Installed and mostly working but I have this in the maillog
warning: connect to Milter service inet:localhost:8891: Connection refused
I see some others have had this but not recently. all daemons are running but none listening on that port, nor on 8893.
Should I post this in another area? Or is this how "Introduction" works?
First install mostly worked
Re: First install mostly worked
Small bug during installation that I'm fixing.
Edit /etc/opendkim.conf and switch the Socket as follows:
Socket inet:8891@localhost
I did that, then did
systemctl restart opendkim
Then did similar fix for port 8893 in /etc/opendmarc.conf and
systemctl restart opendmarc
Seems to be sending mail now
