No update since 4.0.3
I might be doing something noobish, but when I select "Update Now" in the configuration menu not much seems to happen. When I do it at the shell, it mentions that no updates are available, which I find rather strange knowing that the interface is stating that my version is 4.0.3.
Loaded plugins: fastestmirror
* base: centos.mirror.ate.info
* eFa4: dl5.efa-project.org
* epel: www.mirrorservice.org
* extras: distrib-coffee.ipsl.jussieu.fr
* updates: centos.mirror.ate.info
No packages marked for update
The reason I was looking for this update was because I have the issue with the virus scanner which is crashing: https://github.com/E-F-A/v4/issues/256
In the release notes of 4.0.4-5 there is mentioned "Remove yara rules from /var/lib/clamav", does this mean all files with file extension *.yara" in /var/lib/clamav are supposed to be removed?
Re: No update since 4.0.3
Replication appears to be down between the mirrors, I'll take a look tonight.
Oh, and yes .yara
Ok, now I get the packages indeed:
Resolving Dependencies
--> Running transaction check
---> Package MailScanner.noarch 0:5.3.4-3.eFa.el7 will be updated
---> Package MailScanner.noarch 0:5.4.1-1.eFa.el7 will be an update
---> Package MailWatch.noarch 1:1.2.15-4.eFa.el7 will be updated
---> Package MailWatch.noarch 1:1.2.16-1.eFa.el7 will be an update
---> Package clamav-unofficial-sigs.noarch 1:7.2.0-1.eFa.el7 will be updated
---> Package clamav-unofficial-sigs.noarch 1:7.2.2-1.eFa.el7 will be an update
---> Package eFa.noarch 1:4.0.3-14.eFa.el7 will be updated
---> Package eFa.noarch 1:4.0.4-5.eFa.el7 will be an update
---> Package postfix_eFa.x86_64 2:3.4.8-1.eFa.el7 will be updated
---> Package postfix_eFa.x86_64 2:3.5.9-1.eFa.el7 will be an update
I'm facing the same issue.
After a little digging, I found out that the repo that the update process are trying to reach are no longer accesible.
Here are the results of a yum update (within the shell) :
When digging more, I found in the Readme file at http://ftp.rezopole.net/centos/7.8.2003/ :
Am I missing something ?
Could you provide us (for the people facing the same problem) with a workaround in order to upgrade our 4.0.3 version of EFA please ?
Thanks in advance,
Regards
Loaded plugins: fastestmirror, langpacks
* base: centos.crazyfrogs.org
* eFa4-Testing: dl.efa-project.org
* epel: ftp.icm.edu.pl
* extras: centos.crazyfrogs.org
* updates: centos.crazyfrogs.org
http://centos.crazyfrogs.org/7.8.2003/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
Trying other mirror.
To address this issue please refer to the below wiki article
https://wiki.centos.org/yum-errors
If above article doesn't help to resolve this issue please use https://bugs.centos.org/.
http://centos.quelquesmots.fr/7.8.2003/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://miroir.univ-paris13.fr/centos/7.8.2003/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://centos.mirrors.proxad.net/7.8.2003/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://mir01.syntis.net/CentOS/7.8.2003/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://distrib-coffee.ipsl.jussieu.fr/pub/linux/centos/7.8.2003/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://miroir.univ-lorraine.fr/centos/7.8.2003/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://mirror.plusserver.com/centos/7.8.2003/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://centos.mirror.ate.info/7.8.2003/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://mirroir.wptheme.fr/centos/7.8.2003/os/x86_64/repodata/repomd.xml: [Errno 14] HTTPS Error 404 - Not Found
http://centos.crazyfrogs.org/7.8.2003/extras/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://centos.quelquesmots.fr/7.8.2003/extras/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://miroir.univ-paris13.fr/centos/7.8.2003/extras/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://fr2.rpmfind.net/linux/centos/7.8.2003/extras/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://centos.mirrors.proxad.net/7.8.2003/extras/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://ftp.rezopole.net/centos/7.8.2003/extras/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://mirrors.standaloneinstaller.com/centos/7.8.2003/extras/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://ftp.pasteur.fr/mirrors/CentOS/7.8.2003/extras/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://miroir.univ-lorraine.fr/centos/7.8.2003/extras/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://centos.mirror.ate.info/7.8.2003/extras/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://centos.crazyfrogs.org/7.8.2003/updates/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://centos.quelquesmots.fr/7.8.2003/updates/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://miroir.univ-paris13.fr/centos/7.8.2003/updates/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://fr2.rpmfind.net/linux/centos/7.8.2003/updates/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://centos.mirrors.proxad.net/7.8.2003/updates/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://ftp.rezopole.net/centos/7.8.2003/updates/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://distrib-coffee.ipsl.jussieu.fr/pub/linux/centos/7.8.2003/updates/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://miroir.univ-lorraine.fr/centos/7.8.2003/updates/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://ftp.pasteur.fr/mirrors/CentOS/7.8.2003/updates/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
http://centos.mirror.ate.info/7.8.2003/updates/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
This directory (and version of CentOS) is deprecated. For normal users,
you should use /7/ and not /7.8.2003/ in your path. Please see this FAQ
concerning the CentOS release scheme:
https://wiki.centos.org/FAQ/General
If you know what you are doing, and absolutely want to remain at the 7.8.2003
level, go to http://vault.centos.org/ for packages.
Please keep in mind that 7.8.2003 no longer gets any updates, nor
any security fix's.
Thanks in advance,
Regards
yum clean all
yum update
Although you may also need to peek into /etc/yum.conf.d and check that you are using just /7/ for your CentOS repos.
Re,
Thanks for the tip.
This helped me with the system packages : I was able to update the system
Meanwhile, I'm still stuck with the 4.0.3 release :
Any clue ?
Thanks in advance,
Regards
Thanks for the tip.
--- Welcome to the eFa Configuration program ---
--- https://www.efa-project.org ---
You are currently running eFa-4.0.3.
Please choose an option:
0) Logout from ssh 9) MariaDB Recovery
1) Shell 10) Apache Settings
2) Reboot system 11) Virus Settings
3) Halt system 12) System Restore
4) IP Settings 13) Update Now
5) Tunables 14) Maintenance Mode
6) MailWatch Settings 15) Let's Encrypt
7) Mail Settings 16) DKIM and DMARC
8) Spam Settings 17) Webmin
18) Fail2Ban
[eFa] : 13
Update now, are you sure? (y/N): y
* base: ftp.pasteur.fr
* epel: fr2.rpmfind.net
* extras: mirror.plusserver.com
* updates: ftp.rezopole.net
Thanks in advance,
Regards
Do you have the file /etc/yum.repos.d/eFa4.repo?
If so, does it match this?
what's the result of the following command:
[eFa4]
name=eFa-Project
baseurl=https://dl.efa-project.org/rpm/eFa4/x86_64
mirrorlist=https://dl.efa-project.org/rpm/eFa4/mirrors-eFa
failovermethod=priority
enabled=1
yum list |grep ^eFa
Here is what I have :
And :
But you must know that my eFa has upgraded itself few days ago (without any tweak from me).
I've just added the repo you gave in your reply (because I didn't have the file you mentionned).
I did yum update followed by yum upgrade :
And now :
I presume my eFa is up to date, nop ?
[root@efa antispam]# yum list |grep ^eFa
eFa.noarch 1:4.0.4-9.eFa.el7 @eFa4-Testing
eFa-base.x86_64 1:4.0.0-1.eFa.el7 @eFa4-Testing
eFa.x86_64 1:4.0.2-19.eFa.el7 eFa4-Testing
eFa-base.noarch 1:4.0.0-1.eFa.el7 eFa4-Testing
eFa-debuginfo.x86_64 1:4.0.2-19.eFa.el7 eFa4-Testing
[root@efa antispam]# yum list installed|grep ^eFa
[root@efa antispam]# yum update
* eFa4: dl6.efa-project.org
* eFa4-Testing: dl2.efa-project.org
* epel: mirrors.up.pt
[root@efa antispam]# yum upgrade
* epel: mirror.nl.leaseweb.net
Yeah you are up to date. You can ignore the x86-64 packages. I'm thinking the version in /eFa/eFa-Version needs bumped. I'll double check that.
Great.
Thanks for the time and effort you spend to help me.
Regards
Regards
