as described in mailscanner howto it does not work at eFa.
###snip
To: allowed_recipient@example.org
Allow Password-Protected Archives = yes
snip###
Found post "Releasing a password protected archive? (quarantine stored)" that does half of the job, doing exceptions for whole domains but not for specific sender/receipient.
DOES work in eFa; (but only for whole domains), but I do not understand the syntax??
###snip
To: /[\@\-]receipient\.com$/ yes
snip###
What I want is to make exceptions for Domains and single email addesses and mixed like;
To: receipient1.com
To: name@receipient2.com
To: receipient3.com
To: name@receipient4.com
Any idea of the correct syntax in eFa?
allow password protected zip files for secific senders
Re: allow password protected zip files for secific senders
Is it possible to do this?
