Hi there,
I have an issue and I don't know what happening in last 2 days...
I setup an SMTP scanning in a Xerox WC7225 about 1 year.
Everything works fine, but about 2 days ago the to field was ?modified? EFA.
Here is an example mail:
Message Headers: Received: from xeroxwc.bluefield.local (business-89-135-xxx-xxx.business.broadband.hu [89.135.xxx.xxx])
by mailfilter2.xxx.hu (MailScanner Milter) with SMTP id 4CRxKB6MGBzMl8r
for <6264616e69406264616e692e6875>; Thu, 5 Nov 2020 22:21:19 +0100 (CET)
DMARC-Filter: OpenDMARC Filter v1.3.2 mailfilter2.xxx.hu 4CRxKB6MGBzMl8r
Authentication-Results: mailfilter2.xxx.hu; dmarc=fail (p=none dis=none) header.from=xxx.eu
Authentication-Results: mailfilter2.xxx.hu; spf=fail smtp.mailfrom=scan@xxx.eu
DKIM-Filter: OpenDKIM Filter v2.11.0 mailfilter2.xxx.hu 4CRxKB6MGBzMl8r
MIME-Version: 1.0
Date: Thu, 05 Nov 2020 22:19:32 +0100
To: bdani@xxx.hu
Cc:
Reply-To: scan@xxx.eu
X-Mailer: Xerox Mailer /4.03
Subject: Test E-mail
Message-ID: <jmKXtmZHndqRV1cFmtZfP5nys.1604611171.16@xeroxwc.bluefield.local>
x-xerox-mail-id: jmKXtmZHndqRV1cFmtZfP5nys
Where comes 6264616e69406264616e692e6875?
I did not modify anything in EFA the last weeks...
Regard
bdani
Content-Type: multipart/mixed; boundary="Xerox3813603571Xerox3813603572"
scan@xxx.eu [Add to Whitelist | Add to Blacklist]
To: 6264616e69406264616e692e6875
Xerox scanner To field change?
Re: Xerox scanner To field change?
What version of eFa are you running?
It's Efa 4.0.3.
I try to downgrade MailScanner, but same issue
UPDATE:
downgrade + reboot my helpd!
Regards
bdani
UPDATE:
Regards
bdani
