default opendkim configuration:
/etc/opendkim/opendkim.conf
Socket = local:/run/opendkim/opendkim.sockCode: Select all
smtpd_milters = local:/run/opendkim/opendkim.conf, (etc)Code: Select all
systemctl restart opendkim postfixCode: Select all
antispam postfix/cleanup[4443]: warning: connect to Milter service local:/run/opendkim/opendkim.sock: Permission deniedCode: Select all
ls -al /run/opendkim
drwxr-x---. 2 opendkim opendkim 80 Aug 22 18:36 .
drwxr-xr-x. 40 root root 1060 Aug 22 18:36 ..
-rw-r--r--. 1 opendkim opendkim 5 Aug 22 18:36 opendkim.pid
srwxrwx---. 1 opendkim opendkim 0 Aug 22 18:36 opendkim.sockCode: Select all
usermod -aG opendkim postfixCode: Select all
antispam MailScanner[7564]: Unable to openQMQP socket /var/spool/postfix/public/qmqp
antispam MailScanner[7564]: Unable to kick mesage /var/spool/MailScanner/milterout/4RVZYZ71VszG1mh, will retry soonCode: Select all
antispam opendkim[7827]: Cannot open /var/spool/MailScanner/milterout/4RVZYZ71VszG1mh for relaying, will try again laterNote: I already tried using inet:localhost and it works flawlessly, but I wanted to try a different configuration, knowing that is more efficient when dealing with a ton of mails.
Thanks in advance.
