hello, i'm newbie of efa. My efa seems working good but i need to modify mail domains (option Mail ---> Transport settings).
I have two lines and i want to remove line 1 ed edit line 2.
If i press "2" efa says me "2 is not an option..." and if i press 1 and then delete notingh happens...
is there a way to manually edit this list?
Cannot edit domain list
Re: Cannot edit domain list
probably some sort of corruption in the file.
Try to edit /etc/postfix/transports by hand, (scroll to the bottom).
Can you share a copy of your transports file?
PM me, if needed for confidentiality...
Thanks to all, i edit transport file and now all works good!
no I do not think that this is an error in the file itself because I have the same error.
I can select 1 and 10+ but if I select 2, 3, 4, 5, 6, 7, 8 and 9 in the transport menue I always get the message ".. is not an option".
Please recheck this menue.
I have now edited the /etc/postfix/transport file manually.
How do I create the db file?
[EDIT]
got it:
postmap /etc/postfix/transport
regards,
Dirk
[EDIT]
got it:
regards,
Dirk
Can you check if you have the latest E.F.A. version?
This was a bug in a previous version which we fixed (I don't see the issue anymore)
cat /etc/EFA-Version
I noticed when I have more than 5 domains setup, I have problem editing them.
to select 2 to 9, type 02,03,- 09, and it works. I have 13 domains on mine, and found out the right way accidentally.
quote
end quote
quote
end quote
Are you running 3.0.0.6?
