inline signature problem
sniphoe
Post by sniphoe »
Hi Team!
After upgrading from v3 to v4 the inline signature links stopped working.
When I click on them, they redirect me to http://efa.domain.com/mailscanner/login ... agetimeout and I got the login screen and the "Login page timed out, Please try again" error.
This is an example, does it seem to be fine? http://efa.domain.com/mailscanner/eFa-l ... jz55BPc&r=
Thx in advance!
Re: inline signature problem
The link looks incomplete, missing the security token.
sniphoe
Post by sniphoe »
Thank you for your reply!
This was my thought too after checking the v3 links. Any idea how to add the security token manually?
/usr/share/MailScanner/perl/custom/CustomAction.pm should control the addition of the token.
In order for this to work properly, check your /etc/MailScanner/MailScanner.conf:
This should be set to No since it is going to be done with a custom action.
Sign Clean Messages = No
This line should have custom(nonspam) at the end to generate the token.
This configuration is set based on options you choose in eFa-Configure.
