sa-update fails
lukekenny
sa-update fails
Post by lukekenny » 07 Aug 2020 02:47
Running efa 4.0.2 with openDKIM and openDMARC installed and seemingly working.
I wanted to add some spamassassin rules for applying DMARC policy.
I created /etc/mail/spamassassin/opendmarc.cf:
header DMARC_PASS Authentication-Results =~ /remote.goldnugget.com.au; dmarc=pass /
describe DMARC_PASS DMARC validation seems valid
tflags DMARC_PASS nice
score DMARC_PASS -0.1
header DMARC_NONE Authentication-Results =~ /remote.goldnugget.com.au; dmarc=none /
describe DMARC_NONE DMARC validation none
score DMARC_NONE 0.0
header __DMARC_FAIL Authentication-Results =~ /remote.goldnugget.com.au; dmarc=fail /
meta DMARC_FAIL __DMARC_FAIL && !__DOS_HAS_LIST_ID && !__DOS_HAS_MAILING_LIST
describe DMARC_FAIL DMARC validation failed
score DMARC_FAIL 3.0
I then ran sa-update - seemed OK
Then sa-compile - and got the following error:
/usr/bin/perl Makefile.PL PREFIX=/tmp/.spamassassin154812VAFmTtmp/ignored INSTALLSITEARCH=/var/lib/spamassassin/compiled/5.016/3.004004
Only one of PREFIX or INSTALL_BASE can be given. Not both.
command failed: exit 25
I checked spamassassin with systemctl, it wasn't running, so I started it. It started OK.
How can I resolve this issue?
Re: sa-update fails
Post by shawniverson » 07 Aug 2020 09:30
Try again today, might be a bug in the previous day's SA update
lukekenny
Re: sa-update fails
Post by lukekenny » 07 Aug 2020 11:34
I will try again tomorrow. Just tried now and still no luck...
Here is the full output of the two commands.... do you notice anything odd (other than the error)?
[root@scanner spamassassin]# sa-update
[root@scanner spamassassin]# sa-compile
Aug 7 21:32:29.897 [32394] info: generic: base extraction starting. this can take a while...
Aug 7 21:32:29.897 [32394] info: generic: extracting from rules of type body_0
100% [=======================================================================================================================] 8080.50 rules/sec 00m00s DONE
100% [=======================================================================================================================] 2038.87 bases/sec 00m01s DONE
Aug 7 21:32:31.216 [32394] info: body_0: 1185 base strings extracted in 2 seconds
cd /tmp/.spamassassin32394pkEox3tmp
reading bases_body_0.in
cd Mail-SpamAssassin-CompiledRegexps-body_0
re2c -i -b -o scanner1.c scanner1.re
re2c -i -b -o scanner2.c scanner2.re
re2c -i -b -o scanner3.c scanner3.re
re2c -i -b -o scanner4.c scanner4.re
re2c -i -b -o scanner5.c scanner5.re
re2c -i -b -o scanner6.c scanner6.re
/usr/bin/perl Makefile.PL PREFIX=/tmp/.spamassassin32394pkEox3tmp/ignored INSTALLSITEARCH=/var/lib/spamassassin/compiled/5.016/3.004004
Re: sa-update fails
Post by pdwalker » 24 Aug 2020 11:18
any resolution to your problem?
lukekenny
Re: sa-update fails
Post by lukekenny » 01 Sep 2020 05:28
No, unfortunately I haven't been able to resolve this at all. Still getting the same error running sa-compile.
Re: sa-update fails
Post by henk » 01 Sep 2020 06:36
blaise
Re: sa-update fails
Post by blaise » 03 Sep 2020 11:35
henk wrote:
01 Sep 2020 06:36
Take a look at this: http://mail-archives.apache.org/mod_mbo ... .gov.uk%3E
Sorry, I can't see any answers to the following question in the thread. Is the problem solved already?
Re: sa-update fails
Post by pdwalker » 21 Sep 2020 09:22
blaise wrote:
03 Sep 2020 11:35
henk wrote:
01 Sep 2020 06:36
From the thread post, at the top.
I've seen this, caused by a CPAN install which leaves stuff like this in .bashrc:
export PERL_LOCAL_LIB_ROOT="$PERL_LOCAL_LIB_ROOT:/root/perl5";
export PERL_MB_OPT="--install_base /root/perl5"; export PERL_MM_OPT="INSTALL_BASE=/root/perl5";
export PERL5LIB="/root/perl5/lib/perl5:$PERL5LIB";
export PATH="/root/perl5/bin:$PATH";
Workaround:
PERL_MM_OPT='' sa-compile
Cheers,
Phil
is PERL_MB_OPT defined in your environment anywhere?
lukekenny
Re: sa-update fails
Post by lukekenny » 13 Oct 2021 14:45
Workaround:
Hi Phil, seems to have taken me a while to loop back around to look at this issue again, but I tried your workaround and it seems to have worked!
PERL_MB_OPT was defined as the last line in .bashrc
PERL_MM_OPT="INSTALL_BASE=/root/perl5"; export PERL_MM_OPT;
I executed:
export PERL_MM_OPT=" sa-compile"
sa-compile
and it seems to have worked! Thanks!
