reboot slow after configure
After installing and configuring reboot became slow (2 minutes) on vm on centos 8.3 on esxi 6.7
Re: reboot slow after configure
It has to to a SELinux relabel. This is just a one time thing.
no no, i see relabeling
after first configure reboot (or shutdown) takes 2 minutes forever (i have configured 2 machines and is same thing)
I'm not sure I follow you. The timed reboot has a 60 second delay due to needing to leverage cron to kick it off as root?
i am nat talking about 1 minute delay after first install reboot
after installing efa machine takes 2 minutes to reboot that happen after dragcut killall every time
I found that the problem start only when a system is loaded with messages incoming,
it takes 2 minutes and at the end i can see dracut killing remaining processes
In a system with low traffic it doesnt occur it occurs only when i turn dns to use system
