Good morning
My name is Edward. I did alot of research and found eFA and have already implemented it in my lab, fully operational. It does wonders. I have done testing with attachments and double extensions like .exe.pdf and it blocks it 100%.
I have already started setting it up for my client due to the amount of spam they are getting.
I am not sure if this is the place to ask a question but I have three of them:
A) Can i turn on the firewall on CentOS 8? Will it break anything?
$ sudo systemctl start firewalld
$ sudo systemctl enable firewalld
B) Can i secure the password files?
$ sudo chattr +i /etc/passwd
$ sudo chattr +i /etc/shadow
C) I checked the forums and you mentioned some time ago about adding spam assassin spoof plugin. Is this active now? How do i add it and enable it?
Apologies for the questions if not the correct place.
Once again, thank you for an awesome product.
Kind Regards
Edward
						Hello
