Few questions on locking down eFa on CentOS 8
viper407
Post by viper407 »
Good evening
Thank you for taking the time to view my message. Please can you answer the below if possible?
A) Can i turn on the firewall on CentOS 8? Will it break anything?
$ sudo systemctl start firewalld
$ sudo systemctl enable firewalld
B) Can i secure the password files?
$ sudo chattr +i /etc/passwd
$ sudo chattr +i /etc/shadow
C) I checked the forums and you mentioned some time ago about adding spam assassin spoof plugin. Is this active now? How do i add it and enable it?
Kind regards
Edward
Re: Few questions on locking down eFa on CentOS 8
A) Yes, just make sure you allow at least tcp ports 22,25,80,443,587 where needed.
B) Yes, that should be fine.
C) FromNameSpoof? You can enable that plugin in /etc/mail/spamassassin/v342.pre.
viper407
Post by viper407 »
Thanks for the response Shawn :D
I configured point A and B and see the line in that file for spam assassin was already uncommented. All running well.
Kind Regards
Edward
