Click Here to report links gone
sharktech
Post by sharktech »
Fresh install of V4 and i have no links for users to report SPAM anymore, can anyone help
TIA
Re: Click Here to report links gone
I am working on rebuilding this feature using PHP. Stay tuned! (This one is high on the list)
sharktech
Post by sharktech »
Much appreciated! :D
ItemsGmbH
Post by ItemsGmbH »
Hi there
Any progress?
AITCS
Post by AITCS »
Finally upgraded to v4 and just noticed this as well.
Wondering if I've missed something or this is still in the works.
Any updated information would be greatly appreciated.
w_bufffet
Post by w_bufffet »
Any update on this?
Still in the works. The releasing part is done, just need to finish the reporting part.
freyuh
Post by freyuh »
can I do anything to accelerate this a litte bit?
We are still running on v3 because of this feature and now with the turn of the year let's encrypt isn't working anymore.
So we have to migrate to v4 within the next 2 months ...
Sincerely,
Ulrich.
Sure can. I'll bump this to the top of my list.
freyuh
Post by freyuh »
Hello shawn,
many thanks!!!!
I made a donation too, hope this also helps ;)
Sincerely,
Ulrich.
freyuh wrote: 18 Jan 2022 15:58 Hello shawn,
many thanks!!!!
Sincerely,
Ulrich.
Thank you so much! :D
hawrebelo
Post by hawrebelo »
keep in touch with progress
Report link is back in 4.0.4-32:
You will find the configuration options under 8) Spam Settings in eFa-Configure.
Options to control the report link:
1) Non Spam Settings
8) Trusted Networks
9) Inline Signature Rules
freyuh
Post by freyuh »
Thank you very much Shawn
freyuh
Post by freyuh »
/var/eFa/lib/eFa-Configure/func_asknonspam: touch /etc/MailScanner/rules/inline.sig.txt.rules
I think this should be /etc/MailScanner/rules/inline.sig.text.rules
Thanks, I'll get this corrected.
forhire
Post by forhire »
shawniverson wrote: 12 Mar 2022 17:46 Report link is back in 4.0.4-32:
Shawn, I have enabled inline signature but mailscanner isn't inserting the signature. Any ideas?
freyuh
Post by freyuh »
Have you edited the inline sig rules?
forhire
Post by forhire »
freyuh wrote: 01 May 2022 17:48 Have you edited the inline sig rules?
When I added mydomain.com, it inserted rules into these files.
sudo grep mydomain.com /etc/MailScanner/rules/*
/etc/MailScanner/rules/inline.sig.html.rules:To: *@mydomain.com /etc/MailScanner/reports/en/inline.sig.html
/etc/MailScanner/rules/inline.sig.text.rules:To: *@mydomain.com /etc/MailScanner/reports/en/inline.sig.txt
Both includes exist and contain a signature.
It appears it should be working. When it appends the inline sig is it logged someplace? I didn't find anything obvious.
forhire
Post by forhire »
After I Enabled it under option 1) Non Spam Settings I have it appending to ALL domains. Not just the domains appearing in the rules.
Mailscanner.conf shows it's using custom(nonspam) as the spam action:
Sign Clean Messages = No
It's acting as if Sign Clean Messages = Yes yet I have confirmed it is No. It appears custom(nonspam) is the issue. Rebooting the server doesn't correct the issue.
Any ideas?
freyuh
Post by freyuh »
I have to take a look at it ...
freyuh
Post by freyuh »
I think the evaluation of the rules is missing in the custom function.
The logic for that has to be implemented ...
custom(nonspam) overrides the Sign Clean Messages to add extra variables.
Do you have the following in MailScanner.conf
Inline HTML Signature = %rules-dir%/inline.sig.html.rules
Inline Text Signature = %rules-dir%/inline.sig.text.rules
freyuh
Post by freyuh »
Yes I (we) have.
But the signature is nevertheless attached to the email.
And you have a small error in the file CustomAction.pm:
    } elsif ($file =~ /inline.sig.in.txt/ && $spamwhitelisted eq "1") {
should be
   } elsif ($file =~ /inline.sig.txt/ && $spamwhitelisted eq "1") {
freyuh
Post by freyuh »
And I recognize this, because the english report is attached instead of the configured german ...
