hundreds of domains directadmin - srs-dkim etc
zerocool
Post by zerocool »
I have a few VPS servers with directadmin and about 400 domains.
That domains need a spamfilter, implementing EFA was really easy to get the inbound filtering active.
But: how can i automatically import new domains on directadmin?
And about outgoing, how do i use SRS? or any other solution for customers who forward their e-mail to the private gmail/live mailboxes
Re: hundreds of domains directadmin - srs-dkim etc
I'm not familiar with directadmin, so I'm not sure how to answer that.
SRS support is not built-in, so you will need to add it, such as https://github.com/roehling/postsrsd
zerocool
Post by zerocool »
Thank you, now my second question:
How do i automatically import all my domains on my directadmin (exim) servers to efa on a separate server?
I understand i need to create some export/import file? or is their already somebody with a script like that?
I think I have an import script, I'll take a look.
zerocool
Post by zerocool »
Did you find the script @shawniverson ?
zerocool
Post by zerocool »
shawniverson wrote: 09 Dec 2020 20:05 I think I have an import script, I'll take a look.
did you have found the script?
These scripts are old and would need tweaked for eFa 4 but are a good start:
https://github.com/E-F-A/v3/tree/master/tools
