To get right to the detail, here is the final status:
Error: Transaction test error:
file /etc/centos-release from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
file /etc/redhat-release from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
file /etc/system-release from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
file /etc/system-release-cpe from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
file /usr/lib/os-release from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
file /usr/lib/systemd/system-preset/85-display-manager.preset from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
file /usr/lib/systemd/system-preset/90-default.preset from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
file /usr/lib/systemd/system-preset/99-default-disable.preset from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
file /usr/share/redhat-release from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarchI did ask about the future of the platform giving the changes Red Hat did with the sources and that both AlmaLinux and RockyLinux are still on a path.
I look forward to reading more.....
If you want to see all the log detail, here:
Update now, are you sure? (y/N): y
Last metadata expiration check: 2:32:29 ago on Sun 09 Jul 2023 08:26:13 AM CDT.
Dependencies resolved.
Package Architecture Version Repository Size
Upgrading:
NetworkManager x86_64 1:1.40.16-8.el8 stream-baseos 2.3 M
NetworkManager-initscripts-updown noarch 1:1.40.16-8.el8 stream-baseos 143 k
NetworkManager-libnm x86_64 1:1.40.16-8.el8 stream-baseos 1.9 M
apr-util x86_64 1.6.1-9.el8 stream-appstream 106 k
apr-util-bdb x86_64 1.6.1-9.el8 stream-appstream 25 k
apr-util-openssl x86_64 1.6.1-9.el8 stream-appstream 27 k
binutils x86_64 2.30-121.el8 stream-baseos 5.9 M
chkconfig x86_64 1.19.2-1.el8 stream-baseos 217 k
cpp x86_64 8.5.0-20.el8 stream-baseos 10 M
curl x86_64 7.61.1-30.el8_8.2 baseos 352 k
dbus x86_64 1:1.12.8-25.el8 stream-baseos 38 k
dbus-common noarch 1:1.12.8-25.el8 stream-baseos 47 k
dbus-daemon x86_64 1:1.12.8-25.el8 stream-baseos 246 k
dbus-libs x86_64 1:1.12.8-25.el8 stream-baseos 185 k
dbus-tools x86_64 1:1.12.8-25.el8 stream-baseos 87 k
dnf noarch 4.7.0-18.el8 stream-baseos 552 k
dnf-automatic noarch 4.7.0-18.el8 stream-baseos 153 k
dnf-data noarch 4.7.0-18.el8 stream-baseos 159 k
dnf-plugins-core noarch 4.0.21-23.el8 stream-baseos 77 k
dracut x86_64 049-225.git20230614.el8 stream-baseos 446 k
elfutils-debuginfod-client x86_64 0.189-2.el8 stream-baseos 76 k
elfutils-default-yama-scope noarch 0.189-2.el8 stream-baseos 52 k
elfutils-libelf x86_64 0.189-2.el8 stream-baseos 232 k
elfutils-libs x86_64 0.189-2.el8 stream-baseos 302 k
gcc x86_64 8.5.0-20.el8 stream-baseos 24 M
gcc-plugin-annobin x86_64 8.5.0-20.el8 stream-baseos 36 k
glibc x86_64 2.28-228.el8 stream-baseos 2.2 M
glibc-all-langpacks x86_64 2.28-228.el8 stream-baseos 26 M
glibc-common x86_64 2.28-228.el8 stream-baseos 1.0 M
glibc-devel x86_64 2.28-228.el8 stream-baseos 85 k
glibc-gconv-extra x86_64 2.28-228.el8 stream-baseos 1.7 M
glibc-headers x86_64 2.28-228.el8 stream-baseos 581 k
gnutls x86_64 3.6.16-7.el8 stream-baseos 1.0 M
grub2-common noarch 1:2.02-148.el8.rocky.0.3 baseos 894 k
grub2-tools x86_64 1:2.02-148.el8.rocky.0.3 baseos 2.0 M
grub2-tools-efi x86_64 1:2.02-148.el8.rocky.0.3 baseos 478 k
grub2-tools-extra x86_64 1:2.02-148.el8.rocky.0.3 baseos 1.1 M
grub2-tools-minimal x86_64 1:2.02-148.el8.rocky.0.3 baseos 212 k
grubby x86_64 8.40-48.el8 stream-baseos 50 k
httpd x86_64 2.4.37-56.module+el8.8.0+1284+07ef499e.6 appstream 1.4 M
httpd-filesystem noarch 2.4.37-56.module+el8.8.0+1284+07ef499e.6 appstream 42 k
httpd-tools x86_64 2.4.37-56.module+el8.8.0+1284+07ef499e.6 appstream 109 k
hwdata noarch 0.314-8.18.el8 stream-baseos 1.8 M
iproute x86_64 6.2.0-2.el8 stream-baseos 880 k
kbd x86_64 2.0.4-11.el8 stream-baseos 422 k
kbd-legacy noarch 2.0.4-11.el8 stream-baseos 536 k
kbd-misc noarch 2.0.4-11.el8 stream-baseos 1.6 M
kernel-headers x86_64 4.18.0-500.el8 stream-baseos 11 M
krb5-devel x86_64 1.18.2-25.el8_8 baseos 561 k
krb5-libs x86_64 1.18.2-25.el8_8 baseos 841 k
libblkid x86_64 2.32.1-42.el8_8 baseos 219 k
libcurl x86_64 7.61.1-30.el8_8.2 baseos 302 k
libdnf x86_64 0.63.0-16.el8 stream-baseos 720 k
libfastjson x86_64 0.99.9-2.el8 stream-appstream 38 k
libfdisk x86_64 2.32.1-42.el8_8 baseos 252 k
libgcc x86_64 8.5.0-20.el8 stream-baseos 81 k
libgomp x86_64 8.5.0-20.el8 stream-baseos 208 k
libibverbs x86_64 46.0-1.el8.1 stream-baseos 410 k
libkadm5 x86_64 1.18.2-25.el8_8 baseos 187 k
libmd x86_64 1.1.0-1.el8 epel 45 k
libmount x86_64 2.32.1-42.el8_8 baseos 235 k
libnftnl x86_64 1.2.2-3.el8 stream-baseos 87 k
libsmartcols x86_64 2.32.1-42.el8_8 baseos 178 k
libsolv x86_64 0.7.20-6.el8 stream-baseos 376 k
libssh x86_64 0.9.6-10.el8_8 baseos 217 k
libssh-config noarch 0.9.6-10.el8_8 baseos 19 k
libstdc++ x86_64 8.5.0-20.el8 stream-baseos 458 k
libtalloc x86_64 2.4.0-3.el8 stream-baseos 50 k
libtiff x86_64 4.0.9-28.el8_8 appstream 188 k
libuuid x86_64 2.32.1-42.el8_8 baseos 97 k
libwebp x86_64 1.0.0-9.el8 stream-appstream 274 k
memstrack x86_64 0.2.5-2.el8 stream-baseos 52 k
mod_http2 x86_64 1.15.7-8.module+el8.8.0+1284+07ef499e.3 appstream 154 k
mod_ssl x86_64 1:2.4.37-56.module+el8.8.0+1284+07ef499e.6 appstream 139 k
mysql-common x86_64 8.0.32-1.module+el8.8.0+1283+4b88a3a8.0.1 appstream 137 k
mysql-libs x86_64 8.0.32-1.module+el8.8.0+1283+4b88a3a8.0.1 appstream 1.5 M
pam x86_64 1.3.1-27.el8 stream-baseos 850 k
perl-DBI x86_64 1.641-4.module_el8+332+132e4365 stream-appstream 765 k
perl-IO-Socket-SSL noarch 2.066-4.module_el8+339+1ec643e0 stream-appstream 304 k
perl-Net-SSLeay x86_64 1.88-2.module_el8+339+1ec643e0 stream-appstream 402 k
platform-python x86_64 3.6.8-52.el8 stream-baseos 86 k
protobuf-c x86_64 1.3.0-8.el8 stream-appstream 37 k
python3-cffi x86_64 1.11.5-6.el8 stream-baseos 249 k
python3-cryptography x86_64 3.2.1-6.el8 stream-baseos 641 k
python3-dnf noarch 4.7.0-18.el8 stream-baseos 604 k
python3-dnf-plugins-core noarch 4.0.21-23.el8 stream-baseos 279 k
python3-hawkey x86_64 0.63.0-16.el8 stream-baseos 118 k
python3-libdnf x86_64 0.63.0-16.el8 stream-baseos 787 k
python3-libs x86_64 3.6.8-52.el8 stream-baseos 8.4 M
python3-requests noarch 2.20.0-4.el8 stream-baseos 135 k
rdma-core x86_64 46.0-1.el8.1 stream-baseos 68 k
rocky-gpg-keys noarch 8.8-1.8.el8 baseos 13 k
rocky-release noarch 8.8-1.8.el8 baseos 22 k
rocky-repos noarch 8.8-1.8.el8 baseos 15 k
rsyslog x86_64 8.2102.0-15.el8 stream-appstream 778 k
shadow-utils x86_64 2:4.6-18.el8 stream-baseos 1.3 M
sqlite-libs x86_64 3.26.0-18.el8_8 baseos 580 k
systemd x86_64 239-76.el8 stream-baseos 3.8 M
systemd-libs x86_64 239-76.el8 stream-baseos 1.1 M
systemd-pam x86_64 239-76.el8 stream-baseos 505 k
systemd-udev x86_64 239-76.el8 stream-baseos 1.6 M
systemtap-sdt-devel x86_64 4.9-1.el8 stream-appstream 88 k
util-linux x86_64 2.32.1-42.el8_8 baseos 2.5 M
yum noarch 4.7.0-18.el8 stream-baseos 208 k
zlib x86_64 1.2.11-25.el8 stream-baseos 103 k
zlib-devel x86_64 1.2.11-25.el8 stream-baseos 59 k
Transaction Summary
Upgrade 106 Packages
Total download size: 136 M
Downloading Packages:
(1/106): apr-util-openssl-1.6.1-9.el8.x86_64.rpm 134 kB/s | 27 kB 00:00
(2/106): apr-util-bdb-1.6.1-9.el8.x86_64.rpm 121 kB/s | 25 kB 00:00
(3/106): apr-util-1.6.1-9.el8.x86_64.rpm 437 kB/s | 106 kB 00:00
(4/106): libfastjson-0.99.9-2.el8.x86_64.rpm 386 kB/s | 38 kB 00:00
(5/106): libwebp-1.0.0-9.el8.x86_64.rpm 1.3 MB/s | 274 kB 00:00
(6/106): perl-DBI-1.641-4.module_el8+332+132e4365.x86_64.rpm 4.1 MB/s | 765 kB 00:00
(7/106): perl-IO-Socket-SSL-2.066-4.module_el8+339+1ec643e0.noarch.rpm 1.7 MB/s | 304 kB 00:00
(8/106): protobuf-c-1.3.0-8.el8.x86_64.rpm 720 kB/s | 37 kB 00:00
(9/106): perl-Net-SSLeay-1.88-2.module_el8+339+1ec643e0.x86_64.rpm 3.8 MB/s | 402 kB 00:00
(10/106): systemtap-sdt-devel-4.9-1.el8.x86_64.rpm 1.1 MB/s | 88 kB 00:00
(11/106): rsyslog-8.2102.0-15.el8.x86_64.rpm 4.8 MB/s | 778 kB 00:00
(12/106): NetworkManager-initscripts-updown-1.40.16-8.el8.noarch.rpm 1.7 MB/s | 143 kB 00:00
(13/106): NetworkManager-1.40.16-8.el8.x86_64.rpm 3.6 MB/s | 2.3 MB 00:00
(14/106): chkconfig-1.19.2-1.el8.x86_64.rpm 2.5 MB/s | 217 kB 00:00
(15/106): NetworkManager-libnm-1.40.16-8.el8.x86_64.rpm 2.4 MB/s | 1.9 MB 00:00
(16/106): dbus-1.12.8-25.el8.x86_64.rpm 532 kB/s | 38 kB 00:00
(17/106): dbus-common-1.12.8-25.el8.noarch.rpm 538 kB/s | 47 kB 00:00
(18/106): dbus-daemon-1.12.8-25.el8.x86_64.rpm 1.8 MB/s | 246 kB 00:00
(19/106): dbus-libs-1.12.8-25.el8.x86_64.rpm 1.7 MB/s | 185 kB 00:00
(20/106): binutils-2.30-121.el8.x86_64.rpm 4.3 MB/s | 5.9 MB 00:01
(21/106): dbus-tools-1.12.8-25.el8.x86_64.rpm 506 kB/s | 87 kB 00:00
(22/106): dnf-automatic-4.7.0-18.el8.noarch.rpm 1.4 MB/s | 153 kB 00:00
(23/106): dnf-4.7.0-18.el8.noarch.rpm 3.5 MB/s | 552 kB 00:00
(24/106): dnf-plugins-core-4.0.21-23.el8.noarch.rpm 596 kB/s | 77 kB 00:00
(25/106): dnf-data-4.7.0-18.el8.noarch.rpm 838 kB/s | 159 kB 00:00
(26/106): elfutils-debuginfod-client-0.189-2.el8.x86_64.rpm 1.2 MB/s | 76 kB 00:00
(27/106): dracut-049-225.git20230614.el8.x86_64.rpm 3.4 MB/s | 446 kB 00:00
(28/106): elfutils-default-yama-scope-0.189-2.el8.noarch.rpm 626 kB/s | 52 kB 00:00
(29/106): elfutils-libelf-0.189-2.el8.x86_64.rpm 2.5 MB/s | 232 kB 00:00
(30/106): elfutils-libs-0.189-2.el8.x86_64.rpm 1.5 MB/s | 302 kB 00:00
(31/106): gcc-plugin-annobin-8.5.0-20.el8.x86_64.rpm 438 kB/s | 36 kB 00:00
(32/106): cpp-8.5.0-20.el8.x86_64.rpm 4.4 MB/s | 10 MB 00:02
(33/106): glibc-2.28-228.el8.x86_64.rpm 1.9 MB/s | 2.2 MB 00:01
(34/106): glibc-common-2.28-228.el8.x86_64.rpm 1.6 MB/s | 1.0 MB 00:00
(35/106): glibc-devel-2.28-228.el8.x86_64.rpm 1.0 MB/s | 85 kB 00:00
(36/106): glibc-gconv-extra-2.28-228.el8.x86_64.rpm 1.8 MB/s | 1.7 MB 00:00
(37/106): glibc-headers-2.28-228.el8.x86_64.rpm 2.2 MB/s | 581 kB 00:00
(38/106): gnutls-3.6.16-7.el8.x86_64.rpm 2.4 MB/s | 1.0 MB 00:00
(39/106): grubby-8.40-48.el8.x86_64.rpm 726 kB/s | 50 kB 00:00
(40/106): hwdata-0.314-8.18.el8.noarch.rpm 2.7 MB/s | 1.8 MB 00:00
(41/106): iproute-6.2.0-2.el8.x86_64.rpm 2.5 MB/s | 880 kB 00:00
(42/106): kbd-2.0.4-11.el8.x86_64.rpm 1.4 MB/s | 422 kB 00:00
(43/106): kbd-legacy-2.0.4-11.el8.noarch.rpm 2.3 MB/s | 536 kB 00:00
(44/106): kbd-misc-2.0.4-11.el8.noarch.rpm 2.9 MB/s | 1.6 MB 00:00
(45/106): gcc-8.5.0-20.el8.x86_64.rpm 3.5 MB/s | 24 MB 00:06
(46/106): libdnf-0.63.0-16.el8.x86_64.rpm 2.5 MB/s | 720 kB 00:00
(47/106): libgcc-8.5.0-20.el8.x86_64.rpm 568 kB/s | 81 kB 00:00
(48/106): libgomp-8.5.0-20.el8.x86_64.rpm 1.6 MB/s | 208 kB 00:00
(49/106): libibverbs-46.0-1.el8.1.x86_64.rpm 2.7 MB/s | 410 kB 00:00
(50/106): libnftnl-1.2.2-3.el8.x86_64.rpm 1.4 MB/s | 87 kB 00:00
(51/106): libsolv-0.7.20-6.el8.x86_64.rpm 3.0 MB/s | 376 kB 00:00
(52/106): libstdc++-8.5.0-20.el8.x86_64.rpm 1.7 MB/s | 458 kB 00:00
(53/106): libtalloc-2.4.0-3.el8.x86_64.rpm 813 kB/s | 50 kB 00:00
(54/106): memstrack-0.2.5-2.el8.x86_64.rpm 665 kB/s | 52 kB 00:00
(55/106): pam-1.3.1-27.el8.x86_64.rpm 2.4 MB/s | 850 kB 00:00
(56/106): platform-python-3.6.8-52.el8.x86_64.rpm 2.1 MB/s | 86 kB 00:00
(57/106): python3-cffi-1.11.5-6.el8.x86_64.rpm 2.2 MB/s | 249 kB 00:00
(58/106): python3-cryptography-3.2.1-6.el8.x86_64.rpm 3.0 MB/s | 641 kB 00:00
(59/106): python3-dnf-4.7.0-18.el8.noarch.rpm 3.0 MB/s | 604 kB 00:00
(60/106): python3-dnf-plugins-core-4.0.21-23.el8.noarch.rpm 2.4 MB/s | 279 kB 00:00
(61/106): python3-hawkey-0.63.0-16.el8.x86_64.rpm 1.7 MB/s | 118 kB 00:00
(62/106): python3-libdnf-0.63.0-16.el8.x86_64.rpm 2.7 MB/s | 787 kB 00:00
(63/106): kernel-headers-4.18.0-500.el8.x86_64.rpm 3.1 MB/s | 11 MB 00:03
(64/106): glibc-all-langpacks-2.28-228.el8.x86_64.rpm 2.9 MB/s | 26 MB 00:08
(65/106): python3-requests-2.20.0-4.el8.noarch.rpm 398 kB/s | 135 kB 00:00
(66/106): rdma-core-46.0-1.el8.1.x86_64.rpm 974 kB/s | 68 kB 00:00
(67/106): shadow-utils-4.6-18.el8.x86_64.rpm 2.6 MB/s | 1.3 MB 00:00
(68/106): systemd-libs-239-76.el8.x86_64.rpm 2.6 MB/s | 1.1 MB 00:00
(69/106): systemd-pam-239-76.el8.x86_64.rpm 2.7 MB/s | 505 kB 00:00
(70/106): systemd-239-76.el8.x86_64.rpm 2.8 MB/s | 3.8 MB 00:01
(71/106): yum-4.7.0-18.el8.noarch.rpm 1.5 MB/s | 208 kB 00:00
(72/106): zlib-1.2.11-25.el8.x86_64.rpm 1.4 MB/s | 103 kB 00:00
(73/106): systemd-udev-239-76.el8.x86_64.rpm 2.8 MB/s | 1.6 MB 00:00
(74/106): zlib-devel-1.2.11-25.el8.x86_64.rpm 705 kB/s | 59 kB 00:00
(75/106): httpd-filesystem-2.4.37-56.module+el8.8.0+1284+07ef499e.6.noarch.rpm 118 kB/s | 42 kB 00:00
(76/106): httpd-tools-2.4.37-56.module+el8.8.0+1284+07ef499e.6.x86_64.rpm 725 kB/s | 109 kB 00:00
(77/106): httpd-2.4.37-56.module+el8.8.0+1284+07ef499e.6.x86_64.rpm 1.8 MB/s | 1.4 MB 00:00
(78/106): libtiff-4.0.9-28.el8_8.x86_64.rpm 707 kB/s | 188 kB 00:00
(79/106): mod_http2-1.15.7-8.module+el8.8.0+1284+07ef499e.3.x86_64.rpm 1.2 MB/s | 154 kB 00:00
(80/106): mod_ssl-2.4.37-56.module+el8.8.0+1284+07ef499e.6.x86_64.rpm 934 kB/s | 139 kB 00:00
(81/106): mysql-common-8.0.32-1.module+el8.8.0+1283+4b88a3a8.0.1.x86_64.rpm 1.6 MB/s | 137 kB 00:00
(82/106): python3-libs-3.6.8-52.el8.x86_64.rpm 2.5 MB/s | 8.4 MB 00:03
(83/106): mysql-libs-8.0.32-1.module+el8.8.0+1283+4b88a3a8.0.1.x86_64.rpm 5.3 MB/s | 1.5 MB 00:00
(84/106): curl-7.61.1-30.el8_8.2.x86_64.rpm 660 kB/s | 352 kB 00:00
(85/106): grub2-common-2.02-148.el8.rocky.0.3.noarch.rpm 2.1 MB/s | 894 kB 00:00
(86/106): grub2-tools-efi-2.02-148.el8.rocky.0.3.x86_64.rpm 3.8 MB/s | 478 kB 00:00
(87/106): grub2-tools-2.02-148.el8.rocky.0.3.x86_64.rpm 3.9 MB/s | 2.0 MB 00:00
(88/106): grub2-tools-minimal-2.02-148.el8.rocky.0.3.x86_64.rpm 2.4 MB/s | 212 kB 00:00
(89/106): krb5-devel-1.18.2-25.el8_8.x86_64.rpm 3.3 MB/s | 561 kB 00:00
(90/106): grub2-tools-extra-2.02-148.el8.rocky.0.3.x86_64.rpm 3.3 MB/s | 1.1 MB 00:00
(91/106): libblkid-2.32.1-42.el8_8.x86_64.rpm 4.4 MB/s | 219 kB 00:00
(92/106): krb5-libs-1.18.2-25.el8_8.x86_64.rpm 3.5 MB/s | 841 kB 00:00
(93/106): libfdisk-2.32.1-42.el8_8.x86_64.rpm 5.6 MB/s | 252 kB 00:00
(94/106): libcurl-7.61.1-30.el8_8.2.x86_64.rpm 3.8 MB/s | 302 kB 00:00
(95/106): libkadm5-1.18.2-25.el8_8.x86_64.rpm 4.2 MB/s | 187 kB 00:00
(96/106): libmount-2.32.1-42.el8_8.x86_64.rpm 5.4 MB/s | 235 kB 00:00
(97/106): libsmartcols-2.32.1-42.el8_8.x86_64.rpm 3.9 MB/s | 178 kB 00:00
(98/106): libssh-0.9.6-10.el8_8.x86_64.rpm 4.9 MB/s | 217 kB 00:00
(99/106): libssh-config-0.9.6-10.el8_8.noarch.rpm 482 kB/s | 19 kB 00:00
(100/106): libuuid-2.32.1-42.el8_8.x86_64.rpm 2.2 MB/s | 97 kB 00:00
(101/106): rocky-gpg-keys-8.8-1.8.el8.noarch.rpm 240 kB/s | 13 kB 00:00
(102/106): rocky-release-8.8-1.8.el8.noarch.rpm 539 kB/s | 22 kB 00:00
(103/106): rocky-repos-8.8-1.8.el8.noarch.rpm 398 kB/s | 15 kB 00:00
(104/106): sqlite-libs-3.26.0-18.el8_8.x86_64.rpm 8.4 MB/s | 580 kB 00:00
(105/106): util-linux-2.32.1-42.el8_8.x86_64.rpm 15 MB/s | 2.5 MB 00:00
(106/106): libmd-1.1.0-1.el8.x86_64.rpm 223 kB/s | 45 kB 00:00
Total 7.9 MB/s | 136 MB 00:17
Running transaction check
Transaction check succeeded.
Running transaction test
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'yum clean packages'.
yum clean packages does not have anything to act on. The update stopped due to the error.
