eFa not block infected files detected by ESET
mendark
Post by mendark »
I found this entry in my maillog:
Jul 13 03:15:55 mailout01 MailScanner[51365]: New Batch: Scanning 1 messages, 342451 bytes
Jul 13 03:15:55 mailout01 MailScanner[51365]: Virus and Content Scanning: Starting
Jul 13 03:16:01 mailout01 MailScanner[51365]: Esets::INFECTED::Win32/Exploit.CVE-2017-11882.F
Jul 13 03:16:01 mailout01 MailScanner[51365]: Virus Scanning: esetsefs found 1 infections
Jul 13 03:16:01 mailout01 MailScanner[51365]: Infected message 4LjJ7B56M3zB5qvH.message came from
Jul 13 03:16:01 mailout01 MailScanner[51365]: Virus Scanning: Found 1 viruses
Jul 13 03:16:01 mailout01 MailScanner[51365]: <A> tag found in message 4LjJ7B56M3zB5qvH from shipment.info@one-line.com
Jul 13 03:16:01 mailout01 MailScanner[51365]: Spam Checks: Starting
Jul 13 03:16:06 mailout01 MailScanner[51365]: Requeue: 4LjJ7B56M3zB5qvH to 4LjJ7B56M3zB5qvH
Jul 13 03:16:06 mailout01 postfix/qmqpd[52744]: connect from localhost[127.0.0.1]
Jul 13 03:16:06 mailout01 postfix/qmqpd[52744]: 4LjJ7V3lrbzB5qvJ: client=localhost[127.0.0.1]
Jul 13 03:16:06 mailout01 opendmarc[3104]: ignoring connection from localhost
Jul 13 03:16:06 mailout01 postfix/cleanup[52720]: 4LjJ7V3lrbzB5qvJ: message-id=<20220713021122.DB7427BA0F81069B@one-line.com>
Jul 13 03:16:06 mailout01 opendkim[3100]: 4LjJ7V3lrbzB5qvJ: no signature data
Jul 13 03:16:06 mailout01 postfix/qmqpd[52744]: disconnect from localhost[127.0.0.1]
Jul 13 03:16:06 mailout01 postfix/qmgr[2450]: 4LjJ7V3lrbzB5qvJ: from=<shipment.info@one-line.com>, size=342508, nrcpt=1 (queue active)
Jul 13 03:16:06 mailout01 MailScanner[51365]: Uninfected: Delivered 1 messages
Jul 13 03:16:06 mailout01 MailScanner[51365]: Deleted 1 messages from processing-database
Jul 13 03:16:06 mailout01 MailScanner[51365]: MailWatch: Logging message 4LjJ7B56M3zB5qvH to SQL
Jul 13 03:16:06 mailout01 MailScanner[51368]: MailWatch: 4LjJ7B56M3zB5qvH: Logged to MailWatch SQL
Problem is, email was delivered, not blocked. How can i do to block files that ESET vired as infected?
Thank you
Re: eFa not block infected files detected by ESET
Well, that's not good. It is most definitely infected. Time to do a bug hunt.
mendark
Post by mendark »
Ok, that sound good.
When you want, i can test this type of email to view if block email.
Thank you
Similarly, from this thread
viewtopic.php?p=19107#p19107
clamav is passing on a file it thinks is a virus:
Aug 9 16:43:19 efa4 MailScanner[25395]: New Batch: Scanning 1 messages, 76484 bytes
Aug 9 16:43:19 efa4 MailScanner[25395]: Virus and Content Scanning: Starting
Aug 9 16:43:19 efa4 MailScanner[25395]: Clamd::INFECTED:: Sanesecurity.Badmacro.XlsM.Urlmon1.UNOFFICIAL :: ./4M266D0FjqzMy28c/ExcelMacroVirus.xls
Aug 9 16:43:19 efa4 MailScanner[25395]: Found spam based virus Sanesecurity.Badmacro.XlsM.Urlmon1.UNOFFICIAL in 4M266D0FjqzMy28c
Aug 9 16:43:21 efa4 MailScanner[25395]: Spam Checks: Starting
Aug 9 16:43:29 efa4 MailScanner[25395]: Message 4M266D0FjqzMy28c from 74.207.241.178 (root@example1.com) to example2.com is not spam, SpamAssassin (not cached, score=-9.91, required 4, autolearn=not spam, ASNPF_PASS -0.20, BAYES_00 -6.00, MS_FOUND_SPAMVIRUS 3.00, MXPF_PASS -0.50, OW_REF_EMAIL_D -4.70, OW_SENT_EMAIL_D -1.40, SPF_HELO_NONE 0.00, SPF_PASS -0.00, TXREP -0.10, T_SCC_BODY_TEXT_LINE -0.01)
Aug 9 16:43:29 efa4 MailScanner[25395]: Requeue: 4M266D0FjqzMy28c to 4M266D0FjqzMy28c
debugging.
[root@efa4 bin]# decode Sanesecurity.Badmacro.XlsM.Urlmon1
[badmacro.ndb] Sanesecurity.Badmacro.XlsM.Urlmon1:2:*:D0CF11E0*6E6C6F6164546F4669*75726C6D6F
VIRUS NAME: Sanesecurity.Badmacro.XlsM.Urlmon1
TARGET TYPE: OLE2
OFFSET: *
DECODED SIGNATURE:
���{WILDCARD_ANY_STRING}nloadToFi{WILDCARD_ANY_STRING}urlmo
[root@efa4 bin]# cat decode
So the signature is in the badmacro.ndb database - let's see what this is
the /etc/clamav-unofficial-sigs/master.conf lists the following in the sanesecurity db configuration:
badmacro.ndb|MEDIUM  # Blocks dangerous macros embedded in Word/Excel/Xml/RTF/JS documents
The /var/log/clamd.scan log file shows it being detected
Tue Aug  9 16:40:24 2022 -> SelfCheck: Database status OK.
Tue Aug  9 16:43:19 2022 -> /var/spool/MailScanner/incoming/25395/4M266D0FjqzMy28c/nExcelMacroVirus.xls: Sanesecurity.Badmacro.XlsM.Urlmon1.UNOFFICIAL FOUND
Tue Aug  9 16:43:19 2022 -> /var/spool/MailScanner/incoming/25395/4M266D0FjqzMy28c.message: Sanesecurity.Badmacro.XlsM.Urlmon1.UNOFFICIAL FOUND
Tue Aug  9 16:51:03 2022 -> SelfCheck: Database status OK.
So... I have no idea why clamav is detecting it, but passing it through.
I'm also testing with the EICAR test virus (https://www.eicar.org/download-anti-malware-testfile/) and that gets blocked properly.
[edit: ignore the following. MS_FOUND_SPAMVIRUS is one of my own custom rules.]
Comparing the two messages, I am seeing the following
the spamassassin MS_FOUND_SPAMVIRUS rule gets triggered for the excel macro virus, but does not for EICAR.
So it seems as if the macro virus in the sanesecurity is actually being treated as spam rather than as a virus, and that is why it is getting passed through.
This doesn't explain why the first message is letting the detected infected file through, although there may be similar reasons. What are the spamassassin headers on that particular message?
I'm out of further ideas on this.
