MailScanner: No programs allowed
peter.barlabas
Post by peter.barlabas »
Hello!
Sometimes the EFA is blocking .xlsx files.
The message is: "MailScanner: No programs allowed"
How can I fix it?
Best regards: Péter
SelfMan
Re: MailScanner: No programs allowed
Post by SelfMan »
check /etc/MailScanner/filename.rules.conf
BTW are you sure that those files are not *.xlsx.exe?
peter.barlabas
Hi!
I'm sure 100%, that theese files normal xlsx or xls.
What do I check in /etc/MailScanner/filename.rules.conf ?
Best regards: Péter
peawet08
Post by peawet08 »
Did you resolve this. I seem to have a similar issue with a .txt file
SelfMan
Post by SelfMan »
Hi Peter,
the file contains definition for behavior based on the file extension.
This way you can define which file types are allowed to pass and which are not.
peter.barlabas wrote: 30 Sep 2021 09:31 What do I check in /etc/MailScanner/filename.rules.conf ?
Would someone take a look at this PR https://github.com/MailScanner/v5/pull/556 and set the following in MailScanner.conf:
Archive: Ignore DAT File Executable = yes
peter.barlabas
Hello!
Sorry the latest answer.
So, when the EFA blocking xlsx file, the complete message is: The message is: "MailScanner: No programs allowed (92000.dat)" or (90000.dat etc).
And really the xlsx content a few bytes size dat file.
I can rename xlsx to zip and I can see the xlsx contain a .dat file which was blocked.
Regards: Péter
