Enable TLS 1.3 on efa
bernikm
Post by bernikm »
We have E.F.A v4 as mail-relay before internal Exchange server, so E.F.A in receiving mail from internet.
We have an issue with some external users sending mail and getting error: Must issue a STARTTLS command first
I think we need to configure TLS on EFA ? How can this be done ?
Any help how to do this will be gladly appreciated.
Regards,
Mike
freyuh
Re: Enable TLS 1.3 on efa
Post by freyuh »
The easiest way is to enable let's encrypt and let the certificate bind to postfix ...
bernikm
Post by bernikm »
Thank you for reply. Are there any guides and steps how to do this ?
Regards,
Mike
Aryfir
Post by Aryfir »
Do you mind to tell us how do you setup your EFA Box to your exchange server?
Is that issue of STARTTLS coming from your exchange server or your MUA (user mail client)?
BR
Ary
freyuh
Post by freyuh »
bernikm wrote: 05 Oct 2022 05:49 Are there any guides and steps how to do this ?
Only activate it in the eFa-Config Menu
bernikm
Post by bernikm »
There is no option in efa-config menu to enable STARTTLS ?
We're using efa 4.0.4
freyuh
Post by freyuh »
It shoult be enough to activate „15) Let`s Encrypt“
