IPv6 outgoing relay
daxis
IPv6 outgoing relay
Post by daxis »
When I try to add an ipv6 subnet in the outbound mail relay and save then opendkim crashes on restart.
This is what I found in /var/log/messages:
opendkim: /etc/opendkim.conf: 1.1.1.1/24 aaaa:bbbb:cccc:dddd::/64: dkimf_db_open(): Unknown database type
Multiple ipv4 subnets are no problem.
It's only when adding an ipv6 subnet that openskim crashes.
Am I doing something wrong? Is it syntax?
Any clue to the solution is appreciated.
Re: IPv6 outgoing relay
Try enclosing the IPv6 address in square brackets.
[aaaa:bbbb:cccc:dddd::]/64
daxis
Post by daxis »
Tried [aaaa:bbbb:cccc:dddd::]/64 and [aaaa:bbbb:cccc:dddd::/64].
Same error.
Are you setting that in eFa-Configure? If so, I bet we have a bug here. Let me check into it.
daxis
Post by daxis »
Yes, 7) Mail Settings >> 1) Outbound mail relay
16) DKIM and DMARC is enabled
Yeah this is a bug. The PeerList needs to be comma separated. You can work around it by using brackets for the IP portion and editing /etc/opendkim.conf to comma separate the entries. I'll prepare a fix.
daxis
Post by daxis »
The workaround seems to be working fine for now.
