503 Service Unavailable The server is temporarily unable to service your request...
e-d-i-t
Post by e-d-i-t »
So this morning I wanted to login to EFA, seeing:
503
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Services at the cli seem to run?
I am not a real linux guru to figure out what is wrong now. Has there been an update?
It shows 4.0.4. as version.
e-d-i-t
Re: 503 Service Unavailable The server is temporarily unable to service your request...
Post by e-d-i-t »
Did a DB repair from menu, service seems to stop and start allright.
Services seem to be running though.
I might want to restore the system to yesterday if all fails.
e-d-i-t
Post by e-d-i-t »
Yep, there was an update:
Mail works, just tested, so it seems to be the webinterface/server only.
/etc/cron.daily/0yum-daily.cron:
warning: /etc/php.ini created as /etc/php.ini.rpmnew
warning: /etc/php-fpm.d/www.conf created as /etc/php-fpm.d/www.conf.rpmnew
Preparing to update eFa...
checkmodule: loading policy configuration from /var/eFa/lib/selinux/eFa.te
checkmodule: policy configuration loaded
checkmodule: writing binary representation (version 19) to /var/eFa/lib/selinux/eFa.mod
Update completed successfully!
The following updates will be applied on mailgtw.e-d-i-t.nl:
Package Arch Version Repository
Size
Installing:
eFa noarch 1:4.0.4-8.eFa.el7 eFa4 116 k
replacing mod_php72u.x86_64 7.2.34-1.el7.ius
replacing php72u-cli.x86_64 7.2.34-1.el7.ius
replacing php72u-common.x86_64 7.2.34-1.el7.ius
replacing php72u-fpm.x86_64 7.2.34-1.el7.ius
replacing php72u-gd.x86_64 7.2.34-1.el7.ius
replacing php72u-json.x86_64 7.2.34-1.el7.ius
replacing php72u-ldap.x86_64 7.2.34-1.el7.ius
replacing php72u-mbstring.x86_64 7.2.34-1.el7.ius
replacing php72u-mysqlnd.x86_64 7.2.34-1.el7.ius
replacing php72u-pdo.x86_64 7.2.34-1.el7.ius
replacing php72u-process.x86_64 7.2.34-1.el7.ius
replacing php72u-xml.x86_64 7.2.34-1.el7.ius
Updating:
sqlgreywebinterface noarch 1:1.1.9-4.eFa.el7 eFa4 15 k
Installing for dependencies:
mod_php74 x86_64 7.4.15-1.el7.ius ius 1.6 M
php74-cli x86_64 7.4.15-1.el7.ius ius 3.3 M
php74-common x86_64 7.4.15-1.el7.ius ius 685 k
php74-fpm x86_64 7.4.15-1.el7.ius ius 1.7 M
php74-gd x86_64 7.4.15-1.el7.ius ius 171 k
php74-json x86_64 7.4.15-1.el7.ius ius 75 k
php74-ldap x86_64 7.4.15-1.el7.ius ius 86 k
php74-mbstring x86_64 7.4.15-1.el7.ius ius 477 k
php74-mysqlnd x86_64 7.4.15-1.el7.ius ius 187 k
php74-pdo x86_64 7.4.15-1.el7.ius ius 122 k
php74-process x86_64 7.4.15-1.el7.ius ius 83 k
php74-xml x86_64 7.4.15-1.el7.ius ius 167 k
Transaction Summary
Install 1 Package (+12 Dependent packages)
Upgrade 1 Package
The updates were successfully applied
fperciot
Post by fperciot »
Same issue as reported in this post :
viewtopic.php?f=5&t=4657
MauriceW
Post by MauriceW »
I have the exact same error since today.
arazim1284
Post by arazim1284 »
Here :
viewtopic.php?f=19&t=4655
systemctl restart php-fpm.
There are errors in the message log but the GUI is running
colinjack
Post by colinjack »
Me too ... looks like PHP update from 7.2 to 7.4? :think:
Hopefully Shawn can find a quick fix.
hugorosa
Post by hugorosa »
NOW IT'S WORKING !!! :-)
systemctl enable php-fpm
systemctl start php-fpm
Have a nice day
e-d-i-t
Post by e-d-i-t »
Thank you all! restarting php-fpm did the job, and enabled php-fpm too
bikertrash
Post by bikertrash »
LOL... I've got SO many devices on the home network that pretty much every morning I run across an update that breaks the daylights out of something.
Really glad that I checked here first before spending several hours digging and clawing at this one.
Thank you!!!
:clap: :dance: :D
