SA Learn error
- activateit
SA Learn error
Choosing "Spam+Report" for a email produces this error on my system.
SpamAssassin: Oct 16 10:36:59.001 [13613] warn: reporter: razor2 report failed: No such file or directory report requires authentication at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/Razor2.pm line 176. at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/Razor2.pm line 329., 1 message(s) examined.
Is it a major issue, and is there a fix?
Thanks,
Stephen
Thanks,
Stephen
- activateit
Re: SA Learn error
I ran the commands as listed on the website as both root and the user setup in initial efa4 install.
razor-client
razor-admin -create
razor-admin -register
The commands said they were successful, but I'm still getting the error from the first post.
razor-client
razor-admin -create
Re: SA Learn error
I also have the same issue on a clean install. Where does it expect to find the identity files?
I tried registering with su to postfix that I believe razor runs under but that does not help either
Re: SA Learn error
Same here
Learn as + report = SpamAssassin: Dec 12 16:33:43.449 [155034] warn: reporter: razor2 report failed: No such file or directory report requires authentication at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/Razor2.pm line 176. at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/Razor2.pm line 329., 1 message(s) examined.
Re: SA Learn error
Same issue here. Running those commands did not fix it.
I'm running EFA 4.0.1 with a configuration that was migrated from 3.x using the Wiki article.
Re: SA Learn error
I think this needs to be done under the postfix user.
Try this...
Try this...
sudo mkdir /var/spool/postfix/.razor
sudo ln -s /var/spool/postfix/.razor /var/www/.razor
sudo su postfix -s /bin/bash -c 'razor-admin -create'
sudo su postfix -s /bin/bash -c 'razor-admin -register'
sudo chown -R postfix:mtagroup /var/spool/postfix/.razor
sudo chmod ug+rwx /var/spool/postfix/.razor
sudo chmod ug+s /var/spool/postfix/.razor
Re: SA Learn error
Reproduced issue even after resetting razor. Working on this...
https://github.com/E-F-A/v4/issues/168
Re: SA Learn error
yeah, it is harmless, and I am working on fixing it.
Re: SA Learn error
Did some tests on the razor report. I did manage to get rid of the warning in the Gui.
I did not re-register razor. First I would like to understand why the homedir in mailscanner.cf is ignored..
To register razor, that would be like this below.
razor-admin -create -home=/var/spool/postfix/.razor
Steps followed.
1. /var/spool/postfix/.razor/razor-agent.conf
added razorhome
# see razor-agent.conf(5) man page
razorhome = /var/spool/postfix/.razor
debuglevel = 0
identity = identity
ignorelist = 0
2 /etc/MailScanner/spamassassin.conf
Added
Run test1
[root@eFa]# su -c "/bin/cat /usr/share/doc/spamassassin-3.4.4.rc1/sample-spam.txt | razor-report -d --verbose" -s /bin/bash postfix
Razor-Log: read_file: 16 items read from /var/spool/postfix/.razor/razor-agent.conf
Jan 27 15:18:41.863504 report[8267]: [ 2] [bootup] Logging initiated LogDebugLevel=9 to stdout
Jan 27 15:18:41.864326 report[8267]: [ 5] computed razorhome=/var/spool/postfix/.razor, conf=/var/spool/postfix/.razor/razor-agent.conf, ident=/var/spool/postfix/.razor/identity-Henk
Jan 27 15:18:41.864422 report[8267]: [ 2] Razor-Agents v2.84 starting razor-report -d --verbose -home=/var/spool/postfix/.razor
Jan 27 15:18:41.864677 report[8267]: [ 5] read_file: 2 items read from /var/spool/postfix/.razor/identity-Henk
Jan 27 15:18:41.865539 report[8267]: [ 8] razor-report finished successfully.
test2
[root@eFa]# spamassassin -t -D razor2 < /usr/share/doc/spamassassin-3.4.4.rc1/sample-spam.txt
Jan 27 15:21:16.608 [8442] dbg: razor2: razor2 is available, version 2.84
Razor-Log: Found razorhome: /var/spool/postfix/.razor
Jan 27 15:21:19.495226 check[8442]: [ 2] [bootup] Logging initiated LogDebugLevel=9 to stdout
Jan 27 15:21:19.495495 check[8442]: [ 5] computed razorhome=/var/spool/postfix/.razor, conf=/var/spool/postfix/.razor/razor-agent.conf, ident=/var/spool/postfix/.razor/identity-Henk
Jan 27 15:21:19.495654 check[8442]: [ 8] Client supported_engines: 4
Final
Now test Gui
Spam+ Report, should be fine now
Steps followed.
added razorhome
debuglevel = 0
identity = identity
ignorelist = 0
Added
ifplugin Mail::SpamAssassin::Plugin::Razor2
razor_config /var/spool/postfix/.razor/razor-agent.conf
#razorhome = /var/spool/postfix/.razor
endif[root@eFa]# su -c "/bin/cat /usr/share/doc/spamassassin-3.4.4.rc1/sample-spam.txt | razor-report -d --verbose" -s /bin/bash postfix
test2
Final
Now test Gui
Re: SA Learn error
Official fix is here. It is currently in the testing repo.
https://github.com/E-F-A/v4/commit/0f84 ... 7953089b27
Re: SA Learn error
SpamAssassin: Feb 26 11:42:46.144 [102249] warn: reporter: razor2 report failed: No such file or directory report requires authentication at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/Razor2.pm line 176. at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/Razor2.pm line 329., 1 message(s) examined.
any ideas here?
newest version of efa
MailWatch for MailScanner v1.2.15 running on eFa-4.0.2 - © 2006-2020
any ideas here?
Re: SA Learn error
I did upgrade and it still works fine with me. I did run the tests mentioned in my previous posts + modifications, and everything is still ok
test 2
Add razor home to
Now run without home
Works fine
I'll install a new efa4 tomorrow, and will report back
sudo su -l postfix -s /bin/cat /usr/share/doc/spamassassin-3.4.4.rc1/sample-spam.txt | razor-report -d --verbose -home=/var/spool/postfix/.razorCode: Select all
spamassassin -t -D razor2 < /usr/share/doc/spamassassin-3.4.4.rc1/sample-spam.txtAdd razor home to
/root/.razor/razor-agent.confCode: Select all
# Razor2 config file
# Autogenerated by Razor-Agents v2.84
# Fri Nov 15 20:52:34 2019
# Created with all default values
su -c "/bin/cat /usr/share/doc/spamassassin-3.4.4.rc1/sample-spam.txt | razor-report -d --verbose" -s /bin/bash postfixI'll install a new efa4 tomorrow, and will report back
Re: SA Learn error
Did install a new efa4 yesterday,kickstart on Centos minimal, and all razor issues are gone. (no manual modifications needed)
Re: SA Learn error
Still getting the error in the GUI on an upgraded 4.0.2 install
Do I need to do Henk's modifications manually? And if so, which one(s)? Only razor-agent.conf or also spamassassin.conf?
Re: SA Learn error
This may be related to a missing spamassassin symlink. I'm pushing out the symlink in a minor update starting tonight. If you want to fix it faster, just run this.
sudo ln -s /etc/mailscanner/spamassassin.conf /etc/mail/spamassassin/mailscanner.cf
Re: SA Learn error
I am seeing this error in a recent, 20 day old fresh install of 4.0.2, in the GUI:
Should the configuration changes mentioned above need to be made on a fresh install for reporting to work?
Have checked the soft link, which was already there, Razor appears to be registered and the test commands mentioned above seem to give positive results, no errors etc.SpamAssassin: Jun 30 01:35:56.023 [9217] warn: reporter: razor2 report failed: No such file or directory report requires authentication at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/Razor2.pm line 176. at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/Razor2.pm line 329., 1 message(s) examined.
Re: SA Learn error
Yup, same here. Hopefully the colleague that has faithfully been monitoring incoming mail for the last 10 days and flagging and reporting spam hasn't been wasting his time entirely.lukekenny wrote: 29 Jun 2020 15:43 I am seeing this error in a recent, 20 day old fresh install of 4.0.2, in the GUI:
Re: SA Learn error
I applied the changes mentioned in Henk's first post above, and all seems well. There's no error in the GUI any more.
Is there a way to determine if Razor is working, such as a command that will tell me which emails I've submitted?
Re: SA Learn error
I still have this problem, while my EFA version is upgraded: "MailWatch for MailScanner v1.2.15 running on eFa-4.0.3 - © 2006-2020."
How can I remove this error? I tried Henk's steps, but it did not work.
Re: SA Learn error
Please check again if you did all the changesI tried Henk's steps, but it did not work.
can you show the output of the commands mentioned?
Re: SA Learn error
I had the same issue. I've fixed it with the following steps:
1. Into the file /var/spool/postfix/.razor/razor-agent.conf add the line
2. Into the file /etc/MailScanner/spamassassin.conf add the following section
And restart spamassassin service
3. Run the command:
4. If /var/spool/postfix/.razor/razor-agent.log doesn't exist yet, create empty file
5. Change permissions
Now it should work.
razorhome = /var/spool/postfix/.razorCode: Select all
endifCode: Select all
systemctl restart spamassassinCode: Select all
su -c "/bin/cat /usr/share/doc/spamassassin/sample-spam.txt | razor-report -d --verbose" -s /bin/bash postfixCode: Select all
touch /var/spool/postfix/.razor/razor-agent.logCode: Select all
chmod 640 /var/spool/postfix/.razor/{identity-*,razor-agent.conf}
chmod 664 /var/spool/postfix/.razor/razor-agent.log
chmod 644 /var/spool/postfix/.razor/server*
Re: SA Learn error
This is still happening? I'll take another look.
