Lipkowski Says Hello
New users please present your self here (no real names needed) so we can prevent spam bots.
lipkowski
Post by lipkowski »
Hello people.
I have been using EFA for MANY MANY years as a spam filter for incoming mail and as a smarthost relay for outgoing mail and it has worked VERY well in these capacities fronting for my VERY old FreeBSD mail server.
Thanks so much for it it is SO awesome and works so well.
You rock Shawn. Such solid work you have here.
Just saw that there is a new EFA 5 release in BETA.
CONGRATULATIONS!!!!
Anyways just wanted to say HI!
I am not much of a programmer so I am not sure I would actually be of much help to the project, but I do have a 200/200 dedicated pro network on FIOS with a couple of unused IP addresses so if there is any need for you people to up any test servers, I would be willing to host them here and also up the hardware that I have much of here.
I have nice low power (10 watt) quad core intel j1900 machines that can have 8 Gigabytes of DDR3 memory so they would likely make nice test chassis.
Dunno if that serves anyone's purposes here but I wanted to toss it out there as well as thanking everyone involved in this project cause it works so well.
Lip Lip Lip
Re: Lipkowski Says Hello
:text-welcomewave:
lipkowski
Post by lipkowski »
Hello. With the status of Linux 7's distribution being at EOL what is the future of EFA 4?
Are there plans for open source Devs to keep the CentOS 7 Distro patched into the future?
Also, will EFA 5 be based on a STREAM distro?
I am unfamiliar with the whole stream vs binary patching.
Does STREAM continuously change out your binaries according to what is on the distro's list of approved patched binaries?
Is EFA 5 based on one of the STREAM CentOS distros?
Thanks for all your great work.
DONATE PEOPLE!!!!
God bless Shawn and any other devs working on this software.
It is awesome and thanks!!
eFa 4 users on 7 will need to move to 8 or consider eFa 5 on 9. eFa 4 on CentOS 7 will no longer be maintained.
eFa 5 should work on any Red Hat Linux 9 compatible distribution. You don't have to use CentOS 9 Stream. You could opt for Rocky, AlmaLinux, Oracle, or even Red Hat.
CentOS 9 Stream tracks ahead of Red Hat Linux 9. It means that the wider community contributes to CentOS 9 Stream, after which Red Hat reviews packages for inclusion into Red Hat Linux 9. For that reason many folks are not comfortable using Stream for production.
lipkowski
Post by lipkowski »
So I am assuming that I can somehow take this EFA4 on CentOS 7 I am using now, and move it to 5 by taking the configuration from 4 and moving it to a fresh EFA5 box running on one of the suggested operating systems?
So there must be a configuration export routine somewhere?
