Not sure what I'm doing wrong ...
Obvioulsy something not right but can't see what!
Setup a new EFA 4 on Centos 8
Main issue is LetsEncrypt SSL - just can't seem to get it to work!
Certificate is generated, saved but not install
Tried cartbot command suggested but no luck
I tried changing the host name and regenerated - still the same
Port 80 & 443 are open to the EFA. The DNS record exists and upto date
Right, so after multiple attempts I installed Centos 8, Installed EFA - tested for mail filtering
then tried generating LetsEntrypt SSL again,
Exact same issue
Any ideas how to fix this or is it necessary to report a bug
As I said I can't see any posts (did find a very old one withsimilar issue - suggestion was to toggel LetEncrypt Cert but that didn't work!)
not sure if this is Bug as none has reported similar
Re: not sure if this is Bug as none has reported similar
Do you have eFa behind firewall? Are you using a tunnel through NAT?
Let'sEncrypt requires http AND https to communicate.
The testing effort used to identify, evaluate, and report a particular bug or defect is completely wasted if it cannot be reproduced.
Letsencrypt will leave log files telling you what went wrong. Find them, and you will find your answer.
