LetsEncrypt cartbot install error
bas60
Post by bas60 »
Can't install LetsEncrypt Certificate
Suggestion to install Certificate manually also problem
When I run cartbot install --cert-name my.domain.com
[Errno 13] Permission denied: '/var/log/letsencrypt/.certbot.lock'
Either run as root, or set --config-dir, --work-dir, and --logs-dir to writeable paths.
Bit stuck...NO ROOT password - disabled by EFA!
What do I use for the --config-dir et above?
I tried RE-INSTALLING Centos 8, EFA and running through the entire process
How can I fix this?
Should I be using another OS rather than Centos - if so which?
bas60
Re: LetsEncrypt cartbot install error
Post by bas60 »
Possible Red Herring
Noticed on a new PC not getting the error in Chrome / Edge
So decided to check https://www.ssllabs.com/ssltest/
So it looks its been applied ok !
hope it helps someone !
