I have an error with DCC servers not answering.
I have installed eFa 4.0.2 on a fresh centOS 7 with 4 GB RAM.
Using the command "cdcc info" i get the following:
# 02/17/20 11:42:08 CET /var/dcc/map
# Re-resolve names after 12:46:21
# 12 total, 0 working servers
# continue not asking DCC server 32 seconds after 1 failures
IPv6 on version=3
@,- RTT-1000 ms 32768
# 127.0.0.1,-
# not answering
dcc.nova53.net,- RTT+0 ms anon
# 173.71.176.215,-
# not answering
dcc1.dcc-servers.net,- RTT+0 ms anon
# 74.92.232.243,-
# not answering
# 137.208.8.63,-
# not answering
dcc2.dcc-servers.net,- RTT+0 ms anon
# 192.84.137.21,-
# not answering
# 195.20.8.232,-
# not answering
dcc3.dcc-servers.net,- RTT+0 ms anon
# 209.169.14.27,-
# not answering
# 212.223.102.90,-
# not answering
dcc4.dcc-servers.net,- RTT+0 ms anon
# 69.171.29.33,-
# not answering
# 192.135.10.194,-
# not answering
dcc5.dcc-servers.net,- RTT+0 ms anon
# *136.199.199.160,-
# not answering
# 157.131.0.46,-
# not answering
# 02/17/20 11:42:08 CET greylist /var/dcc/map
# Re-resolve names after 13:42:08
# 1 total, 0 working servers
# continue not asking greylist server 32 seconds after 1 failures
@,- Greylist 32768
# *127.0.0.1,6276
# not answering
Feb 17 11:48:21 cas1 MailScanner[31902]: MailWatch: Starting up MailWatch SQL Blacklist
Feb 17 11:48:21 cas1 MailScanner[31902]: MailWatch: Read 0 blacklist entries
Feb 17 11:48:21 cas1 MailScanner[31902]: Config: calling custom init function MailWatchLogging
Feb 17 11:48:21 cas1 MailScanner[31902]: MailWatch: Started MailWatch SQL Logging child
Feb 17 11:48:21 cas1 MailScanner[31902]: Config: calling custom init function SQLWhitelist
Feb 17 11:48:21 cas1 MailScanner[31902]: MailWatch: Starting up MailWatch SQL Whitelist
Feb 17 11:48:21 cas1 MailScanner[31902]: MailWatch: Read 2 whitelist entries
Feb 17 11:48:21 cas1 MailScanner[31902]: Using SpamAssassin results cache
Feb 17 11:48:21 cas1 MailScanner[31902]: Connected to SpamAssassin cache database
Feb 17 11:48:21 cas1 MailScanner[31902]: Enabling SpamAssassin auto-whitelist functionality...
Feb 17 11:48:22 cas1 dccifd[2556]: no working DCC servers @ dcc.nova53.net dcc1.dcc-servers.net ... at 127.0.0.1 173.71.176.215 173.71.176.215 ...
Feb 17 11:48:22 cas1 dccifd[2556]: continue not asking DCC 32 seconds after 1 failures
Feb 17 11:48:26 cas1 MailScanner[31910]: MailScanner Email Processor version 5.2.2 starting...
Feb 17 11:48:26 cas1 MailScanner[31910]: Reading configuration file /etc/MailScanner/MailScanner.conf
Feb 17 11:48:26 cas1 MailScanner[31910]: Reading configuration file /etc/MailScanner/conf.d/README
Feb 17 11:48:26 cas1 MailScanner[31910]: Read 868 hostnames from the phishing whitelist
Feb 17 11:48:26 cas1 MailScanner[31910]: Read 5807 hostnames from the phishing blacklists
Feb 17 11:48:26 cas1 MailScanner[31910]: Config: calling custom init function SQLBlacklist
Feb 17 11:48:26 cas1 MailScanner[31910]: MailWatch: Starting up MailWatch SQL Blacklist
Feb 17 11:48:26 cas1 MailScanner[31910]: MailWatch: Read 0 blacklist entries
Feb 17 11:48:26 cas1 MailScanner[31910]: Config: calling custom init function MailWatchLogging
Feb 17 11:48:26 cas1 MailScanner[31910]: MailWatch: Started MailWatch SQL Logging child
Feb 17 11:48:26 cas1 MailScanner[31910]: Config: calling custom init function SQLWhitelist
Feb 17 11:48:26 cas1 MailScanner[31910]: MailWatch: Starting up MailWatch SQL Whitelist
Feb 17 11:48:26 cas1 MailScanner[31910]: MailWatch: Read 2 whitelist entries
Feb 17 11:48:26 cas1 MailScanner[31910]: Using SpamAssassin results cache
Feb 17 11:48:26 cas1 MailScanner[31910]: Connected to SpamAssassin cache database
Feb 17 11:48:26 cas1 MailScanner[31910]: Enabling SpamAssassin auto-whitelist functionality...
Feb 17 11:48:27 cas1 dccifd[2556]: continue not asking DCC 27 seconds after 1 failures
Does anyone have a solution with this problem?
Thanks in advance!
