Supress daily DMARC reports
VAXman65
Post by VAXman65 »
In viewtopic.php?t=5144 we discussed suppressing the daily DMARC reports because it generated so many outbound emails. I think this issue would come up from time to time for home users that have to endure an ISP that does not permit outbound SMTP. For such situations, a proxy service is required and these will likely meter usage of their proxy (i.e. $$).
We were able to identify the /etc/cron.daily/eFa-Daily-DMARC job as being the culprit and skipping the job as the fix. While this works, it gets put back in place any time there is a software update. I also tried modifying the script it points to to bypass one line:
#/usr/sbin/opendmarc-reports -dbhost=${DBHOST} -dbuser=${DBUSER} -dbpasswd=${DBPASS} -dbname=${DBNAME} -interval=86400 -report-email $DMARCRepEmail -report-org $DMARCRepDomain -smtp-server=127.0.0.1 >/dev/null 2>&1
but this also gets put back with software updates.
Can we get a parameter to govern execution of this script or at least this one line in it? That way, the big consumer of SMTP sending quota is controlled and it will survive software updates
Re: Supress daily DMARC reports
In update 4.0.4-43, you will find a setting at /etc/sysconfig/eFa-Daily-DMARC
SENDREPORTS="yes"
Set this to "no" to suppress the daily reports.
VAXman65
Post by VAXman65 »
Thank you!
