IPv6 support
hunter-nl
IPv6 support
Post by hunter-nl »
Does EFA fully support IPv6?
Re: IPv6 support
No, some of the components of EFA are currently IPV4 only. I hope that some of the 3rd party components will be updated soon by the developers to support IPV6.
hunter-nl
Re: IPv6 support
Post by hunter-nl »
Can you tell me which components do not support IPv6 (yet)?
Re: IPv6 support
Mailwatch has some outstanding issues with IPv6...
Razor requires additional setup for IPv6 support...
Other than that I think the rest is IPv6 supported. I'll have to research further, as some packages may need updated for better IPv6 support
