After succeffully installed Efa4, i can't continue initial install.
This error pops up:
[eFa] - Configure timezone
[eFa] - Configuring razor
nextserver: Bootstrap discovery failed. Giving up.
chmod: impossible d'accéder à '/var/spool/postfix/.razor/identity-*': No such file or directory
Re: [eFa] - Error initializing system!
Are you able to resolve using DNS?
dig discovery.razor.cloudmark.comRe: [eFa] - Error initializing system!
I checked and The server is resolving the domain name:
;; ANSWER SECTION:
discovery.razor.cloudmark.com. 74 IN A 208.83.137.117
discovery.razor.cloudmark.com. 74 IN A 208.83.137.118
discovery.razor.cloudmark.com. 74 IN A 208.83.139.205
;; ANSWER SECTION:
Do you have anything between you and this domain that is restricting access (such as limited firewall ports?)
