Fail2Ban config in EFA v4
toddh
Post by toddh »
I am finally moving over to EFA v4 and tightening down my boxes.
Do I need to do any configuration for Fail2Ban in v4? Or just enable it in the EFA-Configure menu.
By default does it block IPs via Postfix?
Sorry if this has been covered. Was reading the forum but most of the references are for v3.x
Todd
Re: Fail2Ban config in EFA v4
It should block ssh and postfix repeat attempts by default.
toddh
Post by toddh »
Thanks Shawn.
There is nothing else that needs to be configured? Just enable in EFA-Configure and it does the rest.
You might want to consider adding the postfix-sasl jail as well, if you get a lot of failed sasl authentication attempts.
jamerson
Post by jamerson »
pdwalker wrote: 09 Feb 2021 05:58 You might want to consider adding the postfix-sasl jail as well, if you get a lot of failed sasl authentication attempts.
this is a good idea, maybe add it out of the box.
tesme33
Post by tesme33 »
i got annoyed because of all the login attempts
Feb 25 21:14:12 efa4 postfix/smtpd[2436]: disconnect from unknown[5.34.207.79] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Feb 25 21:14:12 efa4 postfix/smtpd[3328]: disconnect from unknown[87.246.7.229] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Feb 25 21:14:14 efa4 postfix/smtpd[10446]: connect from unknown[5.34.207.79]
Feb 25 21:14:15 efa4 postfix/smtpd[11953]: connect from unknown[5.34.207.192]
Feb 25 21:14:15 efa4 postfix/smtpd[9753]: warning: unknown[5.34.207.79]: SASL LOGIN authentication failed: authentication failure
Feb 25 21:14:16 efa4 postfix/smtpd[9753]: disconnect from unknown[5.34.207.79] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Feb 25 21:14:18 efa4 postfix/smtpd[3328]: connect from unknown[5.34.207.79]
Feb 25 21:14:19 efa4 postfix/smtpd[10446]: warning: unknown[5.34.207.79]: SASL LOGIN authentication failed: authentication failure
Feb 25 21:14:19 efa4 postfix/smtpd[11953]: warning: unknown[5.34.207.192]: SASL LOGIN authentication failed: authentication failure
Feb 25 21:14:20 efa4 postfix/smtpd[10446]: disconnect from unknown[5.34.207.79] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Feb 25 21:14:20 efa4 postfix/smtpd[11953]: disconnect from unknown[5.34.207.192] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
so i configured fail2ban to also capture SASL.
Ich was following the description here: https://bobcares.com/blog/fail2ban-postfix-sasl/ (just the name of the logfile needed to be maillog instead of mail.log)
afterwards a
systemctl restart fail2ban.service
made the day .
And immediatly it catched the first IPs. :-)
[root@efa4 log]# fail2ban-client status sasl
Status for the jail: sasl
|- Filter
|  |- Currently failed:	3
|  |- Total failed:	257
|  `- File list:	/var/log/maillog
`- Actions
   |- Currently banned:	3
   |- Total banned:	3
   `- Banned IP list:	5.34.207.192 87.246.7.229 5.34.207.79
Just in case anybody is interested
Here's a good and current working configuration for EFA v4 postfix-sasl by ajmind
viewtopic.php?p=19136#p19136
Helpful!
