So this morning I wanted to login to EFA, seeing:
503
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Services at the cli seem to run?
I am not a real linux guru to figure out what is wrong now. Has there been an update?
It shows 4.0.4. as version.
503 Service Unavailable The server is temporarily unable to service your request...
Re: 503 Service Unavailable The server is temporarily unable to service your request...
Did a DB repair from menu, service seems to stop and start allright.
Services seem to be running though.
I might want to restore the system to yesterday if all fails.
Yep, there was an update:
Mail works, just tested, so it seems to be the webinterface/server only.
/etc/cron.daily/0yum-daily.cron:
warning: /etc/php.ini created as /etc/php.ini.rpmnew
warning: /etc/php-fpm.d/www.conf created as /etc/php-fpm.d/www.conf.rpmnew
Preparing to update eFa...
checkmodule: loading policy configuration from /var/eFa/lib/selinux/eFa.te
checkmodule: policy configuration loaded
checkmodule: writing binary representation (version 19) to /var/eFa/lib/selinux/eFa.mod
Update completed successfully!
The following updates will be applied on mailgtw.e-d-i-t.nl:
Package Arch Version Repository
Size
Installing:
eFa noarch 1:4.0.4-8.eFa.el7 eFa4 116 k
replacing mod_php72u.x86_64 7.2.34-1.el7.ius
replacing php72u-cli.x86_64 7.2.34-1.el7.ius
replacing php72u-common.x86_64 7.2.34-1.el7.ius
replacing php72u-fpm.x86_64 7.2.34-1.el7.ius
replacing php72u-gd.x86_64 7.2.34-1.el7.ius
replacing php72u-json.x86_64 7.2.34-1.el7.ius
replacing php72u-ldap.x86_64 7.2.34-1.el7.ius
replacing php72u-mbstring.x86_64 7.2.34-1.el7.ius
replacing php72u-mysqlnd.x86_64 7.2.34-1.el7.ius
replacing php72u-pdo.x86_64 7.2.34-1.el7.ius
replacing php72u-process.x86_64 7.2.34-1.el7.ius
replacing php72u-xml.x86_64 7.2.34-1.el7.ius
Updating:
sqlgreywebinterface noarch 1:1.1.9-4.eFa.el7 eFa4 15 k
Installing for dependencies:
mod_php74 x86_64 7.4.15-1.el7.ius ius 1.6 M
php74-cli x86_64 7.4.15-1.el7.ius ius 3.3 M
php74-common x86_64 7.4.15-1.el7.ius ius 685 k
php74-fpm x86_64 7.4.15-1.el7.ius ius 1.7 M
php74-gd x86_64 7.4.15-1.el7.ius ius 171 k
php74-json x86_64 7.4.15-1.el7.ius ius 75 k
php74-ldap x86_64 7.4.15-1.el7.ius ius 86 k
php74-mbstring x86_64 7.4.15-1.el7.ius ius 477 k
php74-mysqlnd x86_64 7.4.15-1.el7.ius ius 187 k
php74-pdo x86_64 7.4.15-1.el7.ius ius 122 k
php74-process x86_64 7.4.15-1.el7.ius ius 83 k
php74-xml x86_64 7.4.15-1.el7.ius ius 167 k
Transaction Summary
Install 1 Package (+12 Dependent packages)
Upgrade 1 Package
The updates were successfully applied
Size
Installing:
Updating:
Transaction Summary
Upgrade 1 Package
I have the exact same error since today.
Here :
viewtopic.php?f=19&t=4655
systemctl restart php-fpm.
There are errors in the message log but the GUI is running
Here :
Me too ... looks like PHP update from 7.2 to 7.4?
Hopefully Shawn can find a quick fix.
NOW IT'S WORKING !!!
systemctl enable php-fpm
systemctl start php-fpm
Have a nice day
Have a nice day
Thank you all! restarting php-fpm did the job, and enabled php-fpm too
- bikertrash
LOL... I've got SO many devices on the home network that pretty much every morning I run across an update that breaks the daylights out of something.
Really glad that I checked here first before spending several hours digging and clawing at this one.
Thank you!!!
Thank you!!!
