Milter Multithread
Milter Multithread
Post by nicola.piazzi »
In some hours of the day my efa take long time to deliver because to much emails incoming accumulate on Milter Inbound
Screenshot 2024-04-11 173859.png (3.62 KiB) Viewed 41432 times
I found that mysqld daemon is at 100% of a single cpu also i have 16 cpu on box
I think that this is milter problem that cant split on more queues, is possible to have more milter ?
Screenshot 2024-04-11 174007.png (20.79 KiB) Viewed 41432 times
Re: Milter Multithread
Hi Nicolca,
can you show your Mysql config
/etc/my.cnf.d/mariadb-server.cnf
My config
# This group is only read by MariaDB-10.1 servers.
# If you use the same .cnf file for MariaDB of different versions,
# use this group for options that older servers don't understand
#[mariadb-10.1]
[mariadb-10.4]
bind-address = 127.0.0.1
innodb-defragment = 1
innodb_buffer_pool_instances = 1
innodb_buffer_pool_size = 1G
innodb_file_per_table = 1
innodb_log_buffer_size = 32M
innodb_log_file_size = 125M
join_buffer_size = 512K
key_cache_segments = 4
max_allowed_packet = 16M
max_heap_table_size = 32M
query_cache_size = 0M
query_cache_type = OFF
read_buffer_size = 2M
read_rnd_buffer_size = 1M
skip-external-locking
skip-host-cache
sort_buffer_size = 4M
thread_cache_size = 16
tmp_table_size = 32M
skip-name-resolve
and Mysqltuner ouput?
Sice there's swapfile use, check
cat /etc/sysctl.d/vm.swappiness.conf
Source and howto: https://mariadb.com/kb/en/configuring-swappiness/
(Assuming your Unbound recursive DNS service is checked and ok and you checked the logfiles)
Little DNS check script to check basics
viewtopic.php?t=3032
I agree with henk this isn't a milter problem. The Milter Inbound count are emails that are in the queue after being processed by the milter, so the bottleneck is elsewhere.
Are you on the latest release of eFa 4? There are some performance fixes that will directly impact mariadb utilization as well.
