After migration eFa 3->4 : MailScanner is not updating
gigabyte
Post by gigabyte »
Hi all,
I successfully migrated from eFa 3->4 using the migration plan on the eFa Wiki (https://wiki.efa-project.org/doku.php?i ... m_v3_to_v4).
Everything is working great except the MailWatch webpage after logging in to the IP of the eFa webpage...
Both the Mail Queues are staying at "0" - and the "Last 50 Messages" view is showing only the eMails from eFa version 3.x but not the new ones that are arriving successfully. MailScanner -lint and all seems to work fine.
Long short -> seems that the MailScanner is still mapped to a db or incoming directory that is not updated when new emails are arriving...
Searched all the day but could not find a way to find out how to change the db or incoming directory (if this is the cause of my issue)...
Thanks in advance
Re: After migration eFa 3->4 : MailScanner is not updating
Sounds like new messages aren't being logged, any indication in /var/log/maillog or /var/log/httpd/* logs?
gigabyte
Post by gigabyte »
/var/log/maillog looks okay (new mails are logged there)
/var/log/httpd/*.log only has the following logs: access_log, error_log, ssl_access_log ssl_error_log ssl_request_log
in /var/log/httpd there seems to be no new messages log... (should there be one? and if where to config it)
Thank you in advance
