Have searched forum, apologies if I've missed this...
We have a bit of an issue where our SU is contacting >7k recipients here using an external company who send via sendgrid (urgh).
They dump >7k messages in the inbound milter queue in a short space of time, leading to delays for other mail.
I've identified that the messages all come from two sendrid relays, so is there a simple way that I can rate-limit using postfix? and the mail can sit on with sendgrid until I accept it at a more acceptable rate?
Rate-limiting relays
Re: Rate-limiting relays
Yes, you can rate-limit using postfix.
http://www.postfix.org/TUNING_README.html#conn_limit
You'll notice, however that the ratelimiting is global, using an exceptions list. What you want, however, is probably the opposite.
To do that, you may want to take a look at https://postfwd.org/ instead.
Thanks for the reply Shawn
I'm not mad keen on putting another level of software on my box as a complication.
I'm tempted to play with the post-fix rate-limiting settings, I dont think there are many well-behaved senders who would be pissed off.
Will have a dig, though. Thanks
