clamd stop working.
Log:
Wed Jul  9 12:15:37 2014 -> HTML support enabled.
Wed Jul  9 12:15:37 2014 -> Self checking every 600 seconds.
Wed Jul  9 12:15:49 2014 -> /var/spool/MailScanner/incoming/30518/D7AB1100746.A2898.message: Suspect.DoubleExtension-zippwd-15 FOUND
**Wed Jul  9 12:15:52 2014 -> WARNING: lstat() failed on: /var/spool/MailScanner/incoming/30518/4A1A9100745.AF0A5/tnef_wAFQ8
**Wed Jul  9 12:15:52 2014 -> WARNING: lstat() failed on: /var/spool/MailScanner/incoming/30531/70613100748.ACC9E/tnef71AGfX
Wed Jul  9 12:15:52 2014 -> /var/spool/MailScanner/incoming/30518/D7AB1100746.A2898/n09-07-2014.9804887301.pdf.zip: Suspect.DoubleExtension-zippwd-15 FOUNDCode: Select all
ls -la /var/spool/MailScanner/incoming/30518/4A1A9100745.AF0A5
total 132
drwxr-xr-x  3 postfix clamav     140 Jul  9 12:15 .
drwxr-xr-x 32 postfix clamav    1840 Jul  9 12:15 ..
-rw-r--r--  1 postfix clamav    8040 Jul  9 12:15 nmsg-30518-219.txt
-rw-r--r--  1 postfix clamav    7672 Jul  9 12:15 nmsg-30518-220.txt
-rw-r--r--  1 postfix clamav    6297 Jul  9 12:15 nmsg-30518-221.txt
-rw-r--r--  1 postfix clamav  107826 Jul  9 12:15 nwinmail.dat
drwx------  2 postfix **postfix**     60 Jul  9 12:15 tnef_wAFQ8
