/etc/cron.daily/freshclam:
ERROR: getpatch: Can't download daily-24292.cdiff from db.nl.clamav.net
ERROR: Can't download daily.cvd from db.nl.clamav.net
ERROR: getpatch: Can't download daily-24292.cdiff from db.local.clamav.net
ERROR: Can't download daily.cvd from db.local.clamav.net
[root@sansspam conf.d]# freshclam -v
Current working dir is /var/lib/clamav
Max retries == 3
ClamAV update process started at Thu Feb 8 13:02:58 2018
Using IPv6 aware code
Querying current.cvd.clamav.net
TTL: 1722
Software version from DNS: 0.99.3
WARNING: Local version: 0.99.2 Recommended version: 0.99.3
DON'T PANIC! Read http://www.clamav.net/documents/upgrading-clamav
main.cvd version from DNS: 58
main.cld is up to date (version: 58, sigs: 4566249, f-level: 60, builder: sigmgr)
daily.cvd version from DNS: 24296
Retrieving http://db.nl.clamav.net/daily-24292.cdiff
Ignoring mirror 145.58.29.83 (due to previous errors)
Ignoring mirror 194.109.6.97 (due to previous errors)
WARNING: getpatch: Can't download daily-24292.cdiff from db.nl.clamav.net
etcetcetc
Solution:
move /var/lib/clamav/main.cld to /tmp
move /var/lib/clamav/morrors.dat to /tmp
Run
freshclam -v
Max retries == 3
ClamAV update process started at Thu Feb 8 13:12:15 2018
TTL: 1165
main.cvd is up to date (version: 58, sigs: 4566249, f-level: 60, builder: sigmgr)
daily.cld is up to date (version: 24296, sigs: 1847795, f-level: 63, builder: neo)
bytecode.cvd version from DNS: 319
bytecode.cld is up to date (version: 319, sigs: 75, f-level: 63, builder: neo)
Now delete tmp files
