0 MB     00:00
(13/266): cpp-11.4.1-3.el9.x86_64.rpm           2.6 MB/s |  11 MB     00:04
(14/266): gcc-plugin-annobin-11.4.1-3.el9.x86_6 921 kB/s |  47 kB     00:00
(15/266): ghc-srpm-macros-1.5.0-6.el9.noarch.rp 157 kB/s | 8.8 kB     00:00
(16/266): glibc-devel-2.34-113.el9.x86_64.rpm   666 kB/s |  35 kB     00:00
(17/266): glibc-headers-2.34-113.el9.x86_64.rpm 2.2 MB/s | 540 kB     00:00
(18/266): go-srpm-macros-3.2.0-3.el9.noarch.rpm 508 kB/s |  27 kB     00:00
(19/266): gcc-c++-11.4.1-3.el9.x86_64.rpm       2.5 MB/s |  13 MB     00:05
(20/266): kernel-srpm-macros-1.0-13.el9.noarch. 318 kB/s |  16 kB     00:00
(21/266): libdatrie-0.2.13-4.el9.x86_64.rpm     637 kB/s |  33 kB     00:00
(22/266): libmpc-1.2.1-4.el9.x86_64.rpm         1.2 MB/s |  62 kB     00:00
(23/266): kernel-headers-5.14.0-474.el9.x86_64. 2.5 MB/s | 3.1 MB     00:01
(24/266): libthai-0.1.28-8.el9.x86_64.rpm       1.9 MB/s | 208 kB     00:00
(25/266): libxcrypt-devel-4.4.18-3.el9.x86_64.r 561 kB/s |  29 kB     00:00
(26/266): libstdc++-devel-11.4.1-3.el9.x86_64.r 2.4 MB/s | 2.4 MB     00:01
(27/266): lua-srpm-macros-1-6.el9.noarch.rpm    190 kB/s | 9.5 kB     00:00
(28/266): ocaml-srpm-macros-6-6.el9.noarch.rpm  173 kB/s | 8.8 kB     00:00
(29/266): openblas-srpm-macros-2-11.el9.noarch. 162 kB/s | 8.4 kB     00:00
(30/266): perl-5.32.1-481.el9.x86_64.rpm        162 kB/s | 8.2 kB     00:00
(31/266): perl-Algorithm-Diff-1.2010-4.el9.noar 950 kB/s |  48 kB     00:00
(32/266): perl-Archive-Tar-2.38-6.el9.noarch.rp 1.4 MB/s |  72 kB     00:00
(33/266): perl-Archive-Zip-1.68-6.el9.noarch.rp 2.1 MB/s | 112 kB     00:00
(34/266): perl-Attribute-Handlers-1.01-481.el9. 531 kB/s |  27 kB     00:00
(35/266): perl-AutoLoader-5.74-481.el9.noarch.r 415 kB/s |  21 kB     00:00
(36/266): perl-AutoSplit-5.74-481.el9.noarch.rp 417 kB/s |  21 kB     00:00
(37/266): perl-B-1.80-481.el9.x86_64.rpm        1.8 MB/s | 180 kB     00:00
(38/266): perl-Benchmark-1.23-481.el9.noarch.rp 511 kB/s |  26 kB     00:00
(39/266): perl-CPAN-2.29-3.el9.noarch.rpm       2.2 MB/s | 557 kB     00:00
(40/266): perl-CPAN-DistnameInfo-0.12-23.el9.no 306 kB/s |  15 kB     00:00
(41/266): perl-CPAN-Meta-2.150010-460.el9.noarc 2.0 MB/s | 202 kB     00:00
(42/266): perl-CPAN-Meta-Requirements-2.140-461 639 kB/s |  32 kB     00:00
(43/266): perl-CPAN-Meta-YAML-0.018-461.el9.noa 533 kB/s |  27 kB     00:00
(44/266): perl-Carp-1.50-460.el9.noarch.rpm     583 kB/s |  30 kB     00:00
(45/266): perl-Class-Struct-0.66-481.el9.noarch 423 kB/s |  22 kB     00:00
(46/266): perl-Compress-Bzip2-2.28-5.el9.x86_64 1.3 MB/s |  70 kB     00:00
(47/266): perl-Compress-Raw-Bzip2-2.101-5.el9.x 699 kB/s |  35 kB     00:00
(48/266): perl-Compress-Raw-Lzma-2.101-3.el9.x8 960 kB/s |  51 kB     00:00
(49/266): perl-Compress-Raw-Zlib-2.101-5.el9.x8 1.2 MB/s |  61 kB     00:00
(50/266): perl-Config-Extensions-0.03-481.el9.n 233 kB/s |  12 kB     00:00
(51/266): perl-Config-Perl-V-0.33-4.el9.noarch. 441 kB/s |  22 kB     00:00
(52/266): perl-DBM_Filter-0.06-481.el9.noarch.r 614 kB/s |  31 kB     00:00
(53/266): perl-DB_File-1.855-4.el9.x86_64.rpm   1.5 MB/s |  82 kB     00:00
(54/266): perl-Data-Dumper-2.174-462.el9.x86_64 1.0 MB/s |  56 kB     00:00
(55/266): perl-Data-OptList-0.110-17.el9.noarch 528 kB/s |  27 kB     00:00
(56/266): perl-Data-Section-0.200007-14.el9.noa 456 kB/s |  26 kB     00:00
(57/266): perl-Devel-PPPort-3.62-4.el9.x86_64.r 2.0 MB/s | 212 kB     00:00
(58/266): perl-Devel-Peek-1.28-481.el9.x86_64.r 548 kB/s |  32 kB     00:00
(59/266): perl-Devel-SelfStubber-1.06-481.el9.n 119 kB/s |  14 kB     00:00
(60/266): perl-Devel-Size-0.83-10.el9.x86_64.rp 637 kB/s |  32 kB     00:00
(61/266): perl-Digest-1.19-4.el9.noarch.rpm     505 kB/s |  26 kB     00:00
(62/266): perl-Digest-MD5-2.58-4.el9.x86_64.rpm 682 kB/s |  37 kB     00:00
(63/266): perl-Digest-SHA-6.02-461.el9.x86_64.r 1.2 MB/s |  62 kB     00:00
(64/266): perl-Digest-SHA1-2.13-34.el9.x86_64.r 1.0 MB/s |  53 kB     00:00
(65/266): perl-DirHandle-1.05-481.el9.noarch.rp 188 kB/s |  12 kB     00:00
(66/266): perl-Dumpvalue-2.27-481.el9.noarch.rp 353 kB/s |  18 kB     00:00
(67/266): perl-DynaLoader-1.47-481.el9.x86_64.r 503 kB/s |  25 kB     00:00
(68/266): perl-Encode-3.08-462.el9.x86_64.rpm   2.5 MB/s | 1.7 MB     00:00
(69/266): perl-Encode-Locale-1.05-21.el9.noarch 387 kB/s |  20 kB     00:00
(70/266): perl-Encode-devel-3.08-462.el9.x86_64 799 kB/s |  42 kB     00:00
(71/266): perl-English-1.11-481.el9.noarch.rpm  256 kB/s |  13 kB     00:00
(72/266): perl-Env-1.04-460.el9.noarch.rpm      387 kB/s |  20 kB     00:00
(73/266): perl-Errno-1.30-481.el9.x86_64.rpm    224 kB/s |  14 kB     00:00
(74/266): perl-Exporter-5.74-461.el9.noarch.rpm 634 kB/s |  32 kB     00:00
(75/266): perl-ExtUtils-CBuilder-0.280236-4.el9 944 kB/s |  49 kB     00:00
(76/266): perl-ExtUtils-Command-7.60-3.el9.noar 284 kB/s |  15 kB     00:00
(77/266): perl-ExtUtils-Constant-0.25-481.el9.n 870 kB/s |  46 kB     00:00
(78/266): perl-ExtUtils-Embed-1.35-481.el9.noar 271 kB/s |  17 kB     00:00
(79/266): perl-ExtUtils-Install-2.20-4.el9.noar 891 kB/s |  45 kB     00:00
(80/266): perl-ExtUtils-MM-Utils-7.60-3.el9.noa 254 kB/s |  13 kB     00:00
(81/266): perl-ExtUtils-MakeMaker-7.60-3.el9.no 2.0 MB/s | 300 kB     00:00
(82/266): perl-ExtUtils-Manifest-1.73-4.el9.noa 689 kB/s |  35 kB     00:00
(83/266): perl-ExtUtils-Miniperl-1.09-481.el9.n 291 kB/s |  15 kB     00:00
(84/266): perl-ExtUtils-ParseXS-3.40-460.el9.no 1.8 MB/s | 186 kB     00:00
(85/266): perl-Fcntl-1.13-481.el9.x86_64.rpm    397 kB/s |  20 kB     00:00
(86/266): perl-File-Basename-2.85-481.el9.noarc 330 kB/s |  17 kB     00:00
(87/266): perl-File-Compare-1.100.600-481.el9.n 255 kB/s |  13 kB     00:00
(88/266): perl-File-Copy-2.34-481.el9.noarch.rp 334 kB/s |  20 kB     00:00
(89/266): perl-File-DosGlob-1.12-481.el9.x86_64 384 kB/s |  19 kB     00:00
(90/266): perl-File-Fetch-1.00-4.el9.noarch.rpm 495 kB/s |  31 kB     00:00
(91/266): perl-File-Find-1.37-481.el9.noarch.rp 496 kB/s |  25 kB     00:00
(92/266): perl-File-HomeDir-1.006-4.el9.noarch. 1.2 MB/s |  60 kB     00:00
(93/266): perl-File-Path-2.18-4.el9.noarch.rpm  712 kB/s |  36 kB     00:00
(94/266): perl-File-Temp-0.231.100-4.el9.noarch 1.2 MB/s |  60 kB     00:00
(95/266): perl-File-Which-1.23-10.el9.noarch.rp 441 kB/s |  22 kB     00:00
(96/266): perl-File-stat-1.09-481.el9.noarch.rp 290 kB/s |  17 kB     00:00
(97/266): perl-FileCache-1.10-481.el9.noarch.rp 271 kB/s |  14 kB     00:00
(98/266): perl-FileHandle-2.03-481.el9.noarch.r 297 kB/s |  15 kB     00:00
(99/266): perl-Filter-1.60-4.el9.x86_64.rpm     1.7 MB/s |  91 kB     00:00
(100/266): perl-Filter-Simple-0.96-460.el9.noar 547 kB/s |  28 kB     00:00
(101/266): perl-FindBin-1.51-481.el9.noarch.rpm 271 kB/s |  14 kB     00:00
(102/266): perl-GDBM_File-1.18-481.el9.x86_64.r 437 kB/s |  22 kB     00:00
(103/266): perl-Getopt-Long-2.52-4.el9.noarch.r 1.2 MB/s |  61 kB     00:00
(104/266): perl-Getopt-Std-1.12-481.el9.noarch. 268 kB/s |  15 kB     00:00
(105/266): perl-HTTP-Tiny-0.076-462.el9.noarch. 1.0 MB/s |  54 kB     00:00
(106/266): perl-Hash-Util-0.23-481.el9.x86_64.r 644 kB/s |  34 kB     00:00
(107/266): perl-Hash-Util-FieldHash-1.20-481.el 752 kB/s |  38 kB     00:00
(108/266): perl-I18N-Collate-1.02-481.el9.noarc 273 kB/s |  14 kB     00:00
(109/266): perl-I18N-LangTags-0.44-481.el9.noar 1.0 MB/s |  54 kB     00:00
(110/266): perl-I18N-Langinfo-0.19-481.el9.x86_ 433 kB/s |  22 kB     00:00
(111/266): perl-IO-1.43-481.el9.x86_64.rpm      1.7 MB/s |  88 kB     00:00
(112/266): perl-IO-Compress-2.102-4.el9.noarch. 1.8 MB/s | 270 kB     00:00
(113/266): perl-IO-Compress-Lzma-2.101-4.el9.no 1.5 MB/s |  78 kB     00:00
(114/266): perl-IO-Socket-IP-0.41-5.el9.noarch. 843 kB/s |  43 kB     00:00
(115/266): perl-IO-Socket-SSL-2.073-2.el9.noarc 2.0 MB/s | 217 kB     00:00
(116/266): perl-IO-Zlib-1.11-4.el9.noarch.rpm   396 kB/s |  20 kB     00:00
(117/266): gcc-11.4.1-3.el9.x86_64.rpm          2.6 MB/s |  32 MB     00:12
(118/266): perl-IPC-Cmd-1.04-461.el9.noarch.rpm 697 kB/s |  40 kB     00:00
(119/266): perl-IPC-Open3-1.21-481.el9.noarch.r 437 kB/s |  22 kB     00:00
(120/266): perl-IPC-SysV-2.09-4.el9.x86_64.rpm  802 kB/s |  43 kB     00:00
(121/266): perl-IPC-System-Simple-1.30-6.el9.no 770 kB/s |  41 kB     00:00
(122/266): perl-Importer-0.026-4.el9.noarch.rpm 769 kB/s |  40 kB     00:00
(123/266): perl-JSON-PP-4.06-4.el9.noarch.rpm   1.3 MB/s |  67 kB     00:00
(124/266): perl-Locale-Maketext-1.29-461.el9.no 1.8 MB/s |  95 kB     00:00
(125/266): perl-Locale-Maketext-Simple-0.21-481 341 kB/s |  17 kB     00:00
(126/266): perl-MIME-Base64-3.16-4.el9.x86_64.r 618 kB/s |  31 kB     00:00
(127/266): perl-MIME-Charset-1.012.2-15.el9.noa 948 kB/s |  49 kB     00:00
(128/266): perl-MRO-Compat-0.13-15.el9.noarch.r 395 kB/s |  20 kB     00:00
(129/266): perl-Math-BigInt-FastCalc-0.500.900- 512 kB/s |  28 kB     00:00
(130/266): perl-Math-BigInt-1.9998.18-460.el9.n 1.9 MB/s | 190 kB     00:00
(131/266): perl-Math-BigRat-0.2614-460.el9.noar 767 kB/s |  39 kB     00:00
(132/266): perl-Math-Complex-1.59-481.el9.noarc 893 kB/s |  46 kB     00:00
(133/266): perl-Memoize-1.03-481.el9.noarch.rpm 1.1 MB/s |  56 kB     00:00
(134/266): perl-Module-CoreList-5.20210320-3.el 1.5 MB/s |  82 kB     00:00
(135/266): perl-Module-CoreList-tools-5.2021032 372 kB/s |  19 kB     00:00
(136/266): perl-Module-Build-0.42.31-9.el9.noar 1.7 MB/s | 263 kB     00:00
(137/266): perl-Module-Load-0.36-4.el9.noarch.r 360 kB/s |  18 kB     00:00
(138/266): perl-Module-Load-Conditional-0.74-4. 462 kB/s |  23 kB     00:00
(139/266): perl-Module-Loaded-0.08-481.el9.noar 237 kB/s |  13 kB     00:00
(140/266): perl-Module-Metadata-1.000037-460.el 699 kB/s |  36 kB     00:00
(141/266): perl-Module-Signature-0.88-1.el9.noa 1.6 MB/s |  84 kB     00:00
(142/266): perl-Mozilla-CA-20200520-6.el9.noarc 260 kB/s |  13 kB     00:00
(143/266): perl-NDBM_File-1.15-481.el9.x86_64.r 435 kB/s |  22 kB     00:00
(144/266): perl-NEXT-0.67-481.el9.noarch.rpm    403 kB/s |  21 kB     00:00
(145/266): perl-Net-1.02-481.el9.noarch.rpm     431 kB/s |  25 kB     00:00
(146/266): perl-Net-Ping-2.74-5.el9.noarch.rpm  998 kB/s |  50 kB     00:00
(147/266): perl-ODBM_File-1.16-481.el9.x86_64.r 433 kB/s |  22 kB     00:00
(148/266): perl-Object-HashBase-0.009-7.el9.noa 527 kB/s |  26 kB     00:00
(149/266): perl-Opcode-1.48-481.el9.x86_64.rpm  698 kB/s |  36 kB     00:00
(150/266): perl-Net-SSLeay-1.94-1.el9.x86_64.rp 2.1 MB/s | 414 kB     00:00
(151/266): perl-POSIX-1.94-481.el9.x86_64.rpm   1.8 MB/s |  96 kB     00:00
(152/266): perl-Package-Generator-1.106-23.el9. 481 kB/s |  24 kB     00:00
(153/266): perl-Params-Check-0.38-461.el9.noarc 368 kB/s |  23 kB     00:00
(154/266): perl-Params-Util-1.102-5.el9.x86_64. 658 kB/s |  34 kB     00:00
(155/266): perl-PathTools-3.78-461.el9.x86_64.r 1.7 MB/s |  88 kB     00:00
(156/266): perl-Perl-OSType-1.010-461.el9.noarc 448 kB/s |  24 kB     00:00
(157/266): perl-PerlIO-via-QuotedPrint-0.09-4.e 418 kB/s |  23 kB     00:00
(158/266): perl-Pod-Checker-1.74-4.el9.noarch.r 565 kB/s |  33 kB     00:00
(159/266): perl-Pod-Escapes-1.07-460.el9.noarch 409 kB/s |  21 kB     00:00
(160/266): perl-Pod-Functions-1.13-481.el9.noar 267 kB/s |  13 kB     00:00
(161/266): perl-Pod-Html-1.25-481.el9.noarch.rp 504 kB/s |  26 kB     00:00
(162/266): perl-Pod-Perldoc-3.28.01-461.el9.noa 1.7 MB/s |  87 kB     00:00
(163/266): perl-Pod-Usage-2.01-4.el9.noarch.rpm 818 kB/s |  41 kB     00:00
(164/266): perl-Pod-Simple-3.42-4.el9.noarch.rp 2.2 MB/s | 225 kB     00:00
(165/266): perl-Safe-2.41-481.el9.noarch.rpm    484 kB/s |  25 kB     00:00
(166/266): perl-Scalar-List-Utils-1.56-462.el9. 1.4 MB/s |  71 kB     00:00
(167/266): perl-Search-Dict-1.07-481.el9.noarch 255 kB/s |  13 kB     00:00
(168/266): perl-SelectSaver-1.02-481.el9.noarch 208 kB/s |  11 kB     00:00
(169/266): perl-SelfLoader-1.26-481.el9.noarch. 421 kB/s |  21 kB     00:00
(170/266): perl-Socket-2.031-4.el9.x86_64.rpm   997 kB/s |  56 kB     00:00
(171/266): perl-Software-License-0.103014-12.el 1.3 MB/s | 140 kB     00:00
(172/266): perl-Storable-3.21-460.el9.x86_64.rp 1.8 MB/s |  96 kB     00:00
(173/266): perl-Sub-Exporter-0.987-27.el9.noarc 1.3 MB/s |  73 kB     00:00
(174/266): perl-Sub-Install-0.928-28.el9.noarch 434 kB/s |  23 kB     00:00
(175/266): perl-Symbol-1.08-481.el9.noarch.rpm  262 kB/s |  14 kB     00:00
(176/266): perl-Sys-Hostname-1.23-481.el9.x86_6 319 kB/s |  17 kB     00:00
(177/266): perl-Sys-Syslog-0.36-461.el9.x86_64. 892 kB/s |  48 kB     00:00
(178/266): perl-Term-ANSIColor-5.01-461.el9.noa 890 kB/s |  49 kB     00:00
(179/266): perl-Term-Cap-1.17-460.el9.noarch.rp 442 kB/s |  23 kB     00:00
(180/266): perl-Term-Complete-1.403-481.el9.noa 250 kB/s |  13 kB     00:00
(181/266): perl-Term-ReadLine-1.17-481.el9.noar 358 kB/s |  19 kB     00:00
(182/266): perl-Term-Size-Any-0.002-35.el9.noar 269 kB/s |  14 kB     00:00
(183/266): perl-Term-Size-Perl-0.031-12.el9.x86 430 kB/s |  22 kB     00:00
(184/266): perl-Term-Table-0.015-8.el9.noarch.r 699 kB/s |  36 kB     00:00
(185/266): perl-TermReadKey-2.38-11.el9.x86_64. 710 kB/s |  37 kB     00:00
(186/266): perl-Test-1.31-481.el9.noarch.rpm    541 kB/s |  28 kB     00:00
(187/266): perl-Test-Harness-3.42-461.el9.noarc 1.9 MB/s | 295 kB     00:00
(188/266): perl-Text-Abbrev-1.02-481.el9.noarch 201 kB/s |  12 kB     00:00
(189/266): perl-Test-Simple-1.302183-4.el9.noar 2.5 MB/s | 626 kB     00:00
(190/266): perl-Text-Balanced-2.04-4.el9.noarch 938 kB/s |  48 kB     00:00
(191/266): perl-Text-Diff-1.45-13.el9.noarch.rp 820 kB/s |  42 kB     00:00
(192/266): perl-Text-Glob-0.11-15.el9.noarch.rp 283 kB/s |  14 kB     00:00
(193/266): perl-Text-ParseWords-3.30-460.el9.no 332 kB/s |  17 kB     00:00
(194/266): perl-Text-Tabs+Wrap-2013.0523-460.el 381 kB/s |  24 kB     00:00
(195/266): perl-Text-Template-1.59-5.el9.noarch 1.1 MB/s |  61 kB     00:00
(196/266): perl-Thread-3.05-481.el9.noarch.rpm  327 kB/s |  18 kB     00:00
(197/266): perl-Thread-Queue-3.14-460.el9.noarc 392 kB/s |  22 kB     00:00
(198/266): perl-Thread-Semaphore-2.13-481.el9.n 304 kB/s |  15 kB     00:00
(199/266): perl-Tie-4.6-481.el9.noarch.rpm      615 kB/s |  31 kB     00:00
(200/266): perl-Tie-File-1.06-481.el9.noarch.rp 739 kB/s |  43 kB     00:00
(201/266): perl-Tie-Memoize-1.1-481.el9.noarch. 271 kB/s |  14 kB     00:00
(202/266): perl-Tie-RefHash-1.40-4.el9.noarch.r 471 kB/s |  24 kB     00:00
(203/266): perl-Time-1.03-481.el9.noarch.rpm    337 kB/s |  18 kB     00:00
(204/266): perl-Time-HiRes-1.9764-462.el9.x86_6 1.1 MB/s |  58 kB     00:00
(205/266): perl-Time-Local-1.300-7.el9.noarch.r 680 kB/s |  34 kB     00:00
(206/266): perl-Time-Piece-1.3401-481.el9.x86_6 781 kB/s |  40 kB     00:00
(207/266): perl-URI-5.09-3.el9.noarch.rpm       2.1 MB/s | 121 kB     00:00
(208/266): perl-Unicode-LineBreak-2019.001-11.e 2.3 MB/s | 125 kB     00:00
(209/266): perl-Unicode-Normalize-1.27-461.el9. 1.7 MB/s |  91 kB     00:00
(210/266): perl-Unicode-UCD-0.75-481.el9.noarch 1.4 MB/s |  78 kB     00:00
(211/266): perl-User-pwent-1.03-481.el9.noarch. 402 kB/s |  20 kB     00:00
(212/266): perl-Unicode-Collate-1.29-4.el9.x86_ 2.5 MB/s | 760 kB     00:00
(213/266): perl-autodie-2.34-4.el9.noarch.rpm   1.8 MB/s |  97 kB     00:00
(214/266): perl-autouse-1.11-481.el9.noarch.rpm 261 kB/s |  13 kB     00:00
(215/266): perl-base-2.27-481.el9.noarch.rpm    306 kB/s |  16 kB     00:00
(216/266): perl-bignum-0.51-460.el9.noarch.rpm  856 kB/s |  43 kB     00:00
(217/266): perl-blib-1.07-481.el9.noarch.rpm    237 kB/s |  12 kB     00:00
(218/266): perl-constant-1.33-461.el9.noarch.rp 471 kB/s |  24 kB     00:00
(219/266): perl-deprecate-0.04-481.el9.noarch.r 283 kB/s |  14 kB     00:00
(220/266): perl-debugger-1.56-481.el9.noarch.rp 1.3 MB/s | 133 kB     00:00
(221/266): perl-diagnostics-1.37-481.el9.noarch 1.9 MB/s | 210 kB     00:00
(222/266): perl-devel-5.32.1-481.el9.x86_64.rpm 2.3 MB/s | 676 kB     00:00
(223/266): perl-encoding-3.00-462.el9.x86_64.rp 1.2 MB/s |  63 kB     00:00
(224/266): perl-encoding-warnings-0.13-481.el9. 316 kB/s |  16 kB     00:00
(225/266): perl-experimental-0.022-6.el9.noarch 440 kB/s |  22 kB     00:00
(226/266): perl-fields-2.27-481.el9.noarch.rpm  307 kB/s |  16 kB     00:00
(227/266): perl-filetest-1.03-481.el9.noarch.rp 263 kB/s |  14 kB     00:00
(228/266): perl-if-0.60.800-481.el9.noarch.rpm  270 kB/s |  14 kB     00:00
(229/266): perl-inc-latest-0.500-20.el9.noarch. 488 kB/s |  25 kB     00:00
(230/266): perl-interpreter-5.32.1-481.el9.x86_ 1.3 MB/s |  71 kB     00:00
(231/266): perl-less-0.03-481.el9.noarch.rpm    249 kB/s |  13 kB     00:00
(232/266): perl-lib-0.65-481.el9.x86_64.rpm     286 kB/s |  14 kB     00:00
(233/266): perl-libnet-3.13-4.el9.noarch.rpm    1.3 MB/s | 130 kB     00:00
(234/266): perl-libnetcfg-5.32.1-481.el9.noarch 310 kB/s |  16 kB     00:00
(235/266): perl-libs-5.32.1-481.el9.x86_64.rpm  2.5 MB/s | 2.2 MB     00:00
(236/266): perl-local-lib-2.000024-13.el9.noarc 1.2 MB/s |  68 kB     00:00
(237/266): perl-doc-5.32.1-481.el9.noarch.rpm   2.5 MB/s | 4.6 MB     00:01
(238/266): perl-locale-1.09-481.el9.noarch.rpm  258 kB/s |  13 kB     00:00
(239/266): perl-macros-5.32.1-481.el9.noarch.rp 205 kB/s |  10 kB     00:00
(240/266): perl-meta-notation-5.32.1-481.el9.no 186 kB/s | 9.3 kB     00:00
(241/266): perl-mro-1.23-481.el9.x86_64.rpm     554 kB/s |  28 kB     00:00
(242/266): perl-open-1.12-481.el9.noarch.rpm    321 kB/s |  16 kB     00:00
(243/266): perl-overload-1.31-481.el9.noarch.rp 879 kB/s |  45 kB     00:00
(244/266): perl-overloading-0.02-481.el9.noarch 246 kB/s |  12 kB     00:00
(245/266): perl-parent-0.238-460.el9.noarch.rpm 298 kB/s |  15 kB     00:00
(246/266): perl-ph-5.32.1-481.el9.x86_64.rpm    859 kB/s |  44 kB     00:00
(247/266): perl-perlfaq-5.20201107-4.el9.noarch 2.4 MB/s | 375 kB     00:00
(248/266): perl-podlators-4.14-460.el9.noarch.r 1.9 MB/s | 114 kB     00:00
(249/266): perl-sigtrap-1.09-481.el9.noarch.rpm 299 kB/s |  15 kB     00:00
(250/266): perl-sort-2.04-481.el9.noarch.rpm    261 kB/s |  13 kB     00:00
(251/266): perl-srpm-macros-1-41.el9.noarch.rpm 185 kB/s | 9.1 kB     00:00
(252/266): perl-subs-1.03-481.el9.noarch.rpm    226 kB/s |  11 kB     00:00
(253/266): perl-threads-2.25-460.el9.x86_64.rpm 1.1 MB/s |  58 kB     00:00
(254/266): perl-threads-shared-1.61-460.el9.x86 877 kB/s |  45 kB     00:00
(255/266): perl-utils-5.32.1-481.el9.noarch.rpm 1.0 MB/s |  55 kB     00:00
(256/266): perl-vars-1.05-481.el9.noarch.rpm    242 kB/s |  13 kB     00:00
(257/266): perl-version-0.99.28-4.el9.x86_64.rp 1.2 MB/s |  63 kB     00:00
(258/266): perl-vmsish-1.04-481.el9.noarch.rpm  261 kB/s |  14 kB     00:00
(259/266): pyproject-srpm-macros-1.12.0-1.el9.n 268 kB/s |  14 kB     00:00
(260/266): python-srpm-macros-3.9-54.el9.noarch 338 kB/s |  18 kB     00:00
(261/266): qt5-srpm-macros-5.15.9-1.el9.noarch. 171 kB/s | 8.8 kB     00:00
(262/266): redhat-rpm-config-207-1.el9.noarch.r 1.4 MB/s |  72 kB     00:00
(263/266): rust-srpm-macros-17-4.el9.noarch.rpm 205 kB/s |  10 kB     00:00
(264/266): sombok-2.4.0-16.el9.x86_64.rpm       931 kB/s |  48 kB     00:00
(265/266): systemtap-sdt-devel-5.1-3.el9.x86_64 1.3 MB/s |  75 kB     00:00
(266/266): llvm-libs-18.1.6-3.el9.x86_64.rpm    2.6 MB/s |  50 MB     00:19
Total                                           5.3 MB/s | 137 MB     00:25
Mail2GoCa
Post by Mail2GoCa »
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
  Preparing        :                                                        1/1
  Installing       : perl-Digest-1.19-4.el9.noarch                        1/266
  Installing       : perl-Digest-MD5-2.58-4.el9.x86_64                    2/266
  Installing       : perl-B-1.80-481.el9.x86_64                           3/266
  Installing       : perl-FileHandle-2.03-481.el9.noarch                  4/266
  Installing       : perl-Data-Dumper-2.174-462.el9.x86_64                5/266
  Installing       : perl-libnet-3.13-4.el9.noarch                        6/266
  Installing       : perl-Class-Struct-0.66-481.el9.noarch                7/266
  Installing       : perl-base-2.27-481.el9.noarch                        8/266
  Installing       : perl-URI-5.09-3.el9.noarch                           9/266
  Installing       : perl-AutoLoader-5.74-481.el9.noarch                 10/266
  Installing       : perl-POSIX-1.94-481.el9.x86_64                      11/266
  Installing       : perl-Socket-4:2.031-4.el9.x86_64                    12/266
  Installing       : perl-SelectSaver-1.02-481.el9.noarch                13/266
  Installing       : perl-Term-ANSIColor-5.01-461.el9.noarch             14/266
  Installing       : perl-Mozilla-CA-20200520-6.el9.noarch               15/266
  Installing       : perl-if-0.60.800-481.el9.noarch                     16/266
  Installing       : perl-mro-1.23-481.el9.x86_64                        17/266
  Installing       : perl-IO-Socket-IP-0.41-5.el9.noarch                 18/266
  Installing       : perl-File-stat-1.09-481.el9.noarch                  19/266
  Installing       : perl-overloading-0.02-481.el9.noarch                20/266
  Installing       : perl-Time-Local-2:1.300-7.el9.noarch                21/266
  Installing       : perl-subs-1.03-481.el9.noarch                       22/266
  Installing       : perl-File-Path-2.18-4.el9.noarch                    23/266
  Installing       : perl-Pod-Escapes-1:1.07-460.el9.noarch              24/266
  Installing       : perl-Term-Cap-1.17-460.el9.noarch                   25/266
  Installing       : perl-Text-Tabs+Wrap-2013.0523-460.el9.noarch        26/266
  Installing       : perl-Pod-Usage-4:2.01-4.el9.noarch                  27/266
  Installing       : perl-IO-Socket-SSL-2.073-2.el9.noarch               28/266
  Installing       : perl-Net-SSLeay-1.94-1.el9.x86_64                   29/266
  Installing       : perl-Errno-1.30-481.el9.x86_64                      30/266
  Installing       : perl-Fcntl-1.13-481.el9.x86_64                      31/266
  Installing       : perl-File-Basename-2.85-481.el9.noarch              32/266
  Installing       : perl-Getopt-Std-1.12-481.el9.noarch                 33/266
  Installing       : perl-MIME-Base64-3.16-4.el9.x86_64                  34/266
  Installing       : perl-Scalar-List-Utils-4:1.56-462.el9.x86_64        35/266
  Installing       : perl-Symbol-1.08-481.el9.noarch                     36/266
  Installing       : perl-Text-ParseWords-3.30-460.el9.noarch            37/266
  Installing       : perl-constant-1.33-461.el9.noarch                   38/266
  Installing       : perl-IPC-Open3-1.21-481.el9.noarch                  39/266
  Installing       : perl-Storable-1:3.21-460.el9.x86_64                 40/266
  Installing       : perl-IO-1.43-481.el9.x86_64                         41/266
  Installing       : perl-overload-1.31-481.el9.noarch                   42/266
  Installing       : perl-parent-1:0.238-460.el9.noarch                  43/266
  Installing       : perl-File-Temp-1:0.231.100-4.el9.noarch             44/266
  Installing       : perl-vars-1.05-481.el9.noarch                       45/266
  Installing       : perl-Pod-Simple-1:3.42-4.el9.noarch                 46/266
  Installing       : perl-Getopt-Long-1:2.52-4.el9.noarch                47/266
  Installing       : perl-podlators-1:4.14-460.el9.noarch                48/266
  Installing       : perl-HTTP-Tiny-0.076-462.el9.noarch                 49/266
  Installing       : perl-Carp-1.50-460.el9.noarch                       50/266
  Installing       : perl-Exporter-5.74-461.el9.noarch                   51/266
  Installing       : perl-GDBM_File-1.18-481.el9.x86_64                  52/266
  Installing       : perl-NDBM_File-1.15-481.el9.x86_64                  53/266
  Installing       : perl-ODBM_File-1.16-481.el9.x86_64                  54/266
  Installing       : perl-DB_File-1.855-4.el9.x86_64                     55/266
  Installing       : perl-PathTools-3.78-461.el9.x86_64                  56/266
  Installing       : perl-Encode-4:3.08-462.el9.x86_64                   57/266
  Installing       : perl-libs-4:5.32.1-481.el9.x86_64                   58/266
  Installing       : perl-Pod-Perldoc-3.28.01-461.el9.noarch             59/266
  Installing       : perl-doc-5.32.1-481.el9.noarch                      60/266
  Installing       : perl-interpreter-4:5.32.1-481.el9.x86_64            61/266
  Installing       : perl-File-Find-1.37-481.el9.noarch                  62/266
  Installing       : perl-File-Copy-2.34-481.el9.noarch                  63/266
  Installing       : perl-ExtUtils-Manifest-1:1.73-4.el9.noarch          64/266
  Installing       : perl-DynaLoader-1.47-481.el9.x86_64                 65/266
  Installing       : perl-Time-HiRes-4:1.9764-462.el9.x86_64             66/266
  Installing       : perl-ExtUtils-ParseXS-1:3.40-460.el9.noarch         67/266
  Installing       : perl-Compress-Raw-Zlib-2.101-5.el9.x86_64           68/266
  Installing       : perl-File-Compare-1.100.600-481.el9.noarch          69/266
  Installing       : perl-lib-0.65-481.el9.x86_64                        70/266
  Installing       : perl-threads-1:2.25-460.el9.x86_64                  71/266
  Installing       : perl-threads-shared-1.61-460.el9.x86_64             72/266
  Installing       : perl-Digest-SHA-1:6.02-461.el9.x86_64               73/266
  Installing       : perl-Devel-Peek-1.28-481.el9.x86_64                 74/266
  Installing       : perl-Module-Load-1:0.36-4.el9.noarch                75/266
  Installing       : perl-Perl-OSType-1.010-461.el9.noarch               76/266
  Installing       : perl-Term-ReadLine-1.17-481.el9.noarch              77/266
  Installing       : perl-Tie-4.6-481.el9.noarch                         78/266
  Installing       : perl-Unicode-Normalize-1.27-461.el9.x86_64          79/266
  Installing       : perl-locale-1.09-481.el9.noarch                     80/266
  Installing       : perl-version-7:0.99.28-4.el9.x86_64                 81/266
  Installing       : perl-CPAN-Meta-Requirements-2.140-461.el9.noarch    82/266
  Installing       : perl-Module-CoreList-1:5.20210320-3.el9.noarch      83/266
  Installing       : perl-Module-Metadata-1.000037-460.el9.noarch        84/266
  Installing       : perl-meta-notation-5.32.1-481.el9.noarch            85/266
  Installing       : libmpc-1.2.1-4.el9.x86_64                           86/266
  Installing       : perl-Pod-Html-1.25-481.el9.noarch                   87/266
  Installing       : perl-Dumpvalue-2.27-481.el9.noarch                  88/266
  Installing       : perl-Net-Ping-2.74-5.el9.noarch                     89/266
  Installing       : perl-TermReadKey-2.38-11.el9.x86_64                 90/266
  Installing       : perl-ExtUtils-Command-2:7.60-3.el9.noarch           91/266
  Installing       : perl-AutoSplit-5.74-481.el9.noarch                  92/266
  Installing       : perl-Benchmark-1.23-481.el9.noarch                  93/266
  Installing       : perl-Test-Harness-1:3.42-461.el9.noarch             94/266
  Installing       : perl-CPAN-Meta-YAML-0.018-461.el9.noarch            95/266
  Installing       : perl-Compress-Raw-Bzip2-2.101-5.el9.x86_64          96/266
  Installing       : perl-IO-Compress-2.102-4.el9.noarch                 97/266
  Installing       : perl-IO-Zlib-1:1.11-4.el9.noarch                    98/266
  Installing       : perl-Devel-PPPort-3.62-4.el9.x86_64                 99/266
  Installing       : perl-DirHandle-1.05-481.el9.noarch                 100/266
  Installing       : perl-ExtUtils-Constant-0.25-481.el9.noarch         101/266
  Installing       : perl-ExtUtils-MM-Utils-2:7.60-3.el9.noarch         102/266
  Installing       : perl-Hash-Util-FieldHash-1.20-481.el9.x86_64       103/266
  Installing       : perl-Hash-Util-0.23-481.el9.x86_64                 104/266
  Installing       : perl-I18N-LangTags-0.44-481.el9.noarch             105/266
  Installing       : perl-Locale-Maketext-1.29-461.el9.noarch           106/266
  Installing       : perl-Locale-Maketext-Simple-1:0.21-481.el9.noarc   107/266
  Installing       : perl-Params-Check-1:0.38-461.el9.noarch            108/266
  Installing       : perl-Module-Load-Conditional-0.74-4.el9.noarch     109/266
  Installing       : perl-IPC-Cmd-2:1.04-461.el9.noarch                 110/266
  Installing       : perl-I18N-Langinfo-0.19-481.el9.x86_64             111/266
  Installing       : perl-Math-Complex-1.59-481.el9.noarch              112/266
  Installing       : perl-Math-BigInt-1:1.9998.18-460.el9.noarch        113/266
  Installing       : perl-JSON-PP-1:4.06-4.el9.noarch                   114/266
  Installing       : perl-CPAN-Meta-2.150010-460.el9.noarch             115/266
  Installing       : perl-Math-BigRat-0.2614-460.el9.noarch             116/266
  Installing       : perl-Opcode-1.48-481.el9.x86_64                    117/266
  Installing       : perl-Safe-2.41-481.el9.noarch                      118/266
  Installing       : perl-Params-Util-1.102-5.el9.x86_64                119/266
  Installing       : perl-SelfLoader-1.26-481.el9.noarch                120/266
  Installing       : perl-Sub-Install-0.928-28.el9.noarch               121/266
  Installing       : perl-Sys-Hostname-1.23-481.el9.x86_64              122/266
  Installing       : perl-Text-Balanced-2.04-4.el9.noarch               123/266
  Installing       : perl-Tie-RefHash-1.40-4.el9.noarch                 124/266
  Installing       : perl-User-pwent-1.03-481.el9.noarch                125/266
  Installing       : perl-autouse-1.11-481.el9.noarch                   126/266
  Installing       : make-1:4.3-8.el9.x86_64                            127/266
  Installing       : perl-Data-OptList-0.110-17.el9.noarch              128/266
  Installing       : perl-Devel-SelfStubber-1.06-481.el9.noarch         129/266
  Installing       : perl-bignum-0.51-460.el9.noarch                    130/266
  Installing       : perl-Math-BigInt-FastCalc-0.500.900-460.el9.x86_   131/266
  Installing       : perl-Encode-Locale-1.05-21.el9.noarch              132/266
  Installing       : perl-File-Fetch-1.00-4.el9.noarch                  133/266
  Installing       : perl-fields-2.27-481.el9.noarch                    134/266
  Installing       : perl-DBM_Filter-0.06-481.el9.noarch                135/266
  Installing       : cpp-11.4.1-3.el9.x86_64                            136/266
  Installing       : perl-debugger-1.56-481.el9.noarch                  137/266
  Installing       : perl-sigtrap-1.09-481.el9.noarch                   138/266
  Installing       : perl-Module-CoreList-tools-1:5.20210320-3.el9.no   139/266
  Installing       : perl-experimental-0.022-6.el9.noarch               140/266
  Installing       : perl-Unicode-Collate-1.29-4.el9.x86_64             141/266
  Installing       : perl-Unicode-UCD-0.75-481.el9.noarch               142/266
  Installing       : perl-Env-1.04-460.el9.noarch                       143/266
  Installing       : perl-Thread-3.05-481.el9.noarch                    144/266
  Installing       : perl-Thread-Queue-3.14-460.el9.noarch              145/266
  Installing       : perl-Thread-Semaphore-2.13-481.el9.noarch          146/266
  Installing       : perl-Archive-Zip-1.68-6.el9.noarch                 147/266
  Installing       : perl-Digest-SHA1-2.13-34.el9.x86_64                148/266
  Installing       : kernel-srpm-macros-1.0-13.el9.noarch               149/266
  Installing       : perl-Pod-Checker-4:1.74-4.el9.noarch               150/266
  Installing       : perl-diagnostics-1.37-481.el9.noarch               151/266
  Installing       : perl-macros-4:5.32.1-481.el9.noarch                152/266
  Installing       : perl-utils-5.32.1-481.el9.noarch                   153/266
  Installing       : perl-Algorithm-Diff-1.2010-4.el9.noarch            154/266
  Installing       : perl-Text-Diff-1.45-13.el9.noarch                  155/266
  Installing       : perl-Module-Signature-0.88-1.el9.noarch            156/266
  Installing       : perl-Attribute-Handlers-1.01-481.el9.noarch        157/266
  Installing       : perl-CPAN-DistnameInfo-0.12-23.el9.noarch          158/266
  Installing       : perl-Compress-Bzip2-2.28-5.el9.x86_64              159/266
  Installing       : perl-Compress-Raw-Lzma-2.101-3.el9.x86_64          160/266
  Installing       : perl-IO-Compress-Lzma-2.101-4.el9.noarch           161/266
  Installing       : perl-Archive-Tar-2.38-6.el9.noarch                 162/266
  Installing       : perl-Config-Extensions-0.03-481.el9.noarch         163/266
  Installing       : perl-Config-Perl-V-0.33-4.el9.noarch               164/266
  Installing       : perl-Devel-Size-0.83-10.el9.x86_64                 165/266
  Installing       : perl-English-1.11-481.el9.noarch                   166/266
  Installing       : perl-File-DosGlob-1.12-481.el9.x86_64              167/266
  Installing       : perl-File-Which-1.23-10.el9.noarch                 168/266
  Installing       : perl-File-HomeDir-1.006-4.el9.noarch               169/266
  Installing       : perl-FileCache-1.10-481.el9.noarch                 170/266
  Installing       : perl-FindBin-1.51-481.el9.noarch                   171/266
  Installing       : perl-I18N-Collate-1.02-481.el9.noarch              172/266
  Installing       : perl-IPC-SysV-2.09-4.el9.x86_64                    173/266
  Installing       : perl-IPC-System-Simple-1.30-6.el9.noarch           174/266
  Installing       : perl-autodie-2.34-4.el9.noarch                     175/266
  Installing       : perl-Importer-0.026-4.el9.noarch                   176/266
  Installing       : perl-MIME-Charset-1.012.2-15.el9.noarch            177/266
  Installing       : perl-MRO-Compat-0.13-15.el9.noarch                 178/266
  Installing       : perl-Memoize-1.03-481.el9.noarch                   179/266
  Installing       : perl-Module-Loaded-1:0.08-481.el9.noarch           180/266
  Installing       : perl-NEXT-0.67-481.el9.noarch                      181/266
  Installing       : perl-Net-1.02-481.el9.noarch                       182/266
  Installing       : perl-Object-HashBase-0.009-7.el9.noarch            183/266
  Installing       : perl-Package-Generator-1.106-23.el9.noarch         184/266
  Installing       : perl-Sub-Exporter-0.987-27.el9.noarch              185/266
  Installing       : perl-Data-Section-0.200007-14.el9.noarch           186/266
  Installing       : perl-PerlIO-via-QuotedPrint-0.09-4.el9.noarch      187/266
  Installing       : perl-Pod-Functions-1.13-481.el9.noarch             188/266
  Installing       : perl-Search-Dict-1.07-481.el9.noarch               189/266
  Installing       : perl-Sys-Syslog-0.36-461.el9.x86_64                190/266
  Installing       : perl-Term-Complete-1.403-481.el9.noarch            191/266
  Installing       : perl-Term-Size-Perl-0.031-12.el9.x86_64            192/266
  Installing       : perl-Term-Size-Any-0.002-35.el9.noarch             193/266
  Installing       : perl-Test-1.31-481.el9.noarch                      194/266
  Installing       : perl-Text-Abbrev-1.02-481.el9.noarch               195/266
  Installing       : perl-Text-Glob-0.11-15.el9.noarch                  196/266
  Installing       : perl-Text-Template-1.59-5.el9.noarch               197/266
  Installing       : perl-Software-License-0.103014-12.el9.noarch       198/266
  Installing       : perl-Tie-File-1.06-481.el9.noarch                  199/266
  Installing       : perl-Tie-Memoize-1.1-481.el9.noarch                200/266
  Installing       : perl-Time-1.03-481.el9.noarch                      201/266
  Installing       : perl-Time-Piece-1.3401-481.el9.x86_64              202/266
  Installing       : perl-blib-1.07-481.el9.noarch                      203/266
  Installing       : perl-deprecate-0.04-481.el9.noarch                 204/266
  Installing       : perl-encoding-warnings-0.13-481.el9.noarch         205/266
  Installing       : perl-filetest-1.03-481.el9.noarch                  206/266
  Installing       : perl-less-0.03-481.el9.noarch                      207/266
  Installing       : perl-local-lib-2.000024-13.el9.noarch              208/266
  Installing       : perl-perlfaq-5.20201107-4.el9.noarch               209/266
  Installing       : perl-ph-5.32.1-481.el9.x86_64                      210/266
  Installing       : perl-sort-2.04-481.el9.noarch                      211/266
  Installing       : perl-vmsish-1.04-481.el9.noarch                    212/266
  Installing       : rust-srpm-macros-17-4.el9.noarch                   213/266
  Installing       : qt5-srpm-macros-5.15.9-1.el9.noarch                214/266
  Installing       : pyproject-srpm-macros-1.12.0-1.el9.noarch          215/266
  Installing       : perl-srpm-macros-1-41.el9.noarch                   216/266
  Installing       : openblas-srpm-macros-2-11.el9.noarch               217/266
  Installing       : ocaml-srpm-macros-6-6.el9.noarch                   218/266
  Installing       : lua-srpm-macros-1-6.el9.noarch                     219/266
  Installing       : llvm-libs-18.1.6-3.el9.x86_64                      220/266
  Installing       : libstdc++-devel-11.4.1-3.el9.x86_64                221/266
  Installing       : libdatrie-0.2.13-4.el9.x86_64                      222/266
  Installing       : libthai-0.1.28-8.el9.x86_64                        223/266
  Installing       : sombok-2.4.0-16.el9.x86_64                         224/266
  Installing       : perl-Unicode-LineBreak-2019.001-11.el9.x86_64      225/266
  Installing       : perl-Term-Table-0.015-8.el9.noarch                 226/266
  Installing       : perl-Test-Simple-3:1.302183-4.el9.noarch           227/266
  Installing       : kernel-headers-5.14.0-474.el9.x86_64               228/266
  Installing       : glibc-headers-2.34-113.el9.x86_64                  229/266
  Installing       : ghc-srpm-macros-1.5.0-6.el9.noarch                 230/266
  Installing       : efi-srpm-macros-4-9.el9.noarch                     231/266
  Installing       : dwz-0.14-3.el9.x86_64                              232/266
  Installing       : unzip-6.0-56.el9.x86_64                            233/266
  Installing       : zip-3.0-35.el9.x86_64                              234/266
  Installing       : python3-pyparsing-2.4.7-9.el9.noarch               235/266
  Installing       : systemtap-sdt-devel-5.1-3.el9.x86_64               236/266
  Installing       : pkgconf-m4-1.7.3-10.el9.noarch                     237/266
  Installing       : libpkgconf-1.7.3-10.el9.x86_64                     238/266
  Installing       : pkgconf-1.7.3-10.el9.x86_64                        239/266
  Installing       : pkgconf-pkg-config-1.7.3-10.el9.x86_64             240/266
  Installing       : glibc-devel-2.34-113.el9.x86_64                    241/266
  Installing       : libxcrypt-devel-4.4.18-3.el9.x86_64                242/266
  Installing       : gcc-11.4.1-3.el9.x86_64                            243/266
  Installing       : perl-Filter-2:1.60-4.el9.x86_64                    244/266
  Installing       : perl-encoding-4:3.00-462.el9.x86_64                245/266
  Installing       : perl-open-1.12-481.el9.noarch                      246/266
  Installing       : perl-Filter-Simple-0.96-460.el9.noarch             247/266
  Installing       : annobin-12.31-2.el9.x86_64                         248/266
  Installing       : gcc-c++-11.4.1-3.el9.x86_64                        249/266
  Installing       : gcc-plugin-annobin-11.4.1-3.el9.x86_64             250/266
  Installing       : fonts-srpm-macros-1:2.0.5-7.el9.1.noarch           251/266
  Installing       : go-srpm-macros-3.2.0-3.el9.noarch                  252/266
  Installing       : python-srpm-macros-3.9-54.el9.noarch               253/266
  Installing       : redhat-rpm-config-207-1.el9.noarch                 254/266
  Running scriptlet: redhat-rpm-config-207-1.el9.noarch                 254/266
  Installing       : perl-ExtUtils-Install-2.20-4.el9.noarch            255/266
  Installing       : perl-devel-4:5.32.1-481.el9.x86_64                 256/266
  Installing       : perl-ExtUtils-MakeMaker-2:7.60-3.el9.noarch        257/266
  Installing       : perl-ExtUtils-CBuilder-1:0.280236-4.el9.noarch     258/266
  Installing       : perl-ExtUtils-Embed-1.35-481.el9.noarch            259/266
  Installing       : perl-ExtUtils-Miniperl-1.09-481.el9.noarch         260/266
  Installing       : perl-libnetcfg-4:5.32.1-481.el9.noarch             261/266
  Installing       : perl-Encode-devel-4:3.08-462.el9.x86_64            262/266
  Installing       : perl-inc-latest-2:0.500-20.el9.noarch              263/266
  Installing       : perl-Module-Build-2:0.42.31-9.el9.noarch           264/266
  Installing       : perl-CPAN-2.29-3.el9.noarch                        265/266
  Installing       : perl-4:5.32.1-481.el9.x86_64                       266/266
  Running scriptlet: perl-4:5.32.1-481.el9.x86_64                       266/266
  Verifying        : libpkgconf-1.7.3-10.el9.x86_64                       1/266
  Verifying        : make-1:4.3-8.el9.x86_64                              2/266
  Verifying        : pkgconf-1.7.3-10.el9.x86_64                          3/266
  Verifying        : pkgconf-m4-1.7.3-10.el9.noarch                       4/266
  Verifying        : pkgconf-pkg-config-1.7.3-10.el9.x86_64               5/266
  Verifying        : python3-pyparsing-2.4.7-9.el9.noarch                 6/266
  Verifying        : unzip-6.0-56.el9.x86_64                              7/266
  Verifying        : zip-3.0-35.el9.x86_64                                8/266
  Verifying        : annobin-12.31-2.el9.x86_64                           9/266
  Verifying        : cpp-11.4.1-3.el9.x86_64                             10/266
  Verifying        : dwz-0.14-3.el9.x86_64                               11/266
  Verifying        : efi-srpm-macros-4-9.el9.noarch                      12/266
  Verifying        : fonts-srpm-macros-1:2.0.5-7.el9.1.noarch            13/266
  Verifying        : gcc-11.4.1-3.el9.x86_64                             14/266
  Verifying        : gcc-c++-11.4.1-3.el9.x86_64                         15/266
  Verifying        : gcc-plugin-annobin-11.4.1-3.el9.x86_64              16/266
  Verifying        : ghc-srpm-macros-1.5.0-6.el9.noarch                  17/266
  Verifying        : glibc-devel-2.34-113.el9.x86_64                     18/266
  Verifying        : glibc-headers-2.34-113.el9.x86_64                   19/266
  Verifying        : go-srpm-macros-3.2.0-3.el9.noarch                   20/266
  Verifying        : kernel-headers-5.14.0-474.el9.x86_64                21/266
  Verifying        : kernel-srpm-macros-1.0-13.el9.noarch                22/266
  Verifying        : libdatrie-0.2.13-4.el9.x86_64                       23/266
  Verifying        : libmpc-1.2.1-4.el9.x86_64                           24/266
  Verifying        : libstdc++-devel-11.4.1-3.el9.x86_64                 25/266
  Verifying        : libthai-0.1.28-8.el9.x86_64                         26/266
  Verifying        : libxcrypt-devel-4.4.18-3.el9.x86_64                 27/266
  Verifying        : llvm-libs-18.1.6-3.el9.x86_64                       28/266
  Verifying        : lua-srpm-macros-1-6.el9.noarch                      29/266
  Verifying        : ocaml-srpm-macros-6-6.el9.noarch                    30/266
  Verifying        : openblas-srpm-macros-2-11.el9.noarch                31/266
  Verifying        : perl-4:5.32.1-481.el9.x86_64                        32/266
  Verifying        : perl-Algorithm-Diff-1.2010-4.el9.noarch             33/266
  Verifying        : perl-Archive-Tar-2.38-6.el9.noarch                  34/266
  Verifying        : perl-Archive-Zip-1.68-6.el9.noarch                  35/266
  Verifying        : perl-Attribute-Handlers-1.01-481.el9.noarch         36/266
  Verifying        : perl-AutoLoader-5.74-481.el9.noarch                 37/266
  Verifying        : perl-AutoSplit-5.74-481.el9.noarch                  38/266
  Verifying        : perl-B-1.80-481.el9.x86_64                          39/266
  Verifying        : perl-Benchmark-1.23-481.el9.noarch                  40/266
  Verifying        : perl-CPAN-2.29-3.el9.noarch                         41/266
  Verifying        : perl-CPAN-DistnameInfo-0.12-23.el9.noarch           42/266
  Verifying        : perl-CPAN-Meta-2.150010-460.el9.noarch              43/266
  Verifying        : perl-CPAN-Meta-Requirements-2.140-461.el9.noarch    44/266
  Verifying        : perl-CPAN-Meta-YAML-0.018-461.el9.noarch            45/266
  Verifying        : perl-Carp-1.50-460.el9.noarch                       46/266
  Verifying        : perl-Class-Struct-0.66-481.el9.noarch               47/266
  Verifying        : perl-Compress-Bzip2-2.28-5.el9.x86_64               48/266
  Verifying        : perl-Compress-Raw-Bzip2-2.101-5.el9.x86_64          49/266
  Verifying        : perl-Compress-Raw-Lzma-2.101-3.el9.x86_64           50/266
  Verifying        : perl-Compress-Raw-Zlib-2.101-5.el9.x86_64           51/266
  Verifying        : perl-Config-Extensions-0.03-481.el9.noarch          52/266
  Verifying        : perl-Config-Perl-V-0.33-4.el9.noarch                53/266
  Verifying        : perl-DBM_Filter-0.06-481.el9.noarch                 54/266
  Verifying        : perl-DB_File-1.855-4.el9.x86_64                     55/266
  Verifying        : perl-Data-Dumper-2.174-462.el9.x86_64               56/266
  Verifying        : perl-Data-OptList-0.110-17.el9.noarch               57/266
  Verifying        : perl-Data-Section-0.200007-14.el9.noarch            58/266
  Verifying        : perl-Devel-PPPort-3.62-4.el9.x86_64                 59/266
  Verifying        : perl-Devel-Peek-1.28-481.el9.x86_64                 60/266
  Verifying        : perl-Devel-SelfStubber-1.06-481.el9.noarch          61/266
  Verifying        : perl-Devel-Size-0.83-10.el9.x86_64                  62/266
  Verifying        : perl-Digest-1.19-4.el9.noarch                       63/266
  Verifying        : perl-Digest-MD5-2.58-4.el9.x86_64                   64/266
  Verifying        : perl-Digest-SHA-1:6.02-461.el9.x86_64               65/266
  Verifying        : perl-Digest-SHA1-2.13-34.el9.x86_64                 66/266
  Verifying        : perl-DirHandle-1.05-481.el9.noarch                  67/266
  Verifying        : perl-Dumpvalue-2.27-481.el9.noarch                  68/266
  Verifying        : perl-DynaLoader-1.47-481.el9.x86_64                 69/266
  Verifying        : perl-Encode-4:3.08-462.el9.x86_64                   70/266
  Verifying        : perl-Encode-Locale-1.05-21.el9.noarch               71/266
  Verifying        : perl-Encode-devel-4:3.08-462.el9.x86_64             72/266
  Verifying        : perl-English-1.11-481.el9.noarch                    73/266
  Verifying        : perl-Env-1.04-460.el9.noarch                        74/266
  Verifying        : perl-Errno-1.30-481.el9.x86_64                      75/266
  Verifying        : perl-Exporter-5.74-461.el9.noarch                   76/266
  Verifying        : perl-ExtUtils-CBuilder-1:0.280236-4.el9.noarch      77/266
  Verifying        : perl-ExtUtils-Command-2:7.60-3.el9.noarch           78/266
  Verifying        : perl-ExtUtils-Constant-0.25-481.el9.noarch          79/266
  Verifying        : perl-ExtUtils-Embed-1.35-481.el9.noarch             80/266
  Verifying        : perl-ExtUtils-Install-2.20-4.el9.noarch             81/266
  Verifying        : perl-ExtUtils-MM-Utils-2:7.60-3.el9.noarch          82/266
  Verifying        : perl-ExtUtils-MakeMaker-2:7.60-3.el9.noarch         83/266
  Verifying        : perl-ExtUtils-Manifest-1:1.73-4.el9.noarch          84/266
  Verifying        : perl-ExtUtils-Miniperl-1.09-481.el9.noarch          85/266
  Verifying        : perl-ExtUtils-ParseXS-1:3.40-460.el9.noarch         86/266
  Verifying        : perl-Fcntl-1.13-481.el9.x86_64                      87/266
  Verifying        : perl-File-Basename-2.85-481.el9.noarch              88/266
  Verifying        : perl-File-Compare-1.100.600-481.el9.noarch          89/266
  Verifying        : perl-File-Copy-2.34-481.el9.noarch                  90/266
  Verifying        : perl-File-DosGlob-1.12-481.el9.x86_64               91/266
  Verifying        : perl-File-Fetch-1.00-4.el9.noarch                   92/266
  Verifying        : perl-File-Find-1.37-481.el9.noarch                  93/266
  Verifying        : perl-File-HomeDir-1.006-4.el9.noarch                94/266
  Verifying        : perl-File-Path-2.18-4.el9.noarch                    95/266
  Verifying        : perl-File-Temp-1:0.231.100-4.el9.noarch             96/266
  Verifying        : perl-File-Which-1.23-10.el9.noarch                  97/266
  Verifying        : perl-File-stat-1.09-481.el9.noarch                  98/266
  Verifying        : perl-FileCache-1.10-481.el9.noarch                  99/266
  Verifying        : perl-FileHandle-2.03-481.el9.noarch                100/266
  Verifying        : perl-Filter-2:1.60-4.el9.x86_64                    101/266
  Verifying        : perl-Filter-Simple-0.96-460.el9.noarch             102/266
  Verifying        : perl-FindBin-1.51-481.el9.noarch                   103/266
  Verifying        : perl-GDBM_File-1.18-481.el9.x86_64                 104/266
  Verifying        : perl-Getopt-Long-1:2.52-4.el9.noarch               105/266
  Verifying        : perl-Getopt-Std-1.12-481.el9.noarch                106/266
  Verifying        : perl-HTTP-Tiny-0.076-462.el9.noarch                107/266
  Verifying        : perl-Hash-Util-0.23-481.el9.x86_64                 108/266
  Verifying        : perl-Hash-Util-FieldHash-1.20-481.el9.x86_64       109/266
  Verifying        : perl-I18N-Collate-1.02-481.el9.noarch              110/266
  Verifying        : perl-I18N-LangTags-0.44-481.el9.noarch             111/266
  Verifying        : perl-I18N-Langinfo-0.19-481.el9.x86_64             112/266
  Verifying        : perl-IO-1.43-481.el9.x86_64                        113/266
  Verifying        : perl-IO-Compress-2.102-4.el9.noarch                114/266
  Verifying        : perl-IO-Compress-Lzma-2.101-4.el9.noarch           115/266
  Verifying        : perl-IO-Socket-IP-0.41-5.el9.noarch                116/266
  Verifying        : perl-IO-Socket-SSL-2.073-2.el9.noarch              117/266
  Verifying        : perl-IO-Zlib-1:1.11-4.el9.noarch                   118/266
  Verifying        : perl-IPC-Cmd-2:1.04-461.el9.noarch                 119/266
  Verifying        : perl-IPC-Open3-1.21-481.el9.noarch                 120/266
  Verifying        : perl-IPC-SysV-2.09-4.el9.x86_64                    121/266
  Verifying        : perl-IPC-System-Simple-1.30-6.el9.noarch           122/266
  Verifying        : perl-Importer-0.026-4.el9.noarch                   123/266
  Verifying        : perl-JSON-PP-1:4.06-4.el9.noarch                   124/266
  Verifying        : perl-Locale-Maketext-1.29-461.el9.noarch           125/266
  Verifying        : perl-Locale-Maketext-Simple-1:0.21-481.el9.noarc   126/266
  Verifying        : perl-MIME-Base64-3.16-4.el9.x86_64                 127/266
  Verifying        : perl-MIME-Charset-1.012.2-15.el9.noarch            128/266
  Verifying        : perl-MRO-Compat-0.13-15.el9.noarch                 129/266
  Verifying        : perl-Math-BigInt-1:1.9998.18-460.el9.noarch        130/266
  Verifying        : perl-Math-BigInt-FastCalc-0.500.900-460.el9.x86_   131/266
  Verifying        : perl-Math-BigRat-0.2614-460.el9.noarch             132/266
  Verifying        : perl-Math-Complex-1.59-481.el9.noarch              133/266
  Verifying        : perl-Memoize-1.03-481.el9.noarch                   134/266
  Verifying        : perl-Module-Build-2:0.42.31-9.el9.noarch           135/266
  Verifying        : perl-Module-CoreList-1:5.20210320-3.el9.noarch     136/266
  Verifying        : perl-Module-CoreList-tools-1:5.20210320-3.el9.no   137/266
  Verifying        : perl-Module-Load-1:0.36-4.el9.noarch               138/266
  Verifying        : perl-Module-Load-Conditional-0.74-4.el9.noarch     139/266
  Verifying        : perl-Module-Loaded-1:0.08-481.el9.noarch           140/266
  Verifying        : perl-Module-Metadata-1.000037-460.el9.noarch       141/266
  Verifying        : perl-Module-Signature-0.88-1.el9.noarch            142/266
  Verifying        : perl-Mozilla-CA-20200520-6.el9.noarch              143/266
  Verifying        : perl-NDBM_File-1.15-481.el9.x86_64                 144/266
  Verifying        : perl-NEXT-0.67-481.el9.noarch                      145/266
  Verifying        : perl-Net-1.02-481.el9.noarch                       146/266
  Verifying        : perl-Net-Ping-2.74-5.el9.noarch                    147/266
  Verifying        : perl-Net-SSLeay-1.94-1.el9.x86_64                  148/266
  Verifying        : perl-ODBM_File-1.16-481.el9.x86_64                 149/266
  Verifying        : perl-Object-HashBase-0.009-7.el9.noarch            150/266
  Verifying        : perl-Opcode-1.48-481.el9.x86_64                    151/266
  Verifying        : perl-POSIX-1.94-481.el9.x86_64                     152/266
  Verifying        : perl-Package-Generator-1.106-23.el9.noarch         153/266
  Verifying        : perl-Params-Check-1:0.38-461.el9.noarch            154/266
  Verifying        : perl-Params-Util-1.102-5.el9.x86_64                155/266
  Verifying        : perl-PathTools-3.78-461.el9.x86_64                 156/266
  Verifying        : perl-Perl-OSType-1.010-461.el9.noarch              157/266
  Verifying        : perl-PerlIO-via-QuotedPrint-0.09-4.el9.noarch      158/266
  Verifying        : perl-Pod-Checker-4:1.74-4.el9.noarch               159/266
  Verifying        : perl-Pod-Escapes-1:1.07-460.el9.noarch             160/266
  Verifying        : perl-Pod-Functions-1.13-481.el9.noarch             161/266
  Verifying        : perl-Pod-Html-1.25-481.el9.noarch                  162/266
  Verifying        : perl-Pod-Perldoc-3.28.01-461.el9.noarch            163/266
  Verifying        : perl-Pod-Simple-1:3.42-4.el9.noarch                164/266
  Verifying        : perl-Pod-Usage-4:2.01-4.el9.noarch                 165/266
  Verifying        : perl-Safe-2.41-481.el9.noarch                      166/266
  Verifying        : perl-Scalar-List-Utils-4:1.56-462.el9.x86_64       167/266
  Verifying        : perl-Search-Dict-1.07-481.el9.noarch               168/266
  Verifying        : perl-SelectSaver-1.02-481.el9.noarch               169/266
  Verifying        : perl-SelfLoader-1.26-481.el9.noarch                170/266
  Verifying        : perl-Socket-4:2.031-4.el9.x86_64                   171/266
  Verifying        : perl-Software-License-0.103014-12.el9.noarch       172/266
  Verifying        : perl-Storable-1:3.21-460.el9.x86_64                173/266
  Verifying        : perl-Sub-Exporter-0.987-27.el9.noarch              174/266
  Verifying        : perl-Sub-Install-0.928-28.el9.noarch               175/266
  Verifying        : perl-Symbol-1.08-481.el9.noarch                    176/266
  Verifying        : perl-Sys-Hostname-1.23-481.el9.x86_64              177/266
  Verifying        : perl-Sys-Syslog-0.36-461.el9.x86_64                178/266
  Verifying        : perl-Term-ANSIColor-5.01-461.el9.noarch            179/266
  Verifying        : perl-Term-Cap-1.17-460.el9.noarch                  180/266
  Verifying        : perl-Term-Complete-1.403-481.el9.noarch            181/266
  Verifying        : perl-Term-ReadLine-1.17-481.el9.noarch             182/266
  Verifying        : perl-Term-Size-Any-0.002-35.el9.noarch             183/266
  Verifying        : perl-Term-Size-Perl-0.031-12.el9.x86_64            184/266
  Verifying        : perl-Term-Table-0.015-8.el9.noarch                 185/266
  Verifying        : perl-TermReadKey-2.38-11.el9.x86_64                186/266
  Verifying        : perl-Test-1.31-481.el9.noarch                      187/266
  Verifying        : perl-Test-Harness-1:3.42-461.el9.noarch            188/266
  Verifying        : perl-Test-Simple-3:1.302183-4.el9.noarch           189/266
  Verifying        : perl-Text-Abbrev-1.02-481.el9.noarch               190/266
  Verifying        : perl-Text-Balanced-2.04-4.el9.noarch               191/266
  Verifying        : perl-Text-Diff-1.45-13.el9.noarch                  192/266
  Verifying        : perl-Text-Glob-0.11-15.el9.noarch                  193/266
  Verifying        : perl-Text-ParseWords-3.30-460.el9.noarch           194/266
  Verifying        : perl-Text-Tabs+Wrap-2013.0523-460.el9.noarch       195/266
  Verifying        : perl-Text-Template-1.59-5.el9.noarch               196/266
  Verifying        : perl-Thread-3.05-481.el9.noarch                    197/266
  Verifying        : perl-Thread-Queue-3.14-460.el9.noarch              198/266
  Verifying        : perl-Thread-Semaphore-2.13-481.el9.noarch          199/266
  Verifying        : perl-Tie-4.6-481.el9.noarch                        200/266
  Verifying        : perl-Tie-File-1.06-481.el9.noarch                  201/266
  Verifying        : perl-Tie-Memoize-1.1-481.el9.noarch                202/266
  Verifying        : perl-Tie-RefHash-1.40-4.el9.noarch                 203/266
  Verifying        : perl-Time-1.03-481.el9.noarch                      204/266
  Verifying        : perl-Time-HiRes-4:1.9764-462.el9.x86_64            205/266
  Verifying        : perl-Time-Local-2:1.300-7.el9.noarch               206/266
  Verifying        : perl-Time-Piece-1.3401-481.el9.x86_64              207/266
  Verifying        : perl-URI-5.09-3.el9.noarch                         208/266
  Verifying        : perl-Unicode-Collate-1.29-4.el9.x86_64             209/266
  Verifying        : perl-Unicode-LineBreak-2019.001-11.el9.x86_64      210/266
  Verifying        : perl-Unicode-Normalize-1.27-461.el9.x86_64         211/266
  Verifying        : perl-Unicode-UCD-0.75-481.el9.noarch               212/266
  Verifying        : perl-User-pwent-1.03-481.el9.noarch                213/266
  Verifying        : perl-autodie-2.34-4.el9.noarch                     214/266
  Verifying        : perl-autouse-1.11-481.el9.noarch                   215/266
  Verifying        : perl-base-2.27-481.el9.noarch                      216/266
  Verifying        : perl-bignum-0.51-460.el9.noarch                    217/266
  Verifying        : perl-blib-1.07-481.el9.noarch                      218/266
  Verifying        : perl-constant-1.33-461.el9.noarch                  219/266
  Verifying        : perl-debugger-1.56-481.el9.noarch                  220/266
  Verifying        : perl-deprecate-0.04-481.el9.noarch                 221/266
  Verifying        : perl-devel-4:5.32.1-481.el9.x86_64                 222/266
  Verifying        : perl-diagnostics-1.37-481.el9.noarch               223/266
  Verifying        : perl-doc-5.32.1-481.el9.noarch                     224/266
  Verifying        : perl-encoding-4:3.00-462.el9.x86_64                225/266
  Verifying        : perl-encoding-warnings-0.13-481.el9.noarch         226/266
  Verifying        : perl-experimental-0.022-6.el9.noarch               227/266
  Verifying        : perl-fields-2.27-481.el9.noarch                    228/266
  Verifying        : perl-filetest-1.03-481.el9.noarch                  229/266
  Verifying        : perl-if-0.60.800-481.el9.noarch                    230/266
  Verifying        : perl-inc-latest-2:0.500-20.el9.noarch              231/266
  Verifying        : perl-interpreter-4:5.32.1-481.el9.x86_64           232/266
  Verifying        : perl-less-0.03-481.el9.noarch                      233/266
  Verifying        : perl-lib-0.65-481.el9.x86_64                       234/266
  Verifying        : perl-libnet-3.13-4.el9.noarch                      235/266
  Verifying        : perl-libnetcfg-4:5.32.1-481.el9.noarch             236/266
  Verifying        : perl-libs-4:5.32.1-481.el9.x86_64                  237/266
  Verifying        : perl-local-lib-2.000024-13.el9.noarch              238/266
  Verifying        : perl-locale-1.09-481.el9.noarch                    239/266
  Verifying        : perl-macros-4:5.32.1-481.el9.noarch                240/266
  Verifying        : perl-meta-notation-5.32.1-481.el9.noarch           241/266
  Verifying        : perl-mro-1.23-481.el9.x86_64                       242/266
  Verifying        : perl-open-1.12-481.el9.noarch                      243/266
  Verifying        : perl-overload-1.31-481.el9.noarch                  244/266
  Verifying        : perl-overloading-0.02-481.el9.noarch               245/266
  Verifying        : perl-parent-1:0.238-460.el9.noarch                 246/266
  Verifying        : perl-perlfaq-5.20201107-4.el9.noarch               247/266
  Verifying        : perl-ph-5.32.1-481.el9.x86_64                      248/266
  Verifying        : perl-podlators-1:4.14-460.el9.noarch               249/266
  Verifying        : perl-sigtrap-1.09-481.el9.noarch                   250/266
  Verifying        : perl-sort-2.04-481.el9.noarch                      251/266
  Verifying        : perl-srpm-macros-1-41.el9.noarch                   252/266
  Verifying        : perl-subs-1.03-481.el9.noarch                      253/266
  Verifying        : perl-threads-1:2.25-460.el9.x86_64                 254/266
  Verifying        : perl-threads-shared-1.61-460.el9.x86_64            255/266
  Verifying        : perl-utils-5.32.1-481.el9.noarch                   256/266
  Verifying        : perl-vars-1.05-481.el9.noarch                      257/266
  Verifying        : perl-version-7:0.99.28-4.el9.x86_64                258/266
  Verifying        : perl-vmsish-1.04-481.el9.noarch                    259/266
  Verifying        : pyproject-srpm-macros-1.12.0-1.el9.noarch          260/266
  Verifying        : python-srpm-macros-3.9-54.el9.noarch               261/266
  Verifying        : qt5-srpm-macros-5.15.9-1.el9.noarch                262/266
  Verifying        : redhat-rpm-config-207-1.el9.noarch                 263/266
  Verifying        : rust-srpm-macros-17-4.el9.noarch                   264/266
  Verifying        : sombok-2.4.0-16.el9.x86_64                         265/266
  Verifying        : systemtap-sdt-devel-5.1-3.el9.x86_64               266/266
Installed:
  perl-Locale-Maketext-Simple-1:0.21-481.el9.noarch
  perl-Math-BigInt-FastCalc-0.500.900-460.el9.x86_64
  perl-Module-CoreList-tools-1:5.20210320-3.el9.noarch
Complete!
2024.07.14-12:19:13 - perl installed
2024.07.14-12:19:13 - Adding eFa CentOS 9 Release Repo
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100   181  100   181    0     0    132      0  0:00:01  0:00:01 --:--:--   132
2024.07.14-12:19:15 - Installing EPEL Repo
eFa-Project                                      67 kB/s | 109 kB     00:01
Dependencies resolved.
 Package                 Architecture Version         Repository           Size
Installing:
 epel-release            noarch       9-7.el9         extras-common        19 k
 epel-next-release       noarch       9-7.el9         extras-common       8.1 k
Transaction Summary
Install  2 Packages
Total download size: 27 k
Installed size: 29 k
(1/2): epel-next-release-9-7.el9.noarch.rpm      49 kB/s | 8.1 kB     00:00
(2/2): epel-release-9-7.el9.noarch.rpm           86 kB/s |  19 kB     00:00
Total                                            71 kB/s |  27 kB     00:00
CentOS Stream 9 - Extras packages               2.1 MB/s | 2.1 kB     00:00
Importing GPG key 0x1D997668:
 Userid     : "CentOS Extras SIG (https://wiki.centos.org/SpecialInterestGroup) <security@centos.org>"
 Fingerprint: 363F C097 2F64 B699 AED3 968E 1FF6 A217 1D99 7668
 From       : /etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-SIG-Extras-SHA512
Key imported successfully
Running transaction
  Preparing        :                                                        1/1
  Installing       : epel-release-9-7.el9.noarch                            1/2
  Running scriptlet: epel-release-9-7.el9.noarch                            1/2
Many EPEL packages require the CodeReady Builder (CRB) repository.
It is recommended that you run /usr/bin/crb enable to enable the CRB repository.
  Installing       : epel-next-release-9-7.el9.noarch                       2/2
  Running scriptlet: epel-next-release-9-7.el9.noarch                       2/2
  Verifying        : epel-next-release-9-7.el9.noarch                       1/2
  Verifying        : epel-release-9-7.el9.noarch                            2/2
Installed:
  epel-next-release-9-7.el9.noarch          epel-release-9-7.el9.noarch
Complete!
2024.07.14-12:19:19 - EPEL repo installed
2024.07.14-12:19:19 - crb repo enabled
CentOS Stream 9 - BaseOS                         53 kB/s | 5.8 kB     00:00
CentOS Stream 9 - AppStream                      48 kB/s | 5.9 kB     00:00
CentOS Stream 9 - CRB                           2.4 MB/s | 6.5 MB     00:02
Extra Packages for Enterprise Linux 9 - x86_64   21 MB/s |  22 MB     00:01
Extra Packages for Enterprise Linux 9 openh264  4.4 kB/s | 2.5 kB     00:00
Extra Packages for Enterprise Linux 9 - Next -  431 kB/s | 276 kB     00:00
Nothing to do.
Complete!
Last metadata expiration check: 0:00:02 ago on Sun 14 Jul 2024 12:19:30 PM GMT.
Enabling module streams:
 php                                8.1
Transaction Summary
Complete!
2024.07.14-12:19:32 - php 8.1 stream enabled
2024.07.14-12:19:32 - Updating the OS
Nothing to do.
Complete!
Mail2GoCa
Re: SFTP broken after running EFA 5.0.0 install script
Post by Mail2GoCa »
2024.07.14-12:19:33 - System Updated
2024.07.14-12:19:33 - Removing conflicting packages
2024.07.14-12:19:33 - Installing eFa packages (This can take a while)
Last metadata expiration check: 0:00:03 ago on Sun 14 Jul 2024 12:19:30 PM GMT.
 Package                              Arch    Version                            Repository     Size
Installing:
 eFa                                  noarch  5.0.0-8.eFa.el9                    eFa5-release   97 k
Installing dependencies:
 MailScanner                          noarch  5.5.1-5.eFa.el9                    eFa5-release  566 k
 MailWatch                            noarch  1:1.2.23-2.eFa.el9                 eFa5-release  1.1 M
 apr                                  x86_64  1.7.0-12.el9                       appstream     123 k
 apr-util                             x86_64  1.6.1-23.el9                       appstream      95 k
 apr-util-bdb                         x86_64  1.6.1-23.el9                       appstream      13 k
 augeas-libs                          x86_64  1.13.0-5.el9                       appstream     455 k
 bind-libs                            x86_64  32:9.16.23-15.el9                  appstream     1.2 M
 bind-license                         noarch  32:9.16.23-15.el9                  appstream      13 k
 bind-utils                           x86_64  32:9.16.23-15.el9                  appstream     208 k
 centos-logos-httpd                   noarch  90.8-1.el9                         appstream     1.5 M
 certbot                              noarch  2.11.0-1.el9                       epel           49 k
 checkpolicy                          x86_64  3.6-1.el9                          baseos        353 k
 chkconfig                            x86_64  1.24-1.el9                         baseos        179 k
 clamav                               x86_64  1.0.6-1.el9                        epel          317 k
 clamav-filesystem                    noarch  1.0.6-1.el9                        epel           19 k
 clamav-freshclam                     x86_64  1.0.6-1.el9                        epel           96 k
 clamav-lib                           x86_64  1.0.6-1.el9                        epel          2.5 M
 clamav-unofficial-sigs               noarch  1:7.2.5.1-1.eFa.el9                eFa5-release   56 k
 clamd                                x86_64  1.0.6-1.el9                        epel           92 k
 clucene-core                         x86_64  2.3.3.4-42.20130812.e8e3d20git.el9 appstream     587 k
 cyrus-sasl                           x86_64  2.1.27-21.el9                      baseos         73 k
 cyrus-sasl-md5                       x86_64  2.1.27-21.el9                      appstream      43 k
 cyrus-sasl-plain                     x86_64  2.1.27-21.el9                      baseos         24 k
 dcc                                  x86_64  2.3.168-1.eFa.el9                  eFa5-release  820 k
 dnf-automatic                        noarch  4.14.0-15.el9                      baseos         32 k
 dovecot                              x86_64  1:2.3.16-11.el9                    appstream     4.9 M
 eFa-base                             noarch  1:5.0.0-1.eFa.el9                  eFa5-release   11 M
 emacs-filesystem                     noarch  1:27.2-9.el9                       appstream     8.9 k
 fail2ban                             noarch  1.0.2-12.el9                       epel          8.8 k
 fail2ban-firewalld                   noarch  1.0.2-12.el9                       epel          8.9 k
 fail2ban-selinux                     noarch  1.0.2-12.el9                       epel           29 k
 fail2ban-sendmail                    noarch  1.0.2-12.el9                       epel           12 k
 fail2ban-server                      noarch  1.0.2-12.el9                       epel          444 k
 fontawesome-fonts                    noarch  1:4.7.0-13.el9                     appstream     205 k
 fontconfig                           x86_64  2.14.0-2.el9                       appstream     297 k
 freetype                             x86_64  2.10.4-9.el9                       baseos        388 k
 fstrm                                x86_64  0.6.1-3.el9                        appstream      28 k
 gd                                   x86_64  2.3.2-3.el9                        appstream     132 k
 graphite2                            x86_64  1.3.14-9.el9                       baseos         95 k
 harfbuzz                             x86_64  2.7.4-10.el9                       baseos        624 k
 httpd                                x86_64  2.4.57-8.el9                       appstream      48 k
 httpd-core                           x86_64  2.4.57-8.el9                       appstream     1.5 M
 httpd-filesystem                     noarch  2.4.57-8.el9                       appstream      13 k
 httpd-tools                          x86_64  2.4.57-8.el9                       appstream      83 k
 ipcalc                               x86_64  1.0.0-5.el9                        baseos         42 k
 jbigkit-libs                         x86_64  2.1-23.el9                         appstream      53 k
 libX11                               x86_64  1.7.0-9.el9                        appstream     646 k
 libX11-common                        noarch  1.7.0-9.el9                        appstream     205 k
 libXau                               x86_64  1.0.9-8.el9                        appstream      31 k
 libXpm                               x86_64  3.5.13-10.el9                      appstream      59 k
 libbsd                               x86_64  0.12.2-1.el9                       epel          120 k
 libexttextcat                        x86_64  3.4.5-11.el9                       appstream     245 k
 libicu                               x86_64  67.1-9.el9                         baseos        9.6 M
 libidn                               x86_64  1.38-4.el9                         epel          191 k
 libjpeg-turbo                        x86_64  2.0.90-7.el9                       appstream     175 k
 libmaxminddb                         x86_64  1.5.2-4.el9                        appstream      33 k
 libmd                                x86_64  1.1.0-1.el9                        epel           46 k
 libmemcached-awesome                 x86_64  1.1.0-12.el9                       crb           111 k
 libopendkim                          x86_64  2.11.0-0.36.el9                    epel           70 k
 libopendmarc                         x86_64  1.4.2-10.el9                       epel           31 k
 libpng                               x86_64  2:1.6.37-12.el9                    baseos        117 k
 libspf2                              x86_64  1.2.11-11.20210922git4915c308.el9  epel           68 k
 libstemmer                           x86_64  0-18.585svn.el9                    appstream      83 k
 libtiff                              x86_64  4.4.0-12.el9                       appstream     198 k
 libtirpc                             x86_64  1.3.3-6.el9                        baseos         93 k
 libuv                                x86_64  1:1.42.0-2.el9                     appstream     148 k
 libwebp                              x86_64  1.2.0-8.el9                        appstream     277 k
 libxcb                               x86_64  1.13.1-9.el9                       appstream     243 k
 libxslt                              x86_64  1.1.34-9.el9                       appstream     243 k
 mailcap                              noarch  2.1.49-5.el9                       baseos         33 k
 mariadb                              x86_64  3:10.5.22-1.el9                    appstream     1.6 M
 mariadb-common                       x86_64  3:10.5.22-1.el9                    appstream      31 k
 mariadb-connector-c                  x86_64  3.2.6-1.el9                        appstream     198 k
 mariadb-connector-c-config           noarch  3.2.6-1.el9                        appstream      11 k
 mariadb-errmsg                       x86_64  3:10.5.22-1.el9                    appstream     220 k
 mariadb-server                       x86_64  3:10.5.22-1.el9                    appstream     9.7 M
 mod_ssl                              x86_64  1:2.4.57-8.el9                     appstream     110 k
 mysql-selinux                        noarch  1.0.10-1.el9                       appstream      37 k
 nginx-filesystem                     noarch  1:1.20.1-16.el9                    appstream     9.3 k
 opendbx                              x86_64  1.4.6-31.el9                       epel           52 k
 opendkim                             x86_64  2.11.0-0.36.el9                    epel          223 k
 opendmarc                            x86_64  1.4.2-10.el9                       epel          101 k
 p7zip                                x86_64  16.02-21.el9                       epel          641 k
 p7zip-plugins                        x86_64  16.02-21.el9                       epel          988 k
 perl-B-Hooks-EndOfScope              noarch  0.24-15.el9                        crb            42 k
 perl-BSD-Resource                    x86_64  1.291.100-17.el9                   appstream      46 k
 perl-Bit-Vector                      x86_64  7.4-24.el9                         appstream     169 k
 perl-Carp-Clan                       noarch  6.08-8.el9                         appstream      25 k
 perl-Class-Data-Inheritable          noarch  0.08-39.el9                        crb            14 k
 perl-Class-Inspector                 noarch  1.36-7.el9                         appstream      32 k
 perl-Class-Method-Modifiers          noarch  2.13-8.el9                         crb            49 k
 perl-Class-Singleton                 noarch  1.6-4.el9                          crb            28 k
 perl-Class-Tiny                      noarch  1.008-4.el9                        crb            30 k
 perl-Clone                           x86_64  0.45-6.el9                         appstream      23 k
 perl-Clone-Choose                    noarch  0.010-13.el9                       epel           15 k
 perl-Config-Tiny                     noarch  2.27-1.el9                         epel           30 k
 perl-Convert-BinHex                  noarch  1.125-13.el9                       epel           44 k
 perl-Crypt-OpenSSL-Bignum            x86_64  0.09-16.el9                        appstream      43 k
 perl-Crypt-OpenSSL-RSA               x86_64  0.31-13.el9                        appstream      44 k
 perl-Crypt-OpenSSL-Random            x86_64  0.15-14.el9                        appstream      27 k
 perl-DBD-MariaDB                     x86_64  1.21-16.el9                        appstream     152 k
 perl-DBD-MySQL                       x86_64  4.050-13.el9                       appstream     147 k
 perl-DBD-SQLite                      x86_64  1.66-5.el9                         appstream     195 k
 perl-DBI                             x86_64  1.643-9.el9                        appstream     725 k
 perl-DBIx-Simple                     noarch  1.37-16.el9                        epel           43 k
 perl-DBIx-XHTML_Table                noarch  1.49-19.el9                        epel           38 k
 perl-Data-Dump                       noarch  1.23-18.el9                        appstream      34 k
 perl-Data-Dumper-Concise             noarch  2.023-17.el9                       epel           23 k
 perl-Data-IEEE754                    noarch  0.02-8.el9                         epel           17 k
 perl-Data-Printer                    noarch  1.000004-7.el9                     epel          140 k
 perl-Data-Validate-IP                noarch  0.30-4.el9                         epel           31 k
 perl-Date-Calc                       noarch  6.4-20.el9                         appstream     204 k
 perl-Date-ISO8601                    noarch  0.005-13.el9                       crb            21 k
 perl-DateTime                        x86_64  2:1.54-4.el9                       crb           131 k
 perl-DateTime-Locale                 noarch  1.31-4.el9                         crb           3.3 M
 perl-DateTime-TimeZone               noarch  2.62-1.el9                         crb           420 k
 perl-DateTime-TimeZone-SystemV       noarch  0.010-14.el9                       crb            24 k
 perl-DateTime-TimeZone-Tzfile        noarch  0.011-14.el9                       crb            21 k
 perl-Devel-ArgNames                  noarch  0.03-25.el9                        epel           12 k
 perl-Devel-CallChecker               x86_64  0.008-14.el9                       crb            24 k
 perl-Devel-Caller                    x86_64  2.06-26.el9                        crb            20 k
 perl-Devel-Cycle                     noarch  1.12-16.el9                        epel           17 k
 perl-Devel-GlobalDestruction         noarch  0.14-16.el9                        crb            18 k
 perl-Devel-LexAlias                  x86_64  0.05-27.el9                        crb            17 k
 perl-Devel-StackTrace                noarch  1:2.04-10.el9                      crb            31 k
 perl-Digest-HMAC                     noarch  1.03-29.el9                        appstream      17 k
 perl-Dist-CheckConflicts             noarch  0.11-23.el9                        crb            25 k
 perl-DynaLoader-Functions            noarch  0.003-13.el9                       crb            20 k
 perl-Email-Abstract                  noarch  3.009-3.el9                        epel           37 k
 perl-Email-Address                   noarch  1.912-11.el9                       epel           40 k
 perl-Email-Address-XS                x86_64  1.04-13.el9                        epel           37 k
 perl-Email-Date-Format               noarch  1.005-20.el9                       epel           18 k
 perl-Email-MIME                      noarch  1.954-1.el9                        epel           55 k
 perl-Email-MIME-ContentType          noarch  1.026-4.el9                        epel           25 k
 perl-Email-MIME-Encodings            noarch  1.315-23.el9                       epel           19 k
 perl-Email-MessageID                 noarch  1.406-20.el9                       epel           20 k
 perl-Email-Sender                    noarch  1:2.500-3.el9                      epel           92 k
 perl-Email-Simple                    noarch  2.216-6.el9                        epel           34 k
 perl-Encode-Detect                   x86_64  1.01-37.el9                        appstream      90 k
 perl-Encoding-FixLatin               noarch  1.04-1.eFa.el9                     eFa5-release   24 k
 perl-Error                           noarch  1:0.17029-7.el9                    appstream      42 k
 perl-Eval-Closure                    noarch  0.14-16.el9                        crb            25 k
 perl-Exception-Class                 noarch  1.44-13.el9                        crb            43 k
 perl-Exporter-Tiny                   noarch  1.002002-6.el9                     appstream      54 k
 perl-File-Copy-Recursive             noarch  0.45-7.el9                         crb            27 k
 perl-File-Listing                    noarch  6.14-4.el9                         appstream      26 k
 perl-File-ShareDir                   noarch  1.118-4.el9                        appstream      31 k
 perl-Filesys-Df                      x86_64  0.92-45.el9                        epel           21 k
 perl-Font-AFM                        noarch  1.20-38.el9                        epel           21 k
 perl-Geo-IP                          noarch  1.51-1.eFa.el9                     eFa5-release   77 k
 perl-Geography-Countries             noarch  2009041301-34.el9                  epel           21 k
 perl-HTML-Formatter                  noarch  2.16-17.el9                        epel           52 k
 perl-HTML-Parser                     x86_64  3.76-3.el9                         appstream     124 k
 perl-HTML-Tagset                     noarch  3.20-47.el9                        appstream      19 k
 perl-HTML-Tree                       noarch  1:5.07-16.el9                      crb           216 k
 perl-HTTP-Cookies                    noarch  6.10-4.el9                         appstream      39 k
 perl-HTTP-Date                       noarch  6.05-7.el9                         appstream      25 k
 perl-HTTP-Message                    noarch  6.29-3.el9                         appstream      99 k
 perl-HTTP-Negotiate                  noarch  6.01-30.el9                        appstream      20 k
 perl-Hash-Merge                      noarch  0.302-4.el9                        epel           20 k
 perl-Hash-Ordered                    noarch  0.014-1.el9                        epel           40 k
 perl-IO-HTML                         noarch  1.004-4.el9                        appstream      29 k
 perl-IO-Multiplex                    noarch  1.16-21.el9                        appstream      27 k
 perl-IO-Socket-INET6                 noarch  2.72-24.el9                        appstream      29 k
 perl-IO-String                       noarch  1.08-43.el9                        crb            18 k
 perl-IO-stringy                      noarch  2.113-7.el9                        crb            67 k
 perl-IP-Country                      noarch  2.28-1.eFa.el9                     eFa5-release  290 k
 perl-IP-Country-DB_File              noarch  3.03-1.eFa.el9                     eFa5-release   29 k
 perl-Import-Into                     noarch  1.002005-19.el9                    crb            18 k
 perl-JSON                            noarch  4.03-5.el9                         appstream      96 k
 perl-LWP-MediaTypes                  noarch  6.04-9.el9                         appstream      34 k
 perl-LWP-Protocol-https              noarch  6.10-4.el9                         appstream      22 k
 perl-List-AllUtils                   noarch  0.19-7.el9                         epel           49 k
 perl-List-MoreUtils-XS               x86_64  0.430-5.el9                        appstream      63 k
 perl-List-SomeUtils                  noarch  0.58-10.el9                        epel           46 k
 perl-List-UtilsBy                    noarch  0.12-3.el9                         epel           29 k
 perl-MIME-Types                      noarch  2.18-4.el9                         crb            69 k
 perl-MIME-tools                      noarch  5.509-11.el9                       epel          231 k
 perl-Mail-AuthenticationResults      noarch  2.20210112-4.el9                   appstream      68 k
 perl-Mail-DKIM                       noarch  1.20200907-4.el9                   appstream     205 k
 perl-Mail-DMARC                      noarch  1.20230215-1.eFa.el9               eFa5-release  437 k
 perl-Mail-Message                    noarch  3.013-2.el9                        epel          468 k
 perl-Mail-SPF                        noarch  2.9.0-26.el9                       appstream     159 k
 perl-Mail-Transport                  noarch  3.005-1.el9                        epel           56 k
 perl-MailTools                       noarch  2.21-9.el9                         appstream     111 k
 perl-Math-Int128                     x86_64  0.22-8.el9                         epel           46 k
 perl-Math-Int64                      x86_64  0.54-22.el9                        epel           56 k
 perl-MaxMind-DB-Common               noarch  0.040001-9.el9                     epel           24 k
 perl-MaxMind-DB-Reader               x86_64  1.000014-9.el9                     epel           33 k
 perl-MaxMind-DB-Reader-XS            x86_64  1.000009-3.el9                     epel           34 k
 perl-Module-Implementation           noarch  0.09-30.el9                        crb            20 k
 perl-Module-Pluggable                noarch  2:5.2-18.el9                       crb            32 k
 perl-Module-Runtime                  noarch  0.016-13.el9                       crb            24 k
 perl-Moo                             noarch  2.005004-3.el9                     epel           67 k
 perl-MooX-StrictConstructor          noarch  0.011-9.el9                        epel           24 k
 perl-MooX-Types-MooseLike            noarch  0.29-19.el9                        epel           24 k
 perl-NTLM                            noarch  1.09-30.el9                        appstream      23 k
 perl-Net-CIDR                        noarch  0.21-1.el9                         epel           21 k
 perl-Net-CIDR-Lite                   noarch  0.22-2.el9                         appstream      21 k
 perl-Net-DNS                         noarch  1.29-6.el9                         appstream     401 k
 perl-Net-DNS-Nameserver              noarch  1.29-6.el9                         crb            23 k
 perl-Net-DNS-Resolver-Programmable   noarch  0.009-1.eFa.el9                    eFa5-release   25 k
 perl-Net-HTTP                        noarch  6.21-3.el9                         appstream      41 k
 perl-Net-IDN-Encode                  noarch  2.500-1.eFa.el9                    eFa5-release  101 k
 perl-Net-IP                          noarch  1.26-20.el9                        epel           36 k
 perl-Net-LibIDN                      x86_64  0.12-1.eFa.el9                     eFa5-release   27 k
 perl-Net-LibIDN2                     x86_64  1.01-7.el9                         epel           33 k
 perl-Net-Patricia                    x86_64  1.22-25.el9                        epel           44 k
 perl-Net-SMTP-SSL                    noarch  1.04-16.el9                        appstream      13 k
 perl-Net-Server                      noarch  2.009-14.el9                       appstream     206 k
 perl-NetAddr-IP                      x86_64  4.079-18.el9                       appstream     135 k
 perl-OLE-Storage_Lite                noarch  0.20-7.el9                         epel           30 k
 perl-Object-Accessor                 noarch  1:0.48-26.el9                      epel           23 k
 perl-Package-Stash                   noarch  0.39-4.el9                         crb            34 k
 perl-Package-Stash-XS                x86_64  0.29-11.el9                        crb            36 k
 perl-PadWalker                       x86_64  2.5-4.el9                          crb            27 k
 perl-Params-Classify                 x86_64  0.015-14.el9                       crb            33 k
 perl-Params-ValidationCompiler       noarch  0.30-12.el9                        crb            39 k
 perl-Path-Tiny                       noarch  0.118-3.el9                        crb            67 k
 perl-Razor-Agent                     x86_64  2.86-1.el9                         epel          113 k
 perl-Ref-Util                        noarch  0.204-12.el9                       crb            25 k
 perl-Ref-Util-XS                     x86_64  0.117-13.el9                       crb            24 k
 perl-Regexp-Common                   noarch  2017060201-11.el9                  epel          192 k
 perl-Role-Tiny                       noarch  2.002004-4.el9                     crb            34 k
 perl-SQL-Abstract                    noarch  2.000001-9.el9                     epel          122 k
 perl-SQL-Interp                      noarch  1.27-6.el9                         epel           43 k
 perl-Scope-Guard                     noarch  0.21-18.el9                        crb            16 k
 perl-Sendmail-PMilter                noarch  1.24-1.eFa.el9                     eFa5-release   47 k
 perl-Socket6                         x86_64  0.29-11.el9                        appstream      32 k
 perl-Specio                          noarch  0.47-3.el9                         crb           171 k
 perl-Sub-Exporter-Progressive        noarch  0.001013-16.el9                    crb            22 k
 perl-Sub-Identify                    x86_64  0.14-17.el9                        crb            26 k
 perl-Sub-Quote                       noarch  2.006006-7.el9                     epel           34 k
 perl-Switch                          noarch  2.17-23.el9                        crb            27 k
 perl-Sys-Hostname-Long               noarch  1.5-1.eFa.el9                      eFa5-release   18 k
 perl-Sys-SigAction                   noarch  0.23-21.el9                        epel           33 k
 perl-TeX-Hyphen                      noarch  1.18-5.el9                         epel           36 k
 perl-Test-Deep                       noarch  1.130-6.el9                        crb            69 k
 perl-Test-File-ShareDir              noarch  1.001002-1.eFa.el9                 eFa5-release   43 k
 perl-Text-Aligner                    noarch  0.16-6.el9                         epel           20 k
 perl-Text-Autoformat                 noarch  1.750000-8.el9                     epel           45 k
 perl-Text-Reform                     noarch  1.20-32.el9                        epel           44 k
 perl-Text-Table                      noarch  1.134-7.el9                        epel           37 k
 perl-Text-Unidecode                  noarch  1.30-16.el9                        appstream     194 k
 perl-Throwable                       noarch  1:1.000-2.el9                      epel           29 k
 perl-TimeDate                        noarch  1:2.33-6.el9                       appstream      59 k
 perl-Try-Tiny                        noarch  0.30-13.el9                        appstream      39 k
 perl-Unicode-UTF8                    x86_64  0.62-16.el9                        crb            27 k
 perl-User-Identity                   noarch  1.02-1.el9                         epel           80 k
 perl-Variable-Magic                  x86_64  0.62-14.el9                        crb            54 k
 perl-WWW-RobotRules                  noarch  6.02-30.el9                        appstream      21 k
 perl-XML-LibXML                      x86_64  1:2.0206-5.el9                     appstream     372 k
 perl-XML-NamespaceSupport            noarch  1.12-15.el9                        appstream      27 k
 perl-XML-SAX                         noarch  1.02-8.el9                         appstream      63 k
 perl-XML-SAX-Base                    noarch  1.09-15.el9                        appstream      33 k
 perl-XString                         x86_64  0.005-4.el9                        crb            24 k
 perl-libwww-perl                     noarch  6.53-4.el9                         appstream     211 k
 perl-namespace-autoclean             noarch  0.29-8.el9                         crb            27 k
 perl-namespace-clean                 noarch  0.27-18.el9                        crb            34 k
 perl-strictures                      noarch  2.000006-4.el9                     epel           30 k
 perltidy                             noarch  20210111-4.el9                     crb           551 k
 php                                  x86_64  8.1.27-1.module_el9+790+4812d76d   appstream     4.7 k
 php-cli                              x86_64  8.1.27-1.module_el9+790+4812d76d   appstream     3.5 M
 php-common                           x86_64  8.1.27-1.module_el9+790+4812d76d   appstream     692 k
 php-fpm                              x86_64  8.1.27-1.module_el9+790+4812d76d   appstream     1.8 M
 php-gd                               x86_64  8.1.27-1.module_el9+790+4812d76d   appstream      41 k
 php-gmp                              x86_64  8.1.27-1.module_el9+790+4812d76d   appstream      31 k
 php-ldap                             x86_64  8.1.27-1.module_el9+790+4812d76d   appstream      42 k
 php-mbstring                         x86_64  8.1.27-1.module_el9+790+4812d76d   appstream     473 k
 php-mysqlnd                          x86_64  8.1.27-1.module_el9+790+4812d76d   appstream     145 k
 php-pdo                              x86_64  8.1.27-1.module_el9+790+4812d76d   appstream      83 k
 php-process                          x86_64  8.1.27-1.module_el9+790+4812d76d   appstream      41 k
 php-xml                              x86_64  8.1.27-1.module_el9+790+4812d76d   appstream     146 k
 policycoreutils-python-utils         noarch  3.6-2.1.el9                        baseos         77 k
 postfix                              x86_64  2:3.5.23-1.eFa.el9                 eFa5-release  1.4 M
 procmail                             x86_64  3.22-56.el9                        appstream     184 k
 protobuf-c                           x86_64  1.3.3-13.el9                       baseos         35 k
 python3-acme                         noarch  2.11.0-1.el9                       epel          159 k
 python3-audit                        x86_64  3.1.2-2.el9                        baseos         83 k
 python3-augeas                       noarch  0.5.0-25.el9                       appstream      28 k
 python3-certbot                      noarch  2.11.0-1.el9                       epel          685 k
 python3-certbot-apache               noarch  2.11.0-1.el9                       epel          285 k
 python3-cffi                         x86_64  1.14.5-5.el9                       baseos        253 k
 python3-chardet                      noarch  4.0.0-5.el9                        baseos        239 k
 python3-configargparse               noarch  1.7-1.el9                          epel           45 k
 python3-configobj                    noarch  5.0.6-25.el9                       appstream      63 k
 python3-cryptography                 x86_64  36.0.1-4.el9                       baseos        1.2 M
 python3-distro                       noarch  1.5.0-7.el9                        baseos         37 k
 python3-idna                         noarch  2.10-7.el9.1                       baseos        102 k
 python3-importlib-metadata           noarch  4.12.0-2.el9                       epel           43 k
 python3-josepy                       noarch  1.13.0-1.el9                       epel           60 k
 python3-libsemanage                  x86_64  3.6-1.el9                          baseos         80 k
 python3-parsedatetime                noarch  2.6-5.el9                          epel           79 k
 python3-ply                          noarch  3.11-14.el9                        baseos        106 k
 python3-policycoreutils              noarch  3.6-2.1.el9                        baseos        2.1 M
 python3-pyOpenSSL                    noarch  21.0.0-1.el9                       epel           90 k
 python3-pycparser                    noarch  2.20-6.el9                         baseos        135 k
 python3-pyrfc3339                    noarch  1.1-11.el9                         epel           18 k
 python3-pysocks                      noarch  1.7.1-12.el9                       baseos         35 k
 python3-pytz                         noarch  2021.1-5.el9                       appstream      51 k
 python3-requests                     noarch  2.25.1-8.el9                       baseos        125 k
 python3-setools                      x86_64  4.4.4-1.el9                        baseos        605 k
 python3-setuptools                   noarch  53.0.0-12.el9                      baseos        944 k
 python3-urllib3                      noarch  1.26.5-6.el9                       baseos        215 k
 python3-zipp                         noarch  0.5.1-1.el9                        epel           14 k
 pyzor                                noarch  1.0.0-39.20240609git2be00c3.el9    epel           79 k
 re2c                                 x86_64  2.2-1.el9                          epel          497 k
 rsync                                x86_64  3.2.3-20.el9                       baseos        397 k
 sendmail-milter                      x86_64  8.16.1-11.el9                      crb            39 k
 spamassassin                         x86_64  4.0.1-2.eFa.el9                    eFa5-release  1.3 M
 sqlgrey                              noarch  1:1.8.0-8.eFa.el9                  eFa5-release   65 k
 sqlgreywebinterface                  noarch  1:1.1.9-5.eFa.el9                  eFa5-release   18 k
 sscg                                 x86_64  3.0.0-7.el9                        appstream      46 k
 tar                                  x86_64  2:1.34-6.el9                       baseos        885 k
 tmpwatch                             x86_64  2.11-20.el9                        appstream      36 k
 tnef                                 x86_64  1:1.4.18-1.eFa.el9                 eFa5-release   52 k
 unbound                              x86_64  1.16.2-8.el9                       appstream     969 k
 unbound-libs                         x86_64  1.16.2-8.el9                       appstream     549 k
 unrar                                x86_64  6.2.5-1.eFa.el9                    eFa5-release  147 k
 virt-what                            x86_64  1.25-5.el9                         baseos         34 k
 xml-common                           noarch  0.6.3-58.el9                       appstream      32 k
Installing weak dependencies:
 apr-util-openssl                     x86_64  1.6.1-23.el9                       appstream      15 k
 geolite2-city                        noarch  20191217-6.el9                     appstream      23 M
 geolite2-country                     noarch  20191217-6.el9                     appstream     1.6 M
 mariadb-backup                       x86_64  3:10.5.22-1.el9                    appstream     6.5 M
 mariadb-gssapi-server                x86_64  3:10.5.22-1.el9                    appstream      16 k
 mariadb-server-utils                 x86_64  3:10.5.22-1.el9                    appstream     215 k
 mod_http2                            x86_64  2.0.26-2.el9                       appstream     163 k
 mod_lua                              x86_64  2.4.57-8.el9                       appstream      60 k
 perl-Class-XSAccessor                x86_64  1.19-25.el9                        crb            48 k
 perl-List-MoreUtils                  noarch  0.430-4.el9                        appstream      64 k
 php-opcache                          x86_64  8.1.27-1.module_el9+790+4812d76d   appstream     376 k
 python-josepy-doc                    noarch  1.13.0-1.el9                       epel           19 k
Transaction Summary
Install  334 Packages
Total download size: 125 M
Installed size: 731 M
Downloading Packages:
(1/334): chkconfig-1.24-1.el9.x86_64.rpm        487 kB/s | 179 kB     00:00
(2/334): checkpolicy-3.6-1.el9.x86_64.rpm       858 kB/s | 353 kB     00:00
(3/334): cyrus-sasl-plain-2.1.27-21.el9.x86_64. 468 kB/s |  24 kB     00:00
(4/334): cyrus-sasl-2.1.27-21.el9.x86_64.rpm    172 kB/s |  73 kB     00:00
(5/334): dnf-automatic-4.14.0-15.el9.noarch.rpm 640 kB/s |  32 kB     00:00
(6/334): graphite2-1.3.14-9.el9.x86_64.rpm      939 kB/s |  95 kB     00:00
(7/334): ipcalc-1.0.0-5.el9.x86_64.rpm          820 kB/s |  42 kB     00:00
(8/334): freetype-2.10.4-9.el9.x86_64.rpm       1.9 MB/s | 388 kB     00:00
(9/334): harfbuzz-2.7.4-10.el9.x86_64.rpm       2.5 MB/s | 624 kB     00:00
(10/334): libpng-1.6.37-12.el9.x86_64.rpm       1.1 MB/s | 117 kB     00:00
(11/334): libtirpc-1.3.3-6.el9.x86_64.rpm       1.7 MB/s |  93 kB     00:00
(12/334): mailcap-2.1.49-5.el9.noarch.rpm       649 kB/s |  33 kB     00:00
(13/334): policycoreutils-python-utils-3.6-2.1. 1.5 MB/s |  77 kB     00:00
(14/334): protobuf-c-1.3.3-13.el9.x86_64.rpm    693 kB/s |  35 kB     00:00
(15/334): python3-audit-3.1.2-2.el9.x86_64.rpm  1.6 MB/s |  83 kB     00:00
(16/334): python3-cffi-1.14.5-5.el9.x86_64.rpm  1.7 MB/s | 253 kB     00:00
(17/334): python3-chardet-4.0.0-5.el9.noarch.rp 2.2 MB/s | 239 kB     00:00
(18/334): python3-distro-1.5.0-7.el9.noarch.rpm 723 kB/s |  37 kB     00:00
(19/334): python3-idna-2.10-7.el9.1.noarch.rpm  1.9 MB/s | 102 kB     00:00
(20/334): python3-libsemanage-3.6-1.el9.x86_64. 1.4 MB/s |  80 kB     00:00
(21/334): python3-ply-3.11-14.el9.noarch.rpm    2.1 MB/s | 106 kB     00:00
(22/334): python3-cryptography-36.0.1-4.el9.x86 2.6 MB/s | 1.2 MB     00:00
(23/334): python3-pycparser-2.20-6.el9.noarch.r 1.3 MB/s | 135 kB     00:00
(24/334): python3-pysocks-1.7.1-12.el9.noarch.r 671 kB/s |  35 kB     00:00
(25/334): python3-requests-2.25.1-8.el9.noarch. 1.2 MB/s | 125 kB     00:00
(26/334): python3-setools-4.4.4-1.el9.x86_64.rp 2.0 MB/s | 605 kB     00:00
(27/334): python3-policycoreutils-3.6-2.1.el9.n 2.6 MB/s | 2.1 MB     00:00
(28/334): python3-urllib3-1.26.5-6.el9.noarch.r 2.0 MB/s | 215 kB     00:00
(29/334): rsync-3.2.3-20.el9.x86_64.rpm         2.0 MB/s | 397 kB     00:00
(30/334): python3-setuptools-53.0.0-12.el9.noar 2.4 MB/s | 944 kB     00:00
(31/334): virt-what-1.25-5.el9.x86_64.rpm       522 kB/s |  34 kB     00:00
(32/334): apr-1.7.0-12.el9.x86_64.rpm           1.2 MB/s | 123 kB     00:00
(33/334): apr-util-1.6.1-23.el9.x86_64.rpm      1.8 MB/s |  95 kB     00:00
(34/334): apr-util-bdb-1.6.1-23.el9.x86_64.rpm  257 kB/s |  13 kB     00:00
(35/334): tar-1.34-6.el9.x86_64.rpm             2.2 MB/s | 885 kB     00:00
(36/334): apr-util-openssl-1.6.1-23.el9.x86_64. 279 kB/s |  15 kB     00:00
(37/334): augeas-libs-1.13.0-5.el9.x86_64.rpm   2.3 MB/s | 455 kB     00:00
(38/334): bind-license-9.16.23-15.el9.noarch.rp 249 kB/s |  13 kB     00:00
(39/334): bind-utils-9.16.23-15.el9.x86_64.rpm  2.0 MB/s | 208 kB     00:00
(40/334): bind-libs-9.16.23-15.el9.x86_64.rpm   2.4 MB/s | 1.2 MB     00:00
(41/334): clucene-core-2.3.3.4-42.20130812.e8e3 2.4 MB/s | 587 kB     00:00
(42/334): cyrus-sasl-md5-2.1.27-21.el9.x86_64.r 838 kB/s |  43 kB     00:00
(43/334): centos-logos-httpd-90.8-1.el9.noarch. 2.4 MB/s | 1.5 MB     00:00
(44/334): emacs-filesystem-27.2-9.el9.noarch.rp 175 kB/s | 8.9 kB     00:00
(45/334): fontawesome-fonts-4.7.0-13.el9.noarch 2.0 MB/s | 205 kB     00:00
(46/334): fontconfig-2.14.0-2.el9.x86_64.rpm    2.0 MB/s | 297 kB     00:00
(47/334): fstrm-0.6.1-3.el9.x86_64.rpm          566 kB/s |  28 kB     00:00
(48/334): gd-2.3.2-3.el9.x86_64.rpm             1.3 MB/s | 132 kB     00:00
(49/334): libicu-67.1-9.el9.x86_64.rpm          2.6 MB/s | 9.6 MB     00:03
(50/334): geolite2-country-20191217-6.el9.noarc 2.4 MB/s | 1.6 MB     00:00
(51/334): httpd-2.4.57-8.el9.x86_64.rpm         939 kB/s |  48 kB     00:00
(52/334): dovecot-2.3.16-11.el9.x86_64.rpm      2.5 MB/s | 4.9 MB     00:01
(53/334): httpd-filesystem-2.4.57-8.el9.noarch. 213 kB/s |  13 kB     00:00
(54/334): httpd-tools-2.4.57-8.el9.x86_64.rpm   1.4 MB/s |  83 kB     00:00
(55/334): httpd-core-2.4.57-8.el9.x86_64.rpm    2.4 MB/s | 1.5 MB     00:00
(56/334): jbigkit-libs-2.1-23.el9.x86_64.rpm    979 kB/s |  53 kB     00:00
(57/334): libX11-common-1.7.0-9.el9.noarch.rpm  2.0 MB/s | 205 kB     00:00
(58/334): libXau-1.0.9-8.el9.x86_64.rpm         616 kB/s |  31 kB     00:00
(59/334): libXpm-3.5.13-10.el9.x86_64.rpm       1.1 MB/s |  59 kB     00:00
(60/334): libX11-1.7.0-9.el9.x86_64.rpm         2.2 MB/s | 646 kB     00:00
(61/334): libexttextcat-3.4.5-11.el9.x86_64.rpm 1.6 MB/s | 245 kB     00:00
(62/334): libmaxminddb-1.5.2-4.el9.x86_64.rpm   645 kB/s |  33 kB     00:00
(63/334): libstemmer-0-18.585svn.el9.x86_64.rpm 1.6 MB/s |  83 kB     00:00
(64/334): libtiff-4.4.0-12.el9.x86_64.rpm       1.9 MB/s | 198 kB     00:00
(65/334): libjpeg-turbo-2.0.90-7.el9.x86_64.rpm 523 kB/s | 175 kB     00:00
(66/334): libuv-1.42.0-2.el9.x86_64.rpm         1.5 MB/s | 148 kB     00:00
(67/334): libxcb-1.13.1-9.el9.x86_64.rpm        2.4 MB/s | 243 kB     00:00
(68/334): libwebp-1.2.0-8.el9.x86_64.rpm        1.8 MB/s | 277 kB     00:00
(69/334): libxslt-1.1.34-9.el9.x86_64.rpm       2.4 MB/s | 243 kB     00:00
(70/334): mariadb-10.5.22-1.el9.x86_64.rpm      2.3 MB/s | 1.6 MB     00:00
(71/334): mariadb-common-10.5.22-1.el9.x86_64.r 604 kB/s |  31 kB     00:00
(72/334): mariadb-connector-c-3.2.6-1.el9.x86_6 1.9 MB/s | 198 kB     00:00
(73/334): mariadb-connector-c-config-3.2.6-1.el 214 kB/s |  11 kB     00:00
(74/334): mariadb-errmsg-10.5.22-1.el9.x86_64.r 2.1 MB/s | 220 kB     00:00
(75/334): mariadb-gssapi-server-10.5.22-1.el9.x 310 kB/s |  16 kB     00:00
(76/334): mariadb-backup-10.5.22-1.el9.x86_64.r 2.6 MB/s | 6.5 MB     00:02
(77/334): mariadb-server-utils-10.5.22-1.el9.x8 2.1 MB/s | 215 kB     00:00
(78/334): mod_http2-2.0.26-2.el9.x86_64.rpm     1.6 MB/s | 163 kB     00:00
(79/334): mod_lua-2.4.57-8.el9.x86_64.rpm       1.2 MB/s |  60 kB     00:00
(80/334): mod_ssl-2.4.57-8.el9.x86_64.rpm       2.0 MB/s | 110 kB     00:00
(81/334): mysql-selinux-1.0.10-1.el9.noarch.rpm 721 kB/s |  37 kB     00:00
(82/334): nginx-filesystem-1.20.1-16.el9.noarch 184 kB/s | 9.3 kB     00:00
(83/334): perl-BSD-Resource-1.291.100-17.el9.x8 914 kB/s |  46 kB     00:00
(84/334): perl-Bit-Vector-7.4-24.el9.x86_64.rpm 1.7 MB/s | 169 kB     00:00
(85/334): perl-Carp-Clan-6.08-8.el9.noarch.rpm  506 kB/s |  25 kB     00:00
(86/334): perl-Class-Inspector-1.36-7.el9.noarc 618 kB/s |  32 kB     00:00
(87/334): perl-Clone-0.45-6.el9.x86_64.rpm      453 kB/s |  23 kB     00:00
(88/334): perl-Crypt-OpenSSL-Bignum-0.09-16.el9 802 kB/s |  43 kB     00:00
(89/334): perl-Crypt-OpenSSL-RSA-0.31-13.el9.x8 870 kB/s |  44 kB     00:00
(90/334): perl-Crypt-OpenSSL-Random-0.15-14.el9 550 kB/s |  27 kB     00:00
(91/334): perl-DBD-MariaDB-1.21-16.el9.x86_64.r 1.3 MB/s | 152 kB     00:00
(92/334): perl-DBD-MySQL-4.050-13.el9.x86_64.rp 1.5 MB/s | 147 kB     00:00
(93/334): perl-DBD-SQLite-1.66-5.el9.x86_64.rpm 1.9 MB/s | 195 kB     00:00
(94/334): perl-DBI-1.643-9.el9.x86_64.rpm       2.4 MB/s | 725 kB     00:00
(95/334): perl-Data-Dump-1.23-18.el9.noarch.rpm 663 kB/s |  34 kB     00:00
(96/334): perl-Date-Calc-6.4-20.el9.noarch.rpm  2.0 MB/s | 204 kB     00:00
(97/334): perl-Digest-HMAC-1.03-29.el9.noarch.r 341 kB/s |  17 kB     00:00
(98/334): perl-Encode-Detect-1.01-37.el9.x86_64 1.7 MB/s |  90 kB     00:00
(99/334): perl-Error-0.17029-7.el9.noarch.rpm   832 kB/s |  42 kB     00:00
(100/334): perl-Exporter-Tiny-1.002002-6.el9.no 1.0 MB/s |  54 kB     00:00
(101/334): perl-File-Listing-6.14-4.el9.noarch. 490 kB/s |  26 kB     00:00
(102/334): perl-File-ShareDir-1.118-4.el9.noarc 608 kB/s |  31 kB     00:00
(103/334): perl-HTML-Parser-3.76-3.el9.x86_64.r 2.3 MB/s | 124 kB     00:00
(104/334): perl-HTML-Tagset-3.20-47.el9.noarch. 288 kB/s |  19 kB     00:00
(105/334): perl-HTTP-Cookies-6.10-4.el9.noarch. 755 kB/s |  39 kB     00:00
(106/334): perl-HTTP-Date-6.05-7.el9.noarch.rpm 484 kB/s |  25 kB     00:00
(107/334): perl-HTTP-Message-6.29-3.el9.noarch. 1.8 MB/s |  99 kB     00:00
(108/334): perl-HTTP-Negotiate-6.01-30.el9.noar 400 kB/s |  20 kB     00:00
(109/334): mariadb-server-10.5.22-1.el9.x86_64. 2.5 MB/s | 9.7 MB     00:03
(110/334): perl-IO-HTML-1.004-4.el9.noarch.rpm  564 kB/s |  29 kB     00:00
(111/334): perl-IO-Multiplex-1.16-21.el9.noarch 530 kB/s |  27 kB     00:00
(112/334): perl-IO-Socket-INET6-2.72-24.el9.noa 524 kB/s |  29 kB     00:00
(113/334): perl-JSON-4.03-5.el9.noarch.rpm      1.8 MB/s |  96 kB     00:00
(114/334): perl-LWP-MediaTypes-6.04-9.el9.noarc 673 kB/s |  34 kB     00:00
(115/334): perl-LWP-Protocol-https-6.10-4.el9.n 446 kB/s |  22 kB     00:00
(116/334): perl-List-MoreUtils-0.430-4.el9.noar 1.2 MB/s |  64 kB     00:00
(117/334): perl-List-MoreUtils-XS-0.430-5.el9.x 1.2 MB/s |  63 kB     00:00
(118/334): perl-Mail-AuthenticationResults-2.20 1.3 MB/s |  68 kB     00:00
(119/334): perl-Mail-DKIM-1.20200907-4.el9.noar 2.0 MB/s | 205 kB     00:00
(120/334): perl-Mail-SPF-2.9.0-26.el9.noarch.rp 1.6 MB/s | 159 kB     00:00
(121/334): perl-MailTools-2.21-9.el9.noarch.rpm 2.1 MB/s | 111 kB     00:00
(122/334): perl-NTLM-1.09-30.el9.noarch.rpm     459 kB/s |  23 kB     00:00
(123/334): perl-Net-CIDR-Lite-0.22-2.el9.noarch 413 kB/s |  21 kB     00:00
(124/334): perl-Net-HTTP-6.21-3.el9.noarch.rpm  815 kB/s |  41 kB     00:00
(125/334): perl-Net-SMTP-SSL-1.04-16.el9.noarch 251 kB/s |  13 kB     00:00
(126/334): perl-Net-DNS-1.29-6.el9.noarch.rpm   2.0 MB/s | 401 kB     00:00
(127/334): perl-Net-Server-2.009-14.el9.noarch. 2.0 MB/s | 206 kB     00:00
(128/334): perl-Socket6-0.29-11.el9.x86_64.rpm  644 kB/s |  32 kB     00:00
(129/334): perl-NetAddr-IP-4.079-18.el9.x86_64. 1.3 MB/s | 135 kB     00:00
(130/334): perl-TimeDate-2.33-6.el9.noarch.rpm  1.1 MB/s |  59 kB     00:00
(131/334): perl-Text-Unidecode-1.30-16.el9.noar 1.9 MB/s | 194 kB     00:00
(132/334): perl-Try-Tiny-0.30-13.el9.noarch.rpm 766 kB/s |  39 kB     00:00
(133/334): perl-WWW-RobotRules-6.02-30.el9.noar 410 kB/s |  21 kB     00:00
(134/334): perl-XML-NamespaceSupport-1.12-15.el 522 kB/s |  27 kB     00:00
(135/334): perl-XML-SAX-1.02-8.el9.noarch.rpm   1.2 MB/s |  63 kB     00:00
(136/334): perl-XML-LibXML-2.0206-5.el9.x86_64. 2.4 MB/s | 372 kB     00:00
(137/334): perl-XML-SAX-Base-1.09-15.el9.noarch 646 kB/s |  33 kB     00:00
(138/334): php-8.1.27-1.module_el9+790+4812d76d  92 kB/s | 4.7 kB     00:00
(139/334): perl-libwww-perl-6.53-4.el9.noarch.r 2.1 MB/s | 211 kB     00:00
(140/334): php-common-8.1.27-1.module_el9+790+4 2.3 MB/s | 692 kB     00:00
(141/334): geolite2-city-20191217-6.el9.noarch. 2.6 MB/s |  23 MB     00:08
(142/334): php-gd-8.1.27-1.module_el9+790+4812d 794 kB/s |  41 kB     00:00
(143/334): php-gmp-8.1.27-1.module_el9+790+4812 616 kB/s |  31 kB     00:00
(144/334): php-ldap-8.1.27-1.module_el9+790+481 834 kB/s |  42 kB     00:00
(145/334): php-fpm-8.1.27-1.module_el9+790+4812 2.5 MB/s | 1.8 MB     00:00
(146/334): php-mbstring-8.1.27-1.module_el9+790 1.9 MB/s | 473 kB     00:00
(147/334): php-mysqlnd-8.1.27-1.module_el9+790+ 1.4 MB/s | 145 kB     00:00
(148/334): php-pdo-8.1.27-1.module_el9+790+4812 1.4 MB/s |  83 kB     00:00
(149/334): php-opcache-8.1.27-1.module_el9+790+ 2.4 MB/s | 376 kB     00:00
(150/334): php-process-8.1.27-1.module_el9+790+ 810 kB/s |  41 kB     00:00
(151/334): php-xml-8.1.27-1.module_el9+790+4812 1.4 MB/s | 146 kB     00:00
(152/334): procmail-3.22-56.el9.x86_64.rpm      1.8 MB/s | 184 kB     00:00
(153/334): php-cli-8.1.27-1.module_el9+790+4812 2.6 MB/s | 3.5 MB     00:01
(154/334): python3-augeas-0.5.0-25.el9.noarch.r 558 kB/s |  28 kB     00:00
(155/334): python3-configobj-5.0.6-25.el9.noarc 1.2 MB/s |  63 kB     00:00
(156/334): python3-pytz-2021.1-5.el9.noarch.rpm 1.0 MB/s |  51 kB     00:00
(157/334): sscg-3.0.0-7.el9.x86_64.rpm          894 kB/s |  46 kB     00:00
(158/334): tmpwatch-2.11-20.el9.x86_64.rpm      683 kB/s |  36 kB     00:00
(159/334): xml-common-0.6.3-58.el9.noarch.rpm   611 kB/s |  32 kB     00:00
(160/334): libmemcached-awesome-1.1.0-12.el9.x8 2.0 MB/s | 111 kB     00:00
(161/334): perl-B-Hooks-EndOfScope-0.24-15.el9. 775 kB/s |  42 kB     00:00
(162/334): perl-Class-Data-Inheritable-0.08-39. 270 kB/s |  14 kB     00:00
(163/334): unbound-libs-1.16.2-8.el9.x86_64.rpm 2.2 MB/s | 549 kB     00:00
(164/334): perl-Class-Method-Modifiers-2.13-8.e 926 kB/s |  49 kB     00:00
(165/334): perl-Class-Singleton-1.6-4.el9.noarc 551 kB/s |  28 kB     00:00
(166/334): perl-Class-Tiny-1.008-4.el9.noarch.r 563 kB/s |  30 kB     00:00
(167/334): perl-Class-XSAccessor-1.19-25.el9.x8 942 kB/s |  48 kB     00:00
(168/334): unbound-1.16.2-8.el9.x86_64.rpm      2.4 MB/s | 969 kB     00:00
(169/334): perl-Date-ISO8601-0.005-13.el9.noarc 414 kB/s |  21 kB     00:00
(170/334): perl-DateTime-1.54-4.el9.x86_64.rpm  1.3 MB/s | 131 kB     00:00
(171/334): perl-DateTime-TimeZone-SystemV-0.010 481 kB/s |  24 kB     00:00
(172/334): perl-DateTime-TimeZone-Tzfile-0.011- 414 kB/s |  21 kB     00:00
(173/334): perl-DateTime-TimeZone-2.62-1.el9.no 2.1 MB/s | 420 kB     00:00
(174/334): perl-Devel-CallChecker-0.008-14.el9. 485 kB/s |  24 kB     00:00
(175/334): perl-Devel-Caller-2.06-26.el9.x86_64 376 kB/s |  20 kB     00:00
(176/334): perl-Devel-GlobalDestruction-0.14-16 358 kB/s |  18 kB     00:00
(177/334): perl-Devel-LexAlias-0.05-27.el9.x86_ 347 kB/s |  17 kB     00:00
(178/334): perl-Devel-StackTrace-2.04-10.el9.no 590 kB/s |  31 kB     00:00
(179/334): perl-Dist-CheckConflicts-0.11-23.el9 477 kB/s |  25 kB     00:00
(180/334): perl-DynaLoader-Functions-0.003-13.e 394 kB/s |  20 kB     00:00
(181/334): perl-Eval-Closure-0.14-16.el9.noarch 491 kB/s |  25 kB     00:00
(182/334): perl-Exception-Class-1.44-13.el9.noa 836 kB/s |  43 kB     00:00
(183/334): perl-File-Copy-Recursive-0.45-7.el9. 528 kB/s |  27 kB     00:00
(184/334): perl-IO-String-1.08-43.el9.noarch.rp 361 kB/s |  18 kB     00:00
(185/334): perl-HTML-Tree-5.07-16.el9.noarch.rp 2.1 MB/s | 216 kB     00:00
(186/334): perl-IO-stringy-2.113-7.el9.noarch.r 1.3 MB/s |  67 kB     00:00
(187/334): perl-Import-Into-1.002005-19.el9.noa 360 kB/s |  18 kB     00:00
(188/334): perl-MIME-Types-2.18-4.el9.noarch.rp 1.3 MB/s |  69 kB     00:00
(189/334): perl-Module-Implementation-0.09-30.e 404 kB/s |  20 kB     00:00
(190/334): perl-Module-Pluggable-5.2-18.el9.noa 604 kB/s |  32 kB     00:00
(191/334): perl-Module-Runtime-0.016-13.el9.noa 485 kB/s |  24 kB     00:00
(192/334): perl-Net-DNS-Nameserver-1.29-6.el9.n 462 kB/s |  23 kB     00:00
(193/334): perl-Package-Stash-0.39-4.el9.noarch 669 kB/s |  34 kB     00:00
(194/334): perl-Package-Stash-XS-0.29-11.el9.x8 712 kB/s |  36 kB     00:00
(195/334): perl-PadWalker-2.5-4.el9.x86_64.rpm  553 kB/s |  27 kB     00:00
(196/334): perl-Params-Classify-0.015-14.el9.x8 646 kB/s |  33 kB     00:00
(197/334): perl-Params-ValidationCompiler-0.30- 777 kB/s |  39 kB     00:00
(198/334): perl-Path-Tiny-0.118-3.el9.noarch.rp 1.3 MB/s |  67 kB     00:00
(199/334): perl-Ref-Util-0.204-12.el9.noarch.rp 480 kB/s |  25 kB     00:00
(200/334): perl-Ref-Util-XS-0.117-13.el9.x86_64 440 kB/s |  24 kB     00:00
(201/334): perl-Role-Tiny-2.002004-4.el9.noarch 614 kB/s |  34 kB     00:00
(202/334): perl-Scope-Guard-0.21-18.el9.noarch. 282 kB/s |  16 kB     00:00
(203/334): perl-Specio-0.47-3.el9.noarch.rpm    1.7 MB/s | 171 kB     00:00
(204/334): perl-Sub-Exporter-Progressive-0.0010 424 kB/s |  22 kB     00:00
(205/334): perl-Sub-Identify-0.14-17.el9.x86_64 504 kB/s |  26 kB     00:00
(206/334): perl-Switch-2.17-23.el9.noarch.rpm   531 kB/s |  27 kB     00:00
(207/334): perl-Test-Deep-1.130-6.el9.noarch.rp 1.3 MB/s |  69 kB     00:00
(208/334): perl-Unicode-UTF8-0.62-16.el9.x86_64 545 kB/s |  27 kB     00:00
(209/334): perl-Variable-Magic-0.62-14.el9.x86_ 1.0 MB/s |  54 kB     00:00
(210/334): perl-XString-0.005-4.el9.x86_64.rpm  490 kB/s |  24 kB     00:00
(211/334): perl-namespace-autoclean-0.29-8.el9. 505 kB/s |  27 kB     00:00
(212/334): perl-namespace-clean-0.27-18.el9.noa 655 kB/s |  34 kB     00:00
(213/334): sendmail-milter-8.16.1-11.el9.x86_64 663 kB/s |  39 kB     00:00
(214/334): perl-DateTime-Locale-1.31-4.el9.noar 2.5 MB/s | 3.3 MB     00:01
(215/334): perltidy-20210111-4.el9.noarch.rpm   2.2 MB/s | 551 kB     00:00
(216/334): clamav-unofficial-sigs-7.2.5.1-1.eFa 100 kB/s |  56 kB     00:00
(217/334): MailWatch-1.2.23-2.eFa.el9.noarch.rp 1.2 MB/s | 1.1 MB     00:00
(218/334): MailScanner-5.5.1-5.eFa.el9.noarch.r 570 kB/s | 566 kB     00:00
(219/334): eFa-5.0.0-8.eFa.el9.noarch.rpm       1.0 MB/s |  97 kB     00:00
(220/334): perl-Encoding-FixLatin-1.04-1.eFa.el 258 kB/s |  24 kB     00:00
(221/334): dcc-2.3.168-1.eFa.el9.x86_64.rpm     1.7 MB/s | 820 kB     00:00
(222/334): perl-Geo-IP-1.51-1.eFa.el9.noarch.rp 817 kB/s |  77 kB     00:00
(223/334): perl-IP-Country-2.28-1.eFa.el9.noarc 3.0 MB/s | 290 kB     00:00
(224/334): perl-IP-Country-DB_File-3.03-1.eFa.e 301 kB/s |  29 kB     00:00
(225/334): perl-Mail-DMARC-1.20230215-1.eFa.el9 4.5 MB/s | 437 kB     00:00
(226/334): perl-Net-DNS-Resolver-Programmable-0 270 kB/s |  25 kB     00:00
(227/334): eFa-base-5.0.0-1.eFa.el9.noarch.rpm   21 MB/s |  11 MB     00:00
(228/334): perl-Net-IDN-Encode-2.500-1.eFa.el9. 896 kB/s | 101 kB     00:00
(229/334): perl-Net-LibIDN-0.12-1.eFa.el9.x86_6 290 kB/s |  27 kB     00:00
(230/334): perl-Sys-Hostname-Long-1.5-1.eFa.el9 191 kB/s |  18 kB     00:00
(231/334): perl-Sendmail-PMilter-1.24-1.eFa.el9 489 kB/s |  47 kB     00:00
(232/334): perl-Test-File-ShareDir-1.001002-1.e 458 kB/s |  43 kB     00:00
(233/334): spamassassin-4.0.1-2.eFa.el9.x86_64.  13 MB/s | 1.3 MB     00:00
(234/334): sqlgrey-1.8.0-8.eFa.el9.noarch.rpm   688 kB/s |  65 kB     00:00
(235/334): postfix-3.5.23-1.eFa.el9.x86_64.rpm  7.6 MB/s | 1.4 MB     00:00
(236/334): sqlgreywebinterface-1.1.9-5.eFa.el9. 193 kB/s |  18 kB     00:00
(237/334): tnef-1.4.18-1.eFa.el9.x86_64.rpm     557 kB/s |  52 kB     00:00
(238/334): unrar-6.2.5-1.eFa.el9.x86_64.rpm     1.5 MB/s | 147 kB     00:00
(239/334): certbot-2.11.0-1.el9.noarch.rpm      245 kB/s |  49 kB     00:00
(240/334): clamav-filesystem-1.0.6-1.el9.noarch 105 kB/s |  19 kB     00:00
(241/334): clamav-freshclam-1.0.6-1.el9.x86_64. 1.0 MB/s |  96 kB     00:00
(242/334): clamd-1.0.6-1.el9.x86_64.rpm         1.6 MB/s |  92 kB     00:00
(243/334): clamav-1.0.6-1.el9.x86_64.rpm        919 kB/s | 317 kB     00:00
(244/334): fail2ban-1.0.2-12.el9.noarch.rpm     161 kB/s | 8.8 kB     00:00
(245/334): fail2ban-firewalld-1.0.2-12.el9.noar 157 kB/s | 8.9 kB     00:00
(246/334): fail2ban-selinux-1.0.2-12.el9.noarch 582 kB/s |  29 kB     00:00
(247/334): fail2ban-sendmail-1.0.2-12.el9.noarc 155 kB/s |  12 kB     00:00
(248/334): clamav-lib-1.0.6-1.el9.x86_64.rpm    8.1 MB/s | 2.5 MB     00:00
(249/334): libbsd-0.12.2-1.el9.x86_64.rpm       1.6 MB/s | 120 kB     00:00
(250/334): fail2ban-server-1.0.2-12.el9.noarch. 3.3 MB/s | 444 kB     00:00
(251/334): libopendkim-2.11.0-0.36.el9.x86_64.r 1.2 MB/s |  70 kB     00:00
(252/334): libmd-1.1.0-1.el9.x86_64.rpm         700 kB/s |  46 kB     00:00
(253/334): libidn-1.38-4.el9.x86_64.rpm         2.7 MB/s | 191 kB     00:00
(254/334): libopendmarc-1.4.2-10.el9.x86_64.rpm 967 kB/s |  31 kB     00:00
(255/334): libspf2-1.2.11-11.20210922git4915c30 1.5 MB/s |  68 kB     00:00
(256/334): opendbx-1.4.6-31.el9.x86_64.rpm      702 kB/s |  52 kB     00:00
(257/334): opendmarc-1.4.2-10.el9.x86_64.rpm    1.5 MB/s | 101 kB     00:00
(258/334): opendkim-2.11.0-0.36.el9.x86_64.rpm  1.6 MB/s | 223 kB     00:00
(259/334): perl-Clone-Choose-0.010-13.el9.noarc 222 kB/s |  15 kB     00:00
(260/334): p7zip-16.02-21.el9.x86_64.rpm        3.9 MB/s | 641 kB     00:00
(261/334): perl-Convert-BinHex-1.125-13.el9.noa 1.3 MB/s |  44 kB     00:00
(262/334): perl-Config-Tiny-2.27-1.el9.noarch.r 438 kB/s |  30 kB     00:00
(263/334): p7zip-plugins-16.02-21.el9.x86_64.rp 4.6 MB/s | 988 kB     00:00
(264/334): perl-DBIx-Simple-1.37-16.el9.noarch. 719 kB/s |  43 kB     00:00
(265/334): perl-DBIx-XHTML_Table-1.49-19.el9.no 607 kB/s |  38 kB     00:00
(266/334): perl-Data-Dumper-Concise-2.023-17.el 466 kB/s |  23 kB     00:00
(267/334): perl-Data-IEEE754-0.02-8.el9.noarch. 319 kB/s |  17 kB     00:00
(268/334): perl-Data-Validate-IP-0.30-4.el9.noa 494 kB/s |  31 kB     00:00
(269/334): perl-Devel-ArgNames-0.03-25.el9.noar 183 kB/s |  12 kB     00:00
(270/334): perl-Devel-Cycle-1.12-16.el9.noarch. 220 kB/s |  17 kB     00:00
(271/334): perl-Email-Abstract-3.009-3.el9.noar 402 kB/s |  37 kB     00:00
(272/334): perl-Data-Printer-1.000004-7.el9.noa 763 kB/s | 140 kB     00:00
(273/334): perl-Email-Address-1.912-11.el9.noar 746 kB/s |  40 kB     00:00
(274/334): perl-Email-Date-Format-1.005-20.el9. 564 kB/s |  18 kB     00:00
(275/334): perl-Email-Address-XS-1.04-13.el9.x8 753 kB/s |  37 kB     00:00
(276/334): perl-Email-MIME-1.954-1.el9.noarch.r 862 kB/s |  55 kB     00:00
(277/334): perl-Email-MIME-Encodings-1.315-23.e 352 kB/s |  19 kB     00:00
(278/334): perl-Email-MIME-ContentType-1.026-4. 310 kB/s |  25 kB     00:00
(279/334): perl-Email-MessageID-1.406-20.el9.no 480 kB/s |  20 kB     00:00
(280/334): perl-Email-Sender-2.500-3.el9.noarch 1.3 MB/s |  92 kB     00:00
(281/334): perl-Filesys-Df-0.92-45.el9.x86_64.r 400 kB/s |  21 kB     00:00
(282/334): perl-Email-Simple-2.216-6.el9.noarch 472 kB/s |  34 kB     00:00
(283/334): perl-Geography-Countries-2009041301- 372 kB/s |  21 kB     00:00
(284/334): perl-Font-AFM-1.20-38.el9.noarch.rpm 289 kB/s |  21 kB     00:00
(285/334): perl-HTML-Formatter-2.16-17.el9.noar 738 kB/s |  52 kB     00:00
(286/334): perl-Hash-Ordered-0.014-1.el9.noarch 830 kB/s |  40 kB     00:00
(287/334): perl-Hash-Merge-0.302-4.el9.noarch.r 296 kB/s |  20 kB     00:00
(288/334): perl-List-AllUtils-0.19-7.el9.noarch 732 kB/s |  49 kB     00:00
(289/334): perl-List-SomeUtils-0.58-10.el9.noar 1.0 MB/s |  46 kB     00:00
(290/334): perl-List-UtilsBy-0.12-3.el9.noarch. 557 kB/s |  29 kB     00:00
(291/334): perl-Mail-Transport-3.005-1.el9.noar 927 kB/s |  56 kB     00:00
(292/334): perl-Mail-Message-3.013-2.el9.noarch 3.5 MB/s | 468 kB     00:00
(293/334): perl-MIME-tools-5.509-11.el9.noarch. 1.7 MB/s | 231 kB     00:00
(294/334): perl-Math-Int128-0.22-8.el9.x86_64.r 749 kB/s |  46 kB     00:00
(295/334): perl-Math-Int64-0.54-22.el9.x86_64.r 1.0 MB/s |  56 kB     00:00
(296/334): perl-MaxMind-DB-Reader-1.000014-9.el 618 kB/s |  33 kB     00:00
(297/334): perl-MaxMind-DB-Common-0.040001-9.el 315 kB/s |  24 kB     00:00
(298/334): perl-MaxMind-DB-Reader-XS-1.000009-3 631 kB/s |  34 kB     00:00
(299/334): perl-MooX-StrictConstructor-0.011-9. 509 kB/s |  24 kB     00:00
(300/334): perl-Moo-2.005004-3.el9.noarch.rpm   705 kB/s |  67 kB     00:00
(301/334): perl-Net-CIDR-0.21-1.el9.noarch.rpm  450 kB/s |  21 kB     00:00
(302/334): perl-MooX-Types-MooseLike-0.29-19.el 343 kB/s |  24 kB     00:00
(303/334): perl-Net-IP-1.26-20.el9.noarch.rpm   645 kB/s |  36 kB     00:00
(304/334): perl-Net-LibIDN2-1.01-7.el9.x86_64.r 547 kB/s |  33 kB     00:00
(305/334): perl-Net-Patricia-1.22-25.el9.x86_64 769 kB/s |  44 kB     00:00
(306/334): perl-OLE-Storage_Lite-0.20-7.el9.noa 568 kB/s |  30 kB     00:00
(307/334): perl-Razor-Agent-2.86-1.el9.x86_64.r 3.1 MB/s | 113 kB     00:00
(308/334): perl-Object-Accessor-0.48-26.el9.noa 393 kB/s |  23 kB     00:00
(309/334): perl-SQL-Abstract-2.000001-9.el9.noa 2.7 MB/s | 122 kB     00:00
(310/334): perl-Regexp-Common-2017060201-11.el9 3.7 MB/s | 192 kB     00:00
(311/334): perl-SQL-Interp-1.27-6.el9.noarch.rp 660 kB/s |  43 kB     00:00
(312/334): perl-Sys-SigAction-0.23-21.el9.noarc 519 kB/s |  33 kB     00:00
(313/334): perl-Sub-Quote-2.006006-7.el9.noarch 490 kB/s |  34 kB     00:00
(314/334): perl-TeX-Hyphen-1.18-5.el9.noarch.rp 818 kB/s |  36 kB     00:00
(315/334): perl-Text-Autoformat-1.750000-8.el9. 754 kB/s |  45 kB     00:00
(316/334): perl-Text-Aligner-0.16-6.el9.noarch. 321 kB/s |  20 kB     00:00
(317/334): perl-Text-Reform-1.20-32.el9.noarch. 619 kB/s |  44 kB     00:00
(318/334): perl-Text-Table-1.134-7.el9.noarch.r 474 kB/s |  37 kB     00:00
(319/334): perl-User-Identity-1.02-1.el9.noarch 1.3 MB/s |  80 kB     00:00
(320/334): perl-Throwable-1.000-2.el9.noarch.rp 326 kB/s |  29 kB     00:00
(321/334): python-josepy-doc-1.13.0-1.el9.noarc 576 kB/s |  19 kB     00:00
(322/334): perl-strictures-2.000006-4.el9.noarc 426 kB/s |  30 kB     00:00
(323/334): python3-acme-2.11.0-1.el9.noarch.rpm 2.1 MB/s | 159 kB     00:00
(324/334): python3-configargparse-1.7-1.el9.noa 1.3 MB/s |  45 kB     00:00
(325/334): python3-certbot-2.11.0-1.el9.noarch. 6.8 MB/s | 685 kB     00:00
(326/334): python3-importlib-metadata-4.12.0-2. 1.2 MB/s |  43 kB     00:00
(327/334): python3-parsedatetime-2.6-5.el9.noar 2.3 MB/s |  79 kB     00:00
(328/334): python3-certbot-apache-2.11.0-1.el9. 2.2 MB/s | 285 kB     00:00
(329/334): python3-josepy-1.13.0-1.el9.noarch.r 806 kB/s |  60 kB     00:00
(330/334): python3-pyrfc3339-1.1-11.el9.noarch. 539 kB/s |  18 kB     00:00
(331/334): python3-zipp-0.5.1-1.el9.noarch.rpm  405 kB/s |  14 kB     00:00
(332/334): python3-pyOpenSSL-21.0.0-1.el9.noarc 1.4 MB/s |  90 kB     00:00
(333/334): pyzor-1.0.0-39.20240609git2be00c3.el 1.2 MB/s |  79 kB     00:00
(334/334): re2c-2.2-1.el9.x86_64.rpm            3.6 MB/s | 497 kB     00:00
Mail2GoCa
Post by Mail2GoCa »
Total                                           6.1 MB/s | 125 MB     00:20
Extra Packages for Enterprise Linux 9 - x86_64  1.6 MB/s | 1.6 kB     00:00
Importing GPG key 0x3228467C:
 Userid     : "Fedora (epel9) <epel@fedoraproject.org>"
 Fingerprint: FF8A D134 4597 106E CE81 3B91 8A38 72BF 3228 467C
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
  Preparing        :                                                        1/1
  Installing       : perl-Module-Runtime-0.016-13.el9.noarch              1/334
  Installing       : php-common-8.1.27-1.module_el9+790+4812d76d.x86_     2/334
  Installing       : perl-DBI-1.643-9.el9.x86_64                          3/334
  Installing       : python3-setuptools-53.0.0-12.el9.noarch              4/334
  Installing       : perl-Try-Tiny-0.30-13.el9.noarch                     5/334
  Installing       : perl-Module-Implementation-0.09-30.el9.noarch        6/334
  Installing       : perl-Sub-Quote-2.006006-7.el9.noarch                 7/334
  Installing       : perl-IO-stringy-2.113-7.el9.noarch                   8/334
  Installing       : perl-Socket6-0.29-11.el9.x86_64                      9/334
  Installing       : perl-NetAddr-IP-4.079-18.el9.x86_64                 10/334
  Installing       : protobuf-c-1.3.3-13.el9.x86_64                      11/334
  Installing       : perl-DBD-SQLite-1.66-5.el9.x86_64                   12/334
  Installing       : php-cli-8.1.27-1.module_el9+790+4812d76d.x86_64     13/334
  Installing       : perl-Dist-CheckConflicts-0.11-23.el9.noarch         14/334
  Installing       : perl-Math-Int64-0.54-22.el9.x86_64                  15/334
  Installing       : clamav-lib-1.0.6-1.el9.x86_64                       16/334
  Running scriptlet: clamav-filesystem-1.0.6-1.el9.noarch                17/334
  Installing       : clamav-filesystem-1.0.6-1.el9.noarch                17/334
  Installing       : clamav-freshclam-1.0.6-1.el9.x86_64                 18/334
  Running scriptlet: clamav-freshclam-1.0.6-1.el9.x86_64                 18/334
  Installing       : perl-PadWalker-2.5-4.el9.x86_64                     19/334
  Installing       : perl-Devel-StackTrace-1:2.04-10.el9.noarch          20/334
  Installing       : perl-Class-Method-Modifiers-2.13-8.el9.noarch       21/334
  Installing       : perl-Role-Tiny-2.002004-4.el9.noarch                22/334
  Installing       : python3-pytz-2021.1-5.el9.noarch                    23/334
  Installing       : perl-TimeDate-1:2.33-6.el9.noarch                   24/334
  Installing       : perl-HTTP-Date-6.05-7.el9.noarch                    25/334
  Installing       : perl-Net-CIDR-Lite-0.22-2.el9.noarch                26/334
  Installing       : mariadb-connector-c-config-3.2.6-1.el9.noarch       27/334
  Installing       : mariadb-common-3:10.5.22-1.el9.x86_64               28/334
  Installing       : mariadb-connector-c-3.2.6-1.el9.x86_64              29/334
  Installing       : libmaxminddb-1.5.2-4.el9.x86_64                     30/334
  Running scriptlet: httpd-filesystem-2.4.57-8.el9.noarch                31/334
  Installing       : httpd-filesystem-2.4.57-8.el9.noarch                31/334
  Installing       : apr-1.7.0-12.el9.x86_64                             32/334
  Installing       : apr-util-bdb-1.6.1-23.el9.x86_64                    33/334
  Installing       : apr-util-openssl-1.6.1-23.el9.x86_64                34/334
  Installing       : apr-util-1.6.1-23.el9.x86_64                        35/334
  Installing       : python3-pyrfc3339-1.1-11.el9.noarch                 36/334
  Installing       : clamav-1.0.6-1.el9.x86_64                           37/334
  Running scriptlet: clamav-1.0.6-1.el9.x86_64                           37/334
  Installing       : perl-IO-Socket-INET6-2.72-24.el9.noarch             38/334
  Installing       : python3-distro-1.5.0-7.el9.noarch                   39/334
  Installing       : php-mbstring-8.1.27-1.module_el9+790+4812d76d.x8    40/334
  Installing       : php-pdo-8.1.27-1.module_el9+790+4812d76d.x86_64     41/334
  Installing       : perl-Net-LibIDN2-1.01-7.el9.x86_64                  42/334
  Installing       : perl-Geography-Countries-2009041301-34.el9.noarc    43/334
  Installing       : perl-Email-Address-XS-1.04-13.el9.x86_64            44/334
  Installing       : perl-Sys-Hostname-Long-1.5-1.eFa.el9.noarch         45/334
  Installing       : sendmail-milter-8.16.1-11.el9.x86_64                46/334
  Installing       : perl-Sub-Exporter-Progressive-0.001013-16.el9.no    47/334
  Installing       : perl-MIME-Types-2.18-4.el9.noarch                   48/334
  Installing       : perl-Date-ISO8601-0.005-13.el9.noarch               49/334
  Installing       : perl-XML-SAX-Base-1.09-15.el9.noarch                50/334
  Installing       : perl-XML-NamespaceSupport-1.12-15.el9.noarch        51/334
  Installing       : perl-Net-SMTP-SSL-1.04-16.el9.noarch                52/334
  Installing       : perl-MailTools-2.21-9.el9.noarch                    53/334
  Installing       : perl-Net-HTTP-6.21-3.el9.noarch                     54/334
  Installing       : perl-HTML-Tagset-3.20-47.el9.noarch                 55/334
  Installing       : perl-Encode-Detect-1.01-37.el9.x86_64               56/334
  Installing       : perl-Digest-HMAC-1.03-29.el9.noarch                 57/334
  Installing       : perl-Net-DNS-1.29-6.el9.noarch                      58/334
  Installing       : perl-Clone-0.45-6.el9.x86_64                        59/334
  Installing       : perl-Carp-Clan-6.08-8.el9.noarch                    60/334
  Installing       : perl-BSD-Resource-1.291.100-17.el9.x86_64           61/334
  Installing       : libwebp-1.2.0-8.el9.x86_64                          62/334
  Installing       : libjpeg-turbo-2.0.90-7.el9.x86_64                   63/334
  Installing       : python3-idna-2.10-7.el9.1.noarch                    64/334
  Installing       : mailcap-2.1.49-5.el9.noarch                         65/334
  Installing       : perl-LWP-MediaTypes-6.04-9.el9.noarch               66/334
  Installing       : libpng-2:1.6.37-12.el9.x86_64                       67/334
  Installing       : libicu-67.1-9.el9.x86_64                            68/334
  Running scriptlet: postfix-2:3.5.23-1.eFa.el9.x86_64                   69/334
  Installing       : postfix-2:3.5.23-1.eFa.el9.x86_64                   69/334
  Installing       : checkpolicy-3.6-1.el9.x86_64                        70/334
  Installing       : perl-Bit-Vector-7.4-24.el9.x86_64                   71/334
  Installing       : perl-Date-Calc-6.4-20.el9.noarch                    72/334
  Installing       : perl-Net-DNS-Nameserver-1.29-6.el9.noarch           73/334
  Installing       : perl-NTLM-1.09-30.el9.noarch                        74/334
  Installing       : perl-Devel-GlobalDestruction-0.14-16.el9.noarch     75/334
  Installing       : perl-Email-MessageID-1.406-20.el9.noarch            76/334
  Installing       : perl-IP-Country-2.28-1.eFa.el9.noarch               77/334
  Installing       : php-mysqlnd-8.1.27-1.module_el9+790+4812d76d.x86    78/334
  Installing       : httpd-tools-2.4.57-8.el9.x86_64                     79/334
  Installing       : httpd-core-2.4.57-8.el9.x86_64                      80/334
  Installing       : mod_lua-2.4.57-8.el9.x86_64                         81/334
  Installing       : perl-DBD-MariaDB-1.21-16.el9.x86_64                 82/334
  Installing       : perl-DBD-MySQL-4.050-13.el9.x86_64                  83/334
  Installing       : mariadb-errmsg-3:10.5.22-1.el9.x86_64               84/334
  Installing       : perl-Net-Patricia-1.22-25.el9.x86_64                85/334
  Installing       : perl-File-Listing-6.14-4.el9.noarch                 86/334
  Installing       : perl-Devel-Caller-2.06-26.el9.x86_64                87/334
  Installing       : perl-Devel-LexAlias-0.05-27.el9.x86_64              88/334
  Installing       : perl-Devel-ArgNames-0.03-25.el9.noarch              89/334
  Installing       : perl-Data-Dumper-Concise-2.023-17.el9.noarch        90/334
  Installing       : perl-Devel-Cycle-1.12-16.el9.noarch                 91/334
  Running scriptlet: clamd-1.0.6-1.el9.x86_64                            92/334
  Installing       : clamd-1.0.6-1.el9.x86_64                            92/334
  Installing       : perl-IP-Country-DB_File-3.03-1.eFa.el9.noarch       93/334
  Installing       : perl-Math-Int128-0.22-8.el9.x86_64                  94/334
  Running scriptlet: eFa-base-1:5.0.0-1.eFa.el9.noarch                   95/334
  Installing       : eFa-base-1:5.0.0-1.eFa.el9.noarch                   95/334
  Running scriptlet: unbound-libs-1.16.2-8.el9.x86_64                    96/334
  Installing       : unbound-libs-1.16.2-8.el9.x86_64                    96/334
Created symlink /etc/systemd/system/timers.target.wants/unbound-anchor.timer → /usr/lib/systemd/system/unbound-anchor.timer.
  Installing       : unbound-1.16.2-8.el9.x86_64                         97/334
  Running scriptlet: unbound-1.16.2-8.el9.x86_64                         97/334
  Installing       : perl-Data-Validate-IP-0.30-4.el9.noarch             98/334
  Installing       : perl-OLE-Storage_Lite-0.20-7.el9.noarch             99/334
  Installing       : perl-List-SomeUtils-0.58-10.el9.noarch             100/334
  Installing       : python3-setools-4.4.4-1.el9.x86_64                 101/334
  Installing       : perl-DBIx-XHTML_Table-1.49-19.el9.noarch           102/334
  Installing       : perl-SQL-Interp-1.27-6.el9.noarch                  103/334
  Installing       : php-gmp-8.1.27-1.module_el9+790+4812d76d.x86_64    104/334
  Installing       : php-ldap-8.1.27-1.module_el9+790+4812d76d.x86_64   105/334
  Installing       : php-opcache-8.1.27-1.module_el9+790+4812d76d.x86   106/334
  Installing       : php-process-8.1.27-1.module_el9+790+4812d76d.x86   107/334
  Installing       : perl-Import-Into-1.002005-19.el9.noarch            108/334
  Installing       : perl-Moo-2.005004-3.el9.noarch                     109/334
  Installing       : perl-Throwable-1:1.000-2.el9.noarch                110/334
  Installing       : perl-Module-Pluggable-2:5.2-18.el9.noarch          111/334
  Installing       : perl-Clone-Choose-0.010-13.el9.noarch              112/334
  Installing       : perl-Hash-Merge-0.302-4.el9.noarch                 113/334
  Installing       : perl-MooX-Types-MooseLike-0.29-19.el9.noarch       114/334
  Installing       : re2c-2.2-1.el9.x86_64                              115/334
  Installing       : pyzor-1.0.0-39.20240609git2be00c3.el9.noarch       116/334
  Installing       : python3-zipp-0.5.1-1.el9.noarch                    117/334
  Installing       : python3-importlib-metadata-4.12.0-2.el9.noarch     118/334
  Installing       : python3-parsedatetime-2.6-5.el9.noarch             119/334
  Installing       : python3-configargparse-1.7-1.el9.noarch            120/334
  Installing       : python-josepy-doc-1.13.0-1.el9.noarch              121/334
  Installing       : perl-strictures-2.000006-4.el9.noarch              122/334
  Installing       : perl-MooX-StrictConstructor-0.011-9.el9.noarch     123/334
  Installing       : perl-Text-Aligner-0.16-6.el9.noarch                124/334
  Installing       : perl-Text-Table-1.134-7.el9.noarch                 125/334
  Installing       : perl-TeX-Hyphen-1.18-5.el9.noarch                  126/334
  Installing       : perl-Text-Reform-1.20-32.el9.noarch                127/334
  Installing       : perl-Text-Autoformat-1.750000-8.el9.noarch         128/334
  Installing       : perl-Sys-SigAction-0.23-21.el9.noarch              129/334
  Installing       : perl-Regexp-Common-2017060201-11.el9.noarch        130/334
  Installing       : perl-Razor-Agent-2.86-1.el9.x86_64                 131/334
  Installing       : perl-Object-Accessor-1:0.48-26.el9.noarch          132/334
  Installing       : perl-Net-IP-1.26-20.el9.noarch                     133/334
  Installing       : perl-Net-CIDR-0.21-1.el9.noarch                    134/334
  Installing       : perl-List-UtilsBy-0.12-3.el9.noarch                135/334
  Installing       : perl-List-AllUtils-0.19-7.el9.noarch               136/334
  Installing       : perl-Hash-Ordered-0.014-1.el9.noarch               137/334
  Installing       : perl-User-Identity-1.02-1.el9.noarch               138/334
  Installing       : perl-Font-AFM-1.20-38.el9.noarch                   139/334
  Installing       : perl-Filesys-Df-0.92-45.el9.x86_64                 140/334
  Installing       : perl-Email-MIME-Encodings-1.315-23.el9.noarch      141/334
  Installing       : perl-Email-Date-Format-1.005-20.el9.noarch         142/334
  Installing       : perl-Email-Simple-2.216-6.el9.noarch               143/334
  Installing       : perl-Email-Address-1.912-11.el9.noarch             144/334
  Installing       : perl-Data-IEEE754-0.02-8.el9.noarch                145/334
  Installing       : perl-Convert-BinHex-1.125-13.el9.noarch            146/334
  Installing       : perl-MIME-tools-5.509-11.el9.noarch                147/334
  Installing       : perl-Config-Tiny-2.27-1.el9.noarch                 148/334
  Installing       : p7zip-plugins-16.02-21.el9.x86_64                  149/334
  Installing       : p7zip-16.02-21.el9.x86_64                          150/334
  Installing       : opendbx-1.4.6-31.el9.x86_64                        151/334
  Installing       : libspf2-1.2.11-11.20210922git4915c308.el9.x86_64   152/334
  Installing       : libmd-1.1.0-1.el9.x86_64                           153/334
  Installing       : libbsd-0.12.2-1.el9.x86_64                         154/334
  Installing       : libopendkim-2.11.0-0.36.el9.x86_64                 155/334
  Installing       : libopendmarc-1.4.2-10.el9.x86_64                   156/334
  Running scriptlet: opendmarc-1.4.2-10.el9.x86_64                      157/334
  Installing       : opendmarc-1.4.2-10.el9.x86_64                      157/334
  Installing       : unrar-6.2.5-1.eFa.el9.x86_64                       158/334
  Installing       : tnef-1:1.4.18-1.eFa.el9.x86_64                     159/334
  Installing       : perl-Sendmail-PMilter-1.24-1.eFa.el9.noarch        160/334
  Installing       : perl-Net-IDN-Encode-2.500-1.eFa.el9.noarch         161/334
  Installing       : perl-Net-DNS-Resolver-Programmable-0.009-1.eFa.e   162/334
  Installing       : perl-Geo-IP-1.51-1.eFa.el9.noarch                  163/334
  Installing       : perl-Encoding-FixLatin-1.04-1.eFa.el9.noarch       164/334
  Installing       : dcc-2.3.168-1.eFa.el9.x86_64                       165/334
  Running scriptlet: dcc-2.3.168-1.eFa.el9.x86_64                       165/334
  Running scriptlet: MailWatch-1:1.2.23-2.eFa.el9.noarch                166/334
  Installing       : MailWatch-1:1.2.23-2.eFa.el9.noarch                166/334
  Running scriptlet: MailScanner-5.5.1-5.eFa.el9.noarch                 167/334
  Installing       : MailScanner-5.5.1-5.eFa.el9.noarch                 167/334
  Installing       : perl-XString-0.005-4.el9.x86_64                    168/334
  Installing       : perl-Variable-Magic-0.62-14.el9.x86_64             169/334
  Installing       : perl-B-Hooks-EndOfScope-0.24-15.el9.noarch         170/334
  Installing       : perl-Unicode-UTF8-0.62-16.el9.x86_64               171/334
  Installing       : perl-Path-Tiny-0.118-3.el9.noarch                  172/334
  Installing       : perl-Test-Deep-1.130-6.el9.noarch                  173/334
  Installing       : perl-SQL-Abstract-2.000001-9.el9.noarch            174/334
  Installing       : perl-DBIx-Simple-1.37-16.el9.noarch                175/334
  Installing       : perl-Switch-2.17-23.el9.noarch                     176/334
  Installing       : perl-Sub-Identify-0.14-17.el9.x86_64               177/334
  Installing       : perl-Scope-Guard-0.21-18.el9.noarch                178/334
  Installing       : perl-Ref-Util-XS-0.117-13.el9.x86_64               179/334
  Installing       : perl-Ref-Util-0.204-12.el9.noarch                  180/334
  Installing       : perl-Package-Stash-XS-0.29-11.el9.x86_64           181/334
  Installing       : perl-Package-Stash-0.39-4.el9.noarch               182/334
  Installing       : perl-namespace-clean-0.27-18.el9.noarch            183/334
  Installing       : perl-namespace-autoclean-0.29-8.el9.noarch         184/334
  Installing       : perl-Data-Printer-1.000004-7.el9.noarch            185/334
  Installing       : perl-IO-String-1.08-43.el9.noarch                  186/334
  Installing       : perl-File-Copy-Recursive-0.45-7.el9.noarch         187/334
  Installing       : perl-DynaLoader-Functions-0.003-13.el9.noarch      188/334
  Installing       : perl-Devel-CallChecker-0.008-14.el9.x86_64         189/334
  Installing       : perl-Params-Classify-0.015-14.el9.x86_64           190/334
  Installing       : perl-DateTime-TimeZone-SystemV-0.010-14.el9.noar   191/334
  Installing       : perl-DateTime-TimeZone-Tzfile-0.011-14.el9.noarc   192/334
  Installing       : perl-Class-XSAccessor-1.19-25.el9.x86_64           193/334
  Installing       : perl-Class-Tiny-1.008-4.el9.noarch                 194/334
  Installing       : perl-Class-Singleton-1.6-4.el9.noarch              195/334
  Installing       : perl-Class-Data-Inheritable-0.08-39.el9.noarch     196/334
  Installing       : perl-Exception-Class-1.44-13.el9.noarch            197/334
  Installing       : libmemcached-awesome-1.1.0-12.el9.x86_64           198/334
  Running scriptlet: opendkim-2.11.0-0.36.el9.x86_64                    199/334
  Installing       : opendkim-2.11.0-0.36.el9.x86_64                    199/334
  Running scriptlet: xml-common-0.6.3-58.el9.noarch                     200/334
  Installing       : xml-common-0.6.3-58.el9.noarch                     200/334
  Installing       : tmpwatch-2.11-20.el9.x86_64                        201/334
  Installing       : sscg-3.0.0-7.el9.x86_64                            202/334
  Installing       : mod_ssl-1:2.4.57-8.el9.x86_64                      203/334
  Installing       : python3-configobj-5.0.6-25.el9.noarch              204/334
  Installing       : procmail-3.22-56.el9.x86_64                        205/334
  Installing       : perl-WWW-RobotRules-6.02-30.el9.noarch             206/334
  Installing       : perl-Text-Unidecode-1.30-16.el9.noarch             207/334
  Installing       : perl-Email-MIME-ContentType-1.026-4.el9.noarch     208/334
  Installing       : perl-Email-MIME-1.954-1.el9.noarch                 209/334
  Installing       : perl-List-MoreUtils-XS-0.430-5.el9.x86_64          210/334
  Installing       : perl-JSON-4.03-5.el9.noarch                        211/334
  Installing       : perl-Mail-AuthenticationResults-2.20210112-4.el9   212/334
  Installing       : perl-IO-Multiplex-1.16-21.el9.noarch               213/334
  Installing       : perl-Net-Server-2.009-14.el9.noarch                214/334
  Running scriptlet: sqlgrey-1:1.8.0-8.eFa.el9.noarch                   215/334
  Installing       : sqlgrey-1:1.8.0-8.eFa.el9.noarch                   215/334
  Installing       : perl-IO-HTML-1.004-4.el9.noarch                    216/334
  Installing       : perl-HTTP-Message-6.29-3.el9.noarch                217/334
  Installing       : perl-HTML-Parser-3.76-3.el9.x86_64                 218/334
  Installing       : perl-HTML-Tree-1:5.07-16.el9.noarch                219/334
  Installing       : perl-HTML-Formatter-2.16-17.el9.noarch             220/334
  Installing       : perl-Mail-Transport-3.005-1.el9.noarch             221/334
  Installing       : perl-Mail-Message-3.013-2.el9.noarch               222/334
  Installing       : perl-Email-Abstract-3.009-3.el9.noarch             223/334
  Installing       : perl-Email-Sender-1:2.500-3.el9.noarch             224/334
  Installing       : perltidy-20210111-4.el9.noarch                     225/334
  Installing       : perl-Eval-Closure-0.14-16.el9.noarch               226/334
  Installing       : perl-Params-ValidationCompiler-0.30-12.el9.noarc   227/334
  Installing       : perl-Specio-0.47-3.el9.noarch                      228/334
  Installing       : perl-HTTP-Cookies-6.10-4.el9.noarch                229/334
  Installing       : perl-HTTP-Negotiate-6.01-30.el9.noarch             230/334
  Installing       : perl-Exporter-Tiny-1.002002-6.el9.noarch           231/334
  Installing       : perl-List-MoreUtils-0.430-4.el9.noarch             232/334
  Installing       : perl-Error-1:0.17029-7.el9.noarch                  233/334
  Installing       : perl-Mail-SPF-2.9.0-26.el9.noarch                  234/334
  Running scriptlet: perl-Mail-SPF-2.9.0-26.el9.noarch                  234/334
  Installing       : perl-Data-Dump-1.23-18.el9.noarch                  235/334
  Installing       : perl-LWP-Protocol-https-6.10-4.el9.noarch          236/334
  Installing       : perl-libwww-perl-6.53-4.el9.noarch                 237/334
  Installing       : perl-XML-SAX-1.02-8.el9.noarch                     238/334
  Running scriptlet: perl-XML-SAX-1.02-8.el9.noarch                     238/334
  Installing       : perl-XML-LibXML-1:2.0206-5.el9.x86_64              239/334
  Running scriptlet: perl-XML-LibXML-1:2.0206-5.el9.x86_64              239/334
  Installing       : perl-Crypt-OpenSSL-Random-0.15-14.el9.x86_64       240/334
  Installing       : perl-Crypt-OpenSSL-Bignum-0.09-16.el9.x86_64       241/334
  Installing       : perl-Crypt-OpenSSL-RSA-0.31-13.el9.x86_64          242/334
  Installing       : perl-Mail-DKIM-1.20200907-4.el9.noarch             243/334
  Installing       : spamassassin-4.0.1-2.eFa.el9.x86_64                244/334
  Running scriptlet: spamassassin-4.0.1-2.eFa.el9.x86_64                244/334
  Installing       : perl-Class-Inspector-1.36-7.el9.noarch             245/334
  Installing       : perl-File-ShareDir-1.118-4.el9.noarch              246/334
  Installing       : perl-DateTime-Locale-1.31-4.el9.noarch             247/334
  Installing       : perl-DateTime-2:1.54-4.el9.x86_64                  248/334
  Installing       : perl-DateTime-TimeZone-2.62-1.el9.noarch           249/334
  Installing       : perl-MaxMind-DB-Common-0.040001-9.el9.noarch       250/334
  Installing       : perl-MaxMind-DB-Reader-XS-1.000009-3.el9.x86_64    251/334
  Installing       : perl-MaxMind-DB-Reader-1.000014-9.el9.x86_64       252/334
  Installing       : perl-Test-File-ShareDir-1.001002-1.eFa.el9.noarc   253/334
  Installing       : perl-Mail-DMARC-1.20230215-1.eFa.el9.noarch        254/334
  Running scriptlet: nginx-filesystem-1:1.20.1-16.el9.noarch            255/334
  Installing       : nginx-filesystem-1:1.20.1-16.el9.noarch            255/334
  Installing       : php-fpm-8.1.27-1.module_el9+790+4812d76d.x86_64    256/334
  Running scriptlet: php-fpm-8.1.27-1.module_el9+790+4812d76d.x86_64    256/334
  Installing       : libxslt-1.1.34-9.el9.x86_64                        257/334
  Installing       : php-xml-8.1.27-1.module_el9+790+4812d76d.x86_64    258/334
  Installing       : libuv-1:1.42.0-2.el9.x86_64                        259/334
  Installing       : libstemmer-0-18.585svn.el9.x86_64                  260/334
  Installing       : libexttextcat-3.4.5-11.el9.x86_64                  261/334
  Installing       : libXau-1.0.9-8.el9.x86_64                          262/334
  Installing       : libxcb-1.13.1-9.el9.x86_64                         263/334
  Installing       : libX11-common-1.7.0-9.el9.noarch                   264/334
  Installing       : libX11-1.7.0-9.el9.x86_64                          265/334
  Installing       : libXpm-3.5.13-10.el9.x86_64                        266/334
  Installing       : jbigkit-libs-2.1-23.el9.x86_64                     267/334
  Installing       : libtiff-4.4.0-12.el9.x86_64                        268/334
  Installing       : geolite2-country-20191217-6.el9.noarch             269/334
  Installing       : geolite2-city-20191217-6.el9.noarch                270/334
  Installing       : ipcalc-1.0.0-5.el9.x86_64                          271/334
  Installing       : fstrm-0.6.1-3.el9.x86_64                           272/334
  Installing       : fontawesome-fonts-1:4.7.0-13.el9.noarch            273/334
  Installing       : emacs-filesystem-1:27.2-9.el9.noarch               274/334
  Installing       : libidn-1.38-4.el9.x86_64                           275/334
  Installing       : perl-Net-LibIDN-0.12-1.eFa.el9.x86_64              276/334
  Installing       : cyrus-sasl-md5-2.1.27-21.el9.x86_64                277/334
  Installing       : clucene-core-2.3.3.4-42.20130812.e8e3d20git.el9.   278/334
  Installing       : centos-logos-httpd-90.8-1.el9.noarch               279/334
  Installing       : mod_http2-2.0.26-2.el9.x86_64                      280/334
  Installing       : httpd-2.4.57-8.el9.x86_64                          281/334
  Running scriptlet: httpd-2.4.57-8.el9.x86_64                          281/334
  Installing       : php-8.1.27-1.module_el9+790+4812d76d.x86_64        282/334
  Running scriptlet: sqlgreywebinterface-1:1.1.9-5.eFa.el9.noarch       283/334
  Installing       : sqlgreywebinterface-1:1.1.9-5.eFa.el9.noarch       283/334
  Installing       : bind-license-32:9.16.23-15.el9.noarch              284/334
  Installing       : bind-libs-32:9.16.23-15.el9.x86_64                 285/334
  Installing       : bind-utils-32:9.16.23-15.el9.x86_64                286/334
  Installing       : clamav-unofficial-sigs-1:7.2.5.1-1.eFa.el9.noarc   287/334
  Running scriptlet: clamav-unofficial-sigs-1:7.2.5.1-1.eFa.el9.noarc   287/334
  Installing       : augeas-libs-1.13.0-5.el9.x86_64                    288/334
  Installing       : python3-augeas-0.5.0-25.el9.noarch                 289/334
  Installing       : virt-what-1.25-5.el9.x86_64                        290/334
  Installing       : tar-2:1.34-6.el9.x86_64                            291/334
  Installing       : rsync-3.2.3-20.el9.x86_64                          292/334
  Installing       : python3-pysocks-1.7.1-12.el9.noarch                293/334
  Installing       : python3-urllib3-1.26.5-6.el9.noarch                294/334
  Installing       : python3-ply-3.11-14.el9.noarch                     295/334
  Installing       : python3-pycparser-2.20-6.el9.noarch                296/334
  Installing       : python3-cffi-1.14.5-5.el9.x86_64                   297/334
  Installing       : python3-cryptography-36.0.1-4.el9.x86_64           298/334
  Installing       : python3-pyOpenSSL-21.0.0-1.el9.noarch              299/334
  Installing       : python3-josepy-1.13.0-1.el9.noarch                 300/334
  Installing       : python3-libsemanage-3.6-1.el9.x86_64               301/334
  Installing       : python3-chardet-4.0.0-5.el9.noarch                 302/334
  Installing       : python3-requests-2.25.1-8.el9.noarch               303/334
  Installing       : python3-acme-2.11.0-1.el9.noarch                   304/334
  Installing       : python3-certbot-2.11.0-1.el9.noarch                305/334
  Installing       : certbot-2.11.0-1.el9.noarch                        306/334
  Running scriptlet: certbot-2.11.0-1.el9.noarch                        306/334
Created symlink /etc/systemd/system/timers.target.wants/certbot-renew.timer → /usr/lib/systemd/system/certbot-renew.timer.
Certbot auto renewal timer is not started by default.
Run 'systemctl start certbot-renew.timer' to enable automatic renewals.
  Installing       : python3-certbot-apache-2.11.0-1.el9.noarch         307/334
  Installing       : python3-audit-3.1.2-2.el9.x86_64                   308/334
  Installing       : python3-policycoreutils-3.6-2.1.el9.noarch         309/334
  Installing       : policycoreutils-python-utils-3.6-2.1.el9.noarch    310/334
  Running scriptlet: mysql-selinux-1.0.10-1.el9.noarch                  311/334
  Installing       : mysql-selinux-1.0.10-1.el9.noarch                  311/334
libsemanage.semanage_direct_install_info: Overriding mysql module at lower priority 100 with module at priority 200.
  Installing       : mariadb-3:10.5.22-1.el9.x86_64                     312/334
  Installing       : mariadb-backup-3:10.5.22-1.el9.x86_64              313/334
  Installing       : mariadb-gssapi-server-3:10.5.22-1.el9.x86_64       314/334
  Installing       : mariadb-server-utils-3:10.5.22-1.el9.x86_64        315/334
  Running scriptlet: mariadb-server-3:10.5.22-1.el9.x86_64              316/334
  Installing       : mariadb-server-3:10.5.22-1.el9.x86_64              316/334
  Running scriptlet: fail2ban-selinux-1.0.2-12.el9.noarch               317/334
  Installing       : fail2ban-selinux-1.0.2-12.el9.noarch               317/334
libsemanage.semanage_direct_install_info: Overriding fail2ban module at lower priority 100 with module at priority 200.
  Installing       : fail2ban-server-1.0.2-12.el9.noarch                318/334
  Running scriptlet: fail2ban-server-1.0.2-12.el9.noarch                318/334
  Installing       : fail2ban-firewalld-1.0.2-12.el9.noarch             319/334
  Installing       : fail2ban-sendmail-1.0.2-12.el9.noarch              320/334
  Installing       : fail2ban-1.0.2-12.el9.noarch                       321/334
  Installing       : libtirpc-1.3.3-6.el9.x86_64                        322/334
  Running scriptlet: dovecot-1:2.3.16-11.el9.x86_64                     323/334
  Installing       : dovecot-1:2.3.16-11.el9.x86_64                     323/334
  Installing       : graphite2-1.3.14-9.el9.x86_64                      324/334
  Installing       : harfbuzz-2.7.4-10.el9.x86_64                       325/334
  Installing       : freetype-2.10.4-9.el9.x86_64                       326/334
  Installing       : fontconfig-2.14.0-2.el9.x86_64                     327/334
  Running scriptlet: fontconfig-2.14.0-2.el9.x86_64                     327/334
  Installing       : gd-2.3.2-3.el9.x86_64                              328/334
  Installing       : php-gd-8.1.27-1.module_el9+790+4812d76d.x86_64     329/334
  Installing       : dnf-automatic-4.14.0-15.el9.noarch                 330/334
  Running scriptlet: dnf-automatic-4.14.0-15.el9.noarch                 330/334
  Installing       : cyrus-sasl-plain-2.1.27-21.el9.x86_64              331/334
  Running scriptlet: cyrus-sasl-2.1.27-21.el9.x86_64                    332/334
  Installing       : cyrus-sasl-2.1.27-21.el9.x86_64                    332/334
  Installing       : chkconfig-1.24-1.el9.x86_64                        333/334
  Running scriptlet: eFa-5.0.0-8.eFa.el9.noarch                         334/334
  Installing       : eFa-5.0.0-8.eFa.el9.noarch                         334/334
Preparing to install eFa
Configuring postfix...
Configuring postfix...done
Configuring MailScanner...
Configuring MailScanner...done
Configuring clamav...
ClamAV update process started at Sun Jul 14 12:20:30 2024
daily database available for download (remote version: 27336)
Testing database: '/var/lib/clamav/tmp.d28d939296/clamav-2e7b898c7973ec30edd9203b38bde678.tmp-daily.cvd' ...
Database test passed.
daily.cvd updated (version: 27336, sigs: 2064262, f-level: 90, builder: raynman)
main database available for download (remote version: 62)
Testing database: '/var/lib/clamav/tmp.d28d939296/clamav-2e01473e2471678c2446ddfc03ab6328.tmp-main.cvd' ...
main.cvd updated (version: 62, sigs: 6647427, f-level: 90, builder: sigmgr)
bytecode database available for download (remote version: 335)
Testing database: '/var/lib/clamav/tmp.d28d939296/clamav-3820fe213c548dcda55a4e07b32f67a9.tmp-bytecode.cvd' ...
bytecode.cvd updated (version: 335, sigs: 86, f-level: 90, builder: raynman)
Configuring clamav...done
Configuring spamassassin...
Configuring spamassassin...done
Configuring Apache...
Configuring Apache...Done
Configuring sqlgrey...
Configuring sqlgrey...done
Configuring MailWatch...
Configuring MailWatch...done
Configuring sgwi...
Configuring sgwi...done
Configuring pyzor...
Configuring pyzor...done
Configuring razor...
Configuring razor...done
Configuring dcc...
    overwriting existing entry
Configuring dcc...done
Configuring unbound...
Configuring unbound...done
Configuring automatic updates...
Configuring automatic updates...done
Configuring services...
Created symlink /etc/systemd/system/multi-user.target.wants/httpd.service → /usr/lib/systemd/system/httpd.service.
Created symlink /etc/systemd/system/multi-user.target.wants/php-fpm.service → /usr/lib/systemd/system/php-fpm.service.
Removed "/etc/systemd/system/multi-user.target.wants/crond.service".
Removed "/etc/systemd/system/multi-user.target.wants/chronyd.service".
Removed "/etc/systemd/system/multi-user.target.wants/firewalld.service".
Removed "/etc/systemd/system/dbus-org.fedoraproject.FirewallD1.service".
Configuring services...done
Created symlink /etc/systemd/system/multi-user.target.wants/eFaFirstBoot.service → /etc/systemd/system/eFaFirstBoot.service.
Configuring eFaInit...
Configuring eFaInit...done
Build completed!
Mail2GoCa
Re: SFTP broken after running EFA 5.0.0 install script
Post by Mail2GoCa »
  Running scriptlet: httpd-2.4.57-8.el9.x86_64                          334/334
  Running scriptlet: mysql-selinux-1.0.10-1.el9.noarch                  334/334
  Running scriptlet: fail2ban-selinux-1.0.2-12.el9.noarch               334/334
  Running scriptlet: dovecot-1:2.3.16-11.el9.x86_64                     334/334
  Running scriptlet: fontconfig-2.14.0-2.el9.x86_64                     334/334
  Verifying        : checkpolicy-3.6-1.el9.x86_64                         1/334
  Verifying        : chkconfig-1.24-1.el9.x86_64                          2/334
  Verifying        : cyrus-sasl-2.1.27-21.el9.x86_64                      3/334
  Verifying        : cyrus-sasl-plain-2.1.27-21.el9.x86_64                4/334
  Verifying        : dnf-automatic-4.14.0-15.el9.noarch                   5/334
  Verifying        : freetype-2.10.4-9.el9.x86_64                         6/334
  Verifying        : graphite2-1.3.14-9.el9.x86_64                        7/334
  Verifying        : harfbuzz-2.7.4-10.el9.x86_64                         8/334
  Verifying        : ipcalc-1.0.0-5.el9.x86_64                            9/334
  Verifying        : libicu-67.1-9.el9.x86_64                            10/334
  Verifying        : libpng-2:1.6.37-12.el9.x86_64                       11/334
  Verifying        : libtirpc-1.3.3-6.el9.x86_64                         12/334
  Verifying        : mailcap-2.1.49-5.el9.noarch                         13/334
  Verifying        : policycoreutils-python-utils-3.6-2.1.el9.noarch     14/334
  Verifying        : protobuf-c-1.3.3-13.el9.x86_64                      15/334
  Verifying        : python3-audit-3.1.2-2.el9.x86_64                    16/334
  Verifying        : python3-cffi-1.14.5-5.el9.x86_64                    17/334
  Verifying        : python3-chardet-4.0.0-5.el9.noarch                  18/334
  Verifying        : python3-cryptography-36.0.1-4.el9.x86_64            19/334
  Verifying        : python3-distro-1.5.0-7.el9.noarch                   20/334
  Verifying        : python3-idna-2.10-7.el9.1.noarch                    21/334
  Verifying        : python3-libsemanage-3.6-1.el9.x86_64                22/334
  Verifying        : python3-ply-3.11-14.el9.noarch                      23/334
  Verifying        : python3-policycoreutils-3.6-2.1.el9.noarch          24/334
  Verifying        : python3-pycparser-2.20-6.el9.noarch                 25/334
  Verifying        : python3-pysocks-1.7.1-12.el9.noarch                 26/334
  Verifying        : python3-requests-2.25.1-8.el9.noarch                27/334
  Verifying        : python3-setools-4.4.4-1.el9.x86_64                  28/334
  Verifying        : python3-setuptools-53.0.0-12.el9.noarch             29/334
  Verifying        : python3-urllib3-1.26.5-6.el9.noarch                 30/334
  Verifying        : rsync-3.2.3-20.el9.x86_64                           31/334
  Verifying        : tar-2:1.34-6.el9.x86_64                             32/334
  Verifying        : virt-what-1.25-5.el9.x86_64                         33/334
  Verifying        : apr-1.7.0-12.el9.x86_64                             34/334
  Verifying        : apr-util-1.6.1-23.el9.x86_64                        35/334
  Verifying        : apr-util-bdb-1.6.1-23.el9.x86_64                    36/334
  Verifying        : apr-util-openssl-1.6.1-23.el9.x86_64                37/334
  Verifying        : augeas-libs-1.13.0-5.el9.x86_64                     38/334
  Verifying        : bind-libs-32:9.16.23-15.el9.x86_64                  39/334
  Verifying        : bind-license-32:9.16.23-15.el9.noarch               40/334
  Verifying        : bind-utils-32:9.16.23-15.el9.x86_64                 41/334
  Verifying        : centos-logos-httpd-90.8-1.el9.noarch                42/334
  Verifying        : clucene-core-2.3.3.4-42.20130812.e8e3d20git.el9.    43/334
  Verifying        : cyrus-sasl-md5-2.1.27-21.el9.x86_64                 44/334
  Verifying        : dovecot-1:2.3.16-11.el9.x86_64                      45/334
  Verifying        : emacs-filesystem-1:27.2-9.el9.noarch                46/334
  Verifying        : fontawesome-fonts-1:4.7.0-13.el9.noarch             47/334
  Verifying        : fontconfig-2.14.0-2.el9.x86_64                      48/334
  Verifying        : fstrm-0.6.1-3.el9.x86_64                            49/334
  Verifying        : gd-2.3.2-3.el9.x86_64                               50/334
  Verifying        : geolite2-city-20191217-6.el9.noarch                 51/334
  Verifying        : geolite2-country-20191217-6.el9.noarch              52/334
  Verifying        : httpd-2.4.57-8.el9.x86_64                           53/334
  Verifying        : httpd-core-2.4.57-8.el9.x86_64                      54/334
  Verifying        : httpd-filesystem-2.4.57-8.el9.noarch                55/334
  Verifying        : httpd-tools-2.4.57-8.el9.x86_64                     56/334
  Verifying        : jbigkit-libs-2.1-23.el9.x86_64                      57/334
  Verifying        : libX11-1.7.0-9.el9.x86_64                           58/334
  Verifying        : libX11-common-1.7.0-9.el9.noarch                    59/334
  Verifying        : libXau-1.0.9-8.el9.x86_64                           60/334
  Verifying        : libXpm-3.5.13-10.el9.x86_64                         61/334
  Verifying        : libexttextcat-3.4.5-11.el9.x86_64                   62/334
  Verifying        : libjpeg-turbo-2.0.90-7.el9.x86_64                   63/334
  Verifying        : libmaxminddb-1.5.2-4.el9.x86_64                     64/334
  Verifying        : libstemmer-0-18.585svn.el9.x86_64                   65/334
  Verifying        : libtiff-4.4.0-12.el9.x86_64                         66/334
  Verifying        : libuv-1:1.42.0-2.el9.x86_64                         67/334
  Verifying        : libwebp-1.2.0-8.el9.x86_64                          68/334
  Verifying        : libxcb-1.13.1-9.el9.x86_64                          69/334
  Verifying        : libxslt-1.1.34-9.el9.x86_64                         70/334
  Verifying        : mariadb-3:10.5.22-1.el9.x86_64                      71/334
  Verifying        : mariadb-backup-3:10.5.22-1.el9.x86_64               72/334
  Verifying        : mariadb-common-3:10.5.22-1.el9.x86_64               73/334
  Verifying        : mariadb-connector-c-3.2.6-1.el9.x86_64              74/334
  Verifying        : mariadb-connector-c-config-3.2.6-1.el9.noarch       75/334
  Verifying        : mariadb-errmsg-3:10.5.22-1.el9.x86_64               76/334
  Verifying        : mariadb-gssapi-server-3:10.5.22-1.el9.x86_64        77/334
  Verifying        : mariadb-server-3:10.5.22-1.el9.x86_64               78/334
  Verifying        : mariadb-server-utils-3:10.5.22-1.el9.x86_64         79/334
  Verifying        : mod_http2-2.0.26-2.el9.x86_64                       80/334
  Verifying        : mod_lua-2.4.57-8.el9.x86_64                         81/334
  Verifying        : mod_ssl-1:2.4.57-8.el9.x86_64                       82/334
  Verifying        : mysql-selinux-1.0.10-1.el9.noarch                   83/334
  Verifying        : nginx-filesystem-1:1.20.1-16.el9.noarch             84/334
  Verifying        : perl-BSD-Resource-1.291.100-17.el9.x86_64           85/334
  Verifying        : perl-Bit-Vector-7.4-24.el9.x86_64                   86/334
  Verifying        : perl-Carp-Clan-6.08-8.el9.noarch                    87/334
  Verifying        : perl-Class-Inspector-1.36-7.el9.noarch              88/334
  Verifying        : perl-Clone-0.45-6.el9.x86_64                        89/334
  Verifying        : perl-Crypt-OpenSSL-Bignum-0.09-16.el9.x86_64        90/334
  Verifying        : perl-Crypt-OpenSSL-RSA-0.31-13.el9.x86_64           91/334
  Verifying        : perl-Crypt-OpenSSL-Random-0.15-14.el9.x86_64        92/334
  Verifying        : perl-DBD-MariaDB-1.21-16.el9.x86_64                 93/334
  Verifying        : perl-DBD-MySQL-4.050-13.el9.x86_64                  94/334
  Verifying        : perl-DBD-SQLite-1.66-5.el9.x86_64                   95/334
  Verifying        : perl-DBI-1.643-9.el9.x86_64                         96/334
  Verifying        : perl-Data-Dump-1.23-18.el9.noarch                   97/334
  Verifying        : perl-Date-Calc-6.4-20.el9.noarch                    98/334
  Verifying        : perl-Digest-HMAC-1.03-29.el9.noarch                 99/334
  Verifying        : perl-Encode-Detect-1.01-37.el9.x86_64              100/334
  Verifying        : perl-Error-1:0.17029-7.el9.noarch                  101/334
  Verifying        : perl-Exporter-Tiny-1.002002-6.el9.noarch           102/334
  Verifying        : perl-File-Listing-6.14-4.el9.noarch                103/334
  Verifying        : perl-File-ShareDir-1.118-4.el9.noarch              104/334
  Verifying        : perl-HTML-Parser-3.76-3.el9.x86_64                 105/334
  Verifying        : perl-HTML-Tagset-3.20-47.el9.noarch                106/334
  Verifying        : perl-HTTP-Cookies-6.10-4.el9.noarch                107/334
  Verifying        : perl-HTTP-Date-6.05-7.el9.noarch                   108/334
  Verifying        : perl-HTTP-Message-6.29-3.el9.noarch                109/334
  Verifying        : perl-HTTP-Negotiate-6.01-30.el9.noarch             110/334
  Verifying        : perl-IO-HTML-1.004-4.el9.noarch                    111/334
  Verifying        : perl-IO-Multiplex-1.16-21.el9.noarch               112/334
  Verifying        : perl-IO-Socket-INET6-2.72-24.el9.noarch            113/334
  Verifying        : perl-JSON-4.03-5.el9.noarch                        114/334
  Verifying        : perl-LWP-MediaTypes-6.04-9.el9.noarch              115/334
  Verifying        : perl-LWP-Protocol-https-6.10-4.el9.noarch          116/334
  Verifying        : perl-List-MoreUtils-0.430-4.el9.noarch             117/334
  Verifying        : perl-List-MoreUtils-XS-0.430-5.el9.x86_64          118/334
  Verifying        : perl-Mail-AuthenticationResults-2.20210112-4.el9   119/334
  Verifying        : perl-Mail-DKIM-1.20200907-4.el9.noarch             120/334
  Verifying        : perl-Mail-SPF-2.9.0-26.el9.noarch                  121/334
  Verifying        : perl-MailTools-2.21-9.el9.noarch                   122/334
  Verifying        : perl-NTLM-1.09-30.el9.noarch                       123/334
  Verifying        : perl-Net-CIDR-Lite-0.22-2.el9.noarch               124/334
  Verifying        : perl-Net-DNS-1.29-6.el9.noarch                     125/334
  Verifying        : perl-Net-HTTP-6.21-3.el9.noarch                    126/334
  Verifying        : perl-Net-SMTP-SSL-1.04-16.el9.noarch               127/334
  Verifying        : perl-Net-Server-2.009-14.el9.noarch                128/334
  Verifying        : perl-NetAddr-IP-4.079-18.el9.x86_64                129/334
  Verifying        : perl-Socket6-0.29-11.el9.x86_64                    130/334
  Verifying        : perl-Text-Unidecode-1.30-16.el9.noarch             131/334
  Verifying        : perl-TimeDate-1:2.33-6.el9.noarch                  132/334
  Verifying        : perl-Try-Tiny-0.30-13.el9.noarch                   133/334
  Verifying        : perl-WWW-RobotRules-6.02-30.el9.noarch             134/334
  Verifying        : perl-XML-LibXML-1:2.0206-5.el9.x86_64              135/334
  Verifying        : perl-XML-NamespaceSupport-1.12-15.el9.noarch       136/334
  Verifying        : perl-XML-SAX-1.02-8.el9.noarch                     137/334
  Verifying        : perl-XML-SAX-Base-1.09-15.el9.noarch               138/334
  Verifying        : perl-libwww-perl-6.53-4.el9.noarch                 139/334
  Verifying        : php-8.1.27-1.module_el9+790+4812d76d.x86_64        140/334
  Verifying        : php-cli-8.1.27-1.module_el9+790+4812d76d.x86_64    141/334
  Verifying        : php-common-8.1.27-1.module_el9+790+4812d76d.x86_   142/334
  Verifying        : php-fpm-8.1.27-1.module_el9+790+4812d76d.x86_64    143/334
  Verifying        : php-gd-8.1.27-1.module_el9+790+4812d76d.x86_64     144/334
  Verifying        : php-gmp-8.1.27-1.module_el9+790+4812d76d.x86_64    145/334
  Verifying        : php-ldap-8.1.27-1.module_el9+790+4812d76d.x86_64   146/334
  Verifying        : php-mbstring-8.1.27-1.module_el9+790+4812d76d.x8   147/334
  Verifying        : php-mysqlnd-8.1.27-1.module_el9+790+4812d76d.x86   148/334
  Verifying        : php-opcache-8.1.27-1.module_el9+790+4812d76d.x86   149/334
  Verifying        : php-pdo-8.1.27-1.module_el9+790+4812d76d.x86_64    150/334
  Verifying        : php-process-8.1.27-1.module_el9+790+4812d76d.x86   151/334
  Verifying        : php-xml-8.1.27-1.module_el9+790+4812d76d.x86_64    152/334
  Verifying        : procmail-3.22-56.el9.x86_64                        153/334
  Verifying        : python3-augeas-0.5.0-25.el9.noarch                 154/334
  Verifying        : python3-configobj-5.0.6-25.el9.noarch              155/334
  Verifying        : python3-pytz-2021.1-5.el9.noarch                   156/334
  Verifying        : sscg-3.0.0-7.el9.x86_64                            157/334
  Verifying        : tmpwatch-2.11-20.el9.x86_64                        158/334
  Verifying        : unbound-1.16.2-8.el9.x86_64                        159/334
  Verifying        : unbound-libs-1.16.2-8.el9.x86_64                   160/334
  Verifying        : xml-common-0.6.3-58.el9.noarch                     161/334
  Verifying        : libmemcached-awesome-1.1.0-12.el9.x86_64           162/334
  Verifying        : perl-B-Hooks-EndOfScope-0.24-15.el9.noarch         163/334
  Verifying        : perl-Class-Data-Inheritable-0.08-39.el9.noarch     164/334
  Verifying        : perl-Class-Method-Modifiers-2.13-8.el9.noarch      165/334
  Verifying        : perl-Class-Singleton-1.6-4.el9.noarch              166/334
  Verifying        : perl-Class-Tiny-1.008-4.el9.noarch                 167/334
  Verifying        : perl-Class-XSAccessor-1.19-25.el9.x86_64           168/334
  Verifying        : perl-Date-ISO8601-0.005-13.el9.noarch              169/334
  Verifying        : perl-DateTime-2:1.54-4.el9.x86_64                  170/334
  Verifying        : perl-DateTime-Locale-1.31-4.el9.noarch             171/334
  Verifying        : perl-DateTime-TimeZone-2.62-1.el9.noarch           172/334
  Verifying        : perl-DateTime-TimeZone-SystemV-0.010-14.el9.noar   173/334
  Verifying        : perl-DateTime-TimeZone-Tzfile-0.011-14.el9.noarc   174/334
  Verifying        : perl-Devel-CallChecker-0.008-14.el9.x86_64         175/334
  Verifying        : perl-Devel-Caller-2.06-26.el9.x86_64               176/334
  Verifying        : perl-Devel-GlobalDestruction-0.14-16.el9.noarch    177/334
  Verifying        : perl-Devel-LexAlias-0.05-27.el9.x86_64             178/334
  Verifying        : perl-Devel-StackTrace-1:2.04-10.el9.noarch         179/334
  Verifying        : perl-Dist-CheckConflicts-0.11-23.el9.noarch        180/334
  Verifying        : perl-DynaLoader-Functions-0.003-13.el9.noarch      181/334
  Verifying        : perl-Eval-Closure-0.14-16.el9.noarch               182/334
  Verifying        : perl-Exception-Class-1.44-13.el9.noarch            183/334
  Verifying        : perl-File-Copy-Recursive-0.45-7.el9.noarch         184/334
  Verifying        : perl-HTML-Tree-1:5.07-16.el9.noarch                185/334
  Verifying        : perl-IO-String-1.08-43.el9.noarch                  186/334
  Verifying        : perl-IO-stringy-2.113-7.el9.noarch                 187/334
  Verifying        : perl-Import-Into-1.002005-19.el9.noarch            188/334
  Verifying        : perl-MIME-Types-2.18-4.el9.noarch                  189/334
  Verifying        : perl-Module-Implementation-0.09-30.el9.noarch      190/334
  Verifying        : perl-Module-Pluggable-2:5.2-18.el9.noarch          191/334
  Verifying        : perl-Module-Runtime-0.016-13.el9.noarch            192/334
  Verifying        : perl-Net-DNS-Nameserver-1.29-6.el9.noarch          193/334
  Verifying        : perl-Package-Stash-0.39-4.el9.noarch               194/334
  Verifying        : perl-Package-Stash-XS-0.29-11.el9.x86_64           195/334
  Verifying        : perl-PadWalker-2.5-4.el9.x86_64                    196/334
  Verifying        : perl-Params-Classify-0.015-14.el9.x86_64           197/334
  Verifying        : perl-Params-ValidationCompiler-0.30-12.el9.noarc   198/334
  Verifying        : perl-Path-Tiny-0.118-3.el9.noarch                  199/334
  Verifying        : perl-Ref-Util-0.204-12.el9.noarch                  200/334
  Verifying        : perl-Ref-Util-XS-0.117-13.el9.x86_64               201/334
  Verifying        : perl-Role-Tiny-2.002004-4.el9.noarch               202/334
  Verifying        : perl-Scope-Guard-0.21-18.el9.noarch                203/334
  Verifying        : perl-Specio-0.47-3.el9.noarch                      204/334
  Verifying        : perl-Sub-Exporter-Progressive-0.001013-16.el9.no   205/334
  Verifying        : perl-Sub-Identify-0.14-17.el9.x86_64               206/334
  Verifying        : perl-Switch-2.17-23.el9.noarch                     207/334
  Verifying        : perl-Test-Deep-1.130-6.el9.noarch                  208/334
  Verifying        : perl-Unicode-UTF8-0.62-16.el9.x86_64               209/334
  Verifying        : perl-Variable-Magic-0.62-14.el9.x86_64             210/334
  Verifying        : perl-XString-0.005-4.el9.x86_64                    211/334
  Verifying        : perl-namespace-autoclean-0.29-8.el9.noarch         212/334
  Verifying        : perl-namespace-clean-0.27-18.el9.noarch            213/334
  Verifying        : perltidy-20210111-4.el9.noarch                     214/334
  Verifying        : sendmail-milter-8.16.1-11.el9.x86_64               215/334
  Verifying        : MailScanner-5.5.1-5.eFa.el9.noarch                 216/334
  Verifying        : MailWatch-1:1.2.23-2.eFa.el9.noarch                217/334
  Verifying        : clamav-unofficial-sigs-1:7.2.5.1-1.eFa.el9.noarc   218/334
  Verifying        : dcc-2.3.168-1.eFa.el9.x86_64                       219/334
  Verifying        : eFa-5.0.0-8.eFa.el9.noarch                         220/334
  Verifying        : eFa-base-1:5.0.0-1.eFa.el9.noarch                  221/334
  Verifying        : perl-Encoding-FixLatin-1.04-1.eFa.el9.noarch       222/334
  Verifying        : perl-Geo-IP-1.51-1.eFa.el9.noarch                  223/334
  Verifying        : perl-IP-Country-2.28-1.eFa.el9.noarch              224/334
  Verifying        : perl-IP-Country-DB_File-3.03-1.eFa.el9.noarch      225/334
  Verifying        : perl-Mail-DMARC-1.20230215-1.eFa.el9.noarch        226/334
  Verifying        : perl-Net-DNS-Resolver-Programmable-0.009-1.eFa.e   227/334
  Verifying        : perl-Net-IDN-Encode-2.500-1.eFa.el9.noarch         228/334
  Verifying        : perl-Net-LibIDN-0.12-1.eFa.el9.x86_64              229/334
  Verifying        : perl-Sendmail-PMilter-1.24-1.eFa.el9.noarch        230/334
  Verifying        : perl-Sys-Hostname-Long-1.5-1.eFa.el9.noarch        231/334
  Verifying        : perl-Test-File-ShareDir-1.001002-1.eFa.el9.noarc   232/334
  Verifying        : postfix-2:3.5.23-1.eFa.el9.x86_64                  233/334
  Verifying        : spamassassin-4.0.1-2.eFa.el9.x86_64                234/334
  Verifying        : sqlgrey-1:1.8.0-8.eFa.el9.noarch                   235/334
  Verifying        : sqlgreywebinterface-1:1.1.9-5.eFa.el9.noarch       236/334
  Verifying        : tnef-1:1.4.18-1.eFa.el9.x86_64                     237/334
  Verifying        : unrar-6.2.5-1.eFa.el9.x86_64                       238/334
  Verifying        : certbot-2.11.0-1.el9.noarch                        239/334
  Verifying        : clamav-1.0.6-1.el9.x86_64                          240/334
  Verifying        : clamav-filesystem-1.0.6-1.el9.noarch               241/334
  Verifying        : clamav-freshclam-1.0.6-1.el9.x86_64                242/334
  Verifying        : clamav-lib-1.0.6-1.el9.x86_64                      243/334
  Verifying        : clamd-1.0.6-1.el9.x86_64                           244/334
  Verifying        : fail2ban-1.0.2-12.el9.noarch                       245/334
  Verifying        : fail2ban-firewalld-1.0.2-12.el9.noarch             246/334
  Verifying        : fail2ban-selinux-1.0.2-12.el9.noarch               247/334
  Verifying        : fail2ban-sendmail-1.0.2-12.el9.noarch              248/334
  Verifying        : fail2ban-server-1.0.2-12.el9.noarch                249/334
  Verifying        : libbsd-0.12.2-1.el9.x86_64                         250/334
  Verifying        : libidn-1.38-4.el9.x86_64                           251/334
  Verifying        : libmd-1.1.0-1.el9.x86_64                           252/334
  Verifying        : libopendkim-2.11.0-0.36.el9.x86_64                 253/334
  Verifying        : libopendmarc-1.4.2-10.el9.x86_64                   254/334
  Verifying        : libspf2-1.2.11-11.20210922git4915c308.el9.x86_64   255/334
  Verifying        : opendbx-1.4.6-31.el9.x86_64                        256/334
  Verifying        : opendkim-2.11.0-0.36.el9.x86_64                    257/334
  Verifying        : opendmarc-1.4.2-10.el9.x86_64                      258/334
  Verifying        : p7zip-16.02-21.el9.x86_64                          259/334
  Verifying        : p7zip-plugins-16.02-21.el9.x86_64                  260/334
  Verifying        : perl-Clone-Choose-0.010-13.el9.noarch              261/334
  Verifying        : perl-Config-Tiny-2.27-1.el9.noarch                 262/334
  Verifying        : perl-Convert-BinHex-1.125-13.el9.noarch            263/334
  Verifying        : perl-DBIx-Simple-1.37-16.el9.noarch                264/334
  Verifying        : perl-DBIx-XHTML_Table-1.49-19.el9.noarch           265/334
  Verifying        : perl-Data-Dumper-Concise-2.023-17.el9.noarch       266/334
  Verifying        : perl-Data-IEEE754-0.02-8.el9.noarch                267/334
  Verifying        : perl-Data-Printer-1.000004-7.el9.noarch            268/334
  Verifying        : perl-Data-Validate-IP-0.30-4.el9.noarch            269/334
  Verifying        : perl-Devel-ArgNames-0.03-25.el9.noarch             270/334
  Verifying        : perl-Devel-Cycle-1.12-16.el9.noarch                271/334
  Verifying        : perl-Email-Abstract-3.009-3.el9.noarch             272/334
  Verifying        : perl-Email-Address-1.912-11.el9.noarch             273/334
  Verifying        : perl-Email-Address-XS-1.04-13.el9.x86_64           274/334
  Verifying        : perl-Email-Date-Format-1.005-20.el9.noarch         275/334
  Verifying        : perl-Email-MIME-1.954-1.el9.noarch                 276/334
  Verifying        : perl-Email-MIME-ContentType-1.026-4.el9.noarch     277/334
  Verifying        : perl-Email-MIME-Encodings-1.315-23.el9.noarch      278/334
  Verifying        : perl-Email-MessageID-1.406-20.el9.noarch           279/334
  Verifying        : perl-Email-Sender-1:2.500-3.el9.noarch             280/334
  Verifying        : perl-Email-Simple-2.216-6.el9.noarch               281/334
  Verifying        : perl-Filesys-Df-0.92-45.el9.x86_64                 282/334
  Verifying        : perl-Font-AFM-1.20-38.el9.noarch                   283/334
  Verifying        : perl-Geography-Countries-2009041301-34.el9.noarc   284/334
  Verifying        : perl-HTML-Formatter-2.16-17.el9.noarch             285/334
  Verifying        : perl-Hash-Merge-0.302-4.el9.noarch                 286/334
  Verifying        : perl-Hash-Ordered-0.014-1.el9.noarch               287/334
  Verifying        : perl-List-AllUtils-0.19-7.el9.noarch               288/334
  Verifying        : perl-List-SomeUtils-0.58-10.el9.noarch             289/334
  Verifying        : perl-List-UtilsBy-0.12-3.el9.noarch                290/334
  Verifying        : perl-MIME-tools-5.509-11.el9.noarch                291/334
  Verifying        : perl-Mail-Message-3.013-2.el9.noarch               292/334
  Verifying        : perl-Mail-Transport-3.005-1.el9.noarch             293/334
  Verifying        : perl-Math-Int128-0.22-8.el9.x86_64                 294/334
  Verifying        : perl-Math-Int64-0.54-22.el9.x86_64                 295/334
  Verifying        : perl-MaxMind-DB-Common-0.040001-9.el9.noarch       296/334
  Verifying        : perl-MaxMind-DB-Reader-1.000014-9.el9.x86_64       297/334
  Verifying        : perl-MaxMind-DB-Reader-XS-1.000009-3.el9.x86_64    298/334
  Verifying        : perl-Moo-2.005004-3.el9.noarch                     299/334
  Verifying        : perl-MooX-StrictConstructor-0.011-9.el9.noarch     300/334
  Verifying        : perl-MooX-Types-MooseLike-0.29-19.el9.noarch       301/334
  Verifying        : perl-Net-CIDR-0.21-1.el9.noarch                    302/334
  Verifying        : perl-Net-IP-1.26-20.el9.noarch                     303/334
  Verifying        : perl-Net-LibIDN2-1.01-7.el9.x86_64                 304/334
  Verifying        : perl-Net-Patricia-1.22-25.el9.x86_64               305/334
  Verifying        : perl-OLE-Storage_Lite-0.20-7.el9.noarch            306/334
  Verifying        : perl-Object-Accessor-1:0.48-26.el9.noarch          307/334
  Verifying        : perl-Razor-Agent-2.86-1.el9.x86_64                 308/334
  Verifying        : perl-Regexp-Common-2017060201-11.el9.noarch        309/334
  Verifying        : perl-SQL-Abstract-2.000001-9.el9.noarch            310/334
  Verifying        : perl-SQL-Interp-1.27-6.el9.noarch                  311/334
  Verifying        : perl-Sub-Quote-2.006006-7.el9.noarch               312/334
  Verifying        : perl-Sys-SigAction-0.23-21.el9.noarch              313/334
  Verifying        : perl-TeX-Hyphen-1.18-5.el9.noarch                  314/334
  Verifying        : perl-Text-Aligner-0.16-6.el9.noarch                315/334
  Verifying        : perl-Text-Autoformat-1.750000-8.el9.noarch         316/334
  Verifying        : perl-Text-Reform-1.20-32.el9.noarch                317/334
  Verifying        : perl-Text-Table-1.134-7.el9.noarch                 318/334
  Verifying        : perl-Throwable-1:1.000-2.el9.noarch                319/334
  Verifying        : perl-User-Identity-1.02-1.el9.noarch               320/334
  Verifying        : perl-strictures-2.000006-4.el9.noarch              321/334
  Verifying        : python-josepy-doc-1.13.0-1.el9.noarch              322/334
  Verifying        : python3-acme-2.11.0-1.el9.noarch                   323/334
  Verifying        : python3-certbot-2.11.0-1.el9.noarch                324/334
  Verifying        : python3-certbot-apache-2.11.0-1.el9.noarch         325/334
  Verifying        : python3-configargparse-1.7-1.el9.noarch            326/334
  Verifying        : python3-importlib-metadata-4.12.0-2.el9.noarch     327/334
  Verifying        : python3-josepy-1.13.0-1.el9.noarch                 328/334
  Verifying        : python3-parsedatetime-2.6-5.el9.noarch             329/334
  Verifying        : python3-pyOpenSSL-21.0.0-1.el9.noarch              330/334
  Verifying        : python3-pyrfc3339-1.1-11.el9.noarch                331/334
  Verifying        : python3-zipp-0.5.1-1.el9.noarch                    332/334
  Verifying        : pyzor-1.0.0-39.20240609git2be00c3.el9.noarch       333/334
  Verifying        : re2c-2.2-1.el9.x86_64                              334/334
Installed:
  clamav-unofficial-sigs-1:7.2.5.1-1.eFa.el9.noarch
  clucene-core-2.3.3.4-42.20130812.e8e3d20git.el9.x86_64
  perl-DateTime-TimeZone-SystemV-0.010-14.el9.noarch
  perl-DateTime-TimeZone-Tzfile-0.011-14.el9.noarch
  perl-Geography-Countries-2009041301-34.el9.noarch
  perl-Mail-AuthenticationResults-2.20210112-4.el9.noarch
  perl-Net-DNS-Resolver-Programmable-0.009-1.eFa.el9.noarch
  perl-Params-ValidationCompiler-0.30-12.el9.noarch
  perl-Sub-Exporter-Progressive-0.001013-16.el9.noarch
  perl-Test-File-ShareDir-1.001002-1.eFa.el9.noarch
  php-common-8.1.27-1.module_el9+790+4812d76d.x86_64
  php-mbstring-8.1.27-1.module_el9+790+4812d76d.x86_64
  php-mysqlnd-8.1.27-1.module_el9+790+4812d76d.x86_64
  php-opcache-8.1.27-1.module_el9+790+4812d76d.x86_64
  php-process-8.1.27-1.module_el9+790+4812d76d.x86_64
Complete!
2024.07.14-12:21:01 - eFa Installed
2024.07.14-12:21:01 - ============  EFA BUILD SCRIPT FINISHED  ============
2024.07.14-12:21:01 - ============  PLEASE REBOOT YOUR SYSTEM   ============
Do you wish to reboot the system now? (Y/N): N
[root@efa ~]#
Mail2GoCa
Post by Mail2GoCa »
After much head scratching and trial and error my frustration pushed me to try creating an alternate user with root privileges and trying that account instead. It works.
So, now the issue is more specific.
SFTP is broken for the root user only.
Any ideas?
Mail2GoCa
Post by Mail2GoCa »
I discovered the issue by accident. The SFTP authentication completes successfully but the connection is then terminated by the efa initial setup prompt.
I need to transfer the backup files from my efa4 server via SFTP or SCP because the sshfs transfer speed sucks.
I can get around it by transferring the backup files before running the install script or by using an alternate root user, but that's not a proper fix.
Any suggestions? Anybody?
@ShawnIverson ?
Trying SSH authentication PASSWORD
SSH authentication success!
SFTP connection started.
SSH server name: OpenSSH_8.7
STFP error #101: Invalid Packet{-----------------------------------------------------------------        Welcome to the eFa Initial Configuration        ---
STFP error #101: Invalid Packet{---               https://www.efa-project.org              -----------------------------------------------------------------
STFP error #101: Invalid Packet{--------------------------------------------------------------{00;32m[eFa][00m We will ask you a few questions to setup this system.
STFP error #101: Invalid Packet{{00;32m[eFa][00m Please make sure the system is connected to the internet.
STFP error #101: Invalid Packet{--------------------------------------------------------------{{00;32m[eFa][00m Start eFa first-time configure (Y/n) ->
Edit /root/.bashrc and comment out the /usr/sbin/eFa-Init .
Mail2GoCa
Post by Mail2GoCa »
That did it :D
Mail2GoCa
Post by Mail2GoCa »
Thank you @shawniverson
I am now on efa5 and all is working well so far :dance:
