Blacklist TLD
fauxfrogbelly
Blacklist TLD
I've been attempting to blacklist the .icu TLD, but I've been fairly unsuccessful.
When creating a blacklist entry, I've used .icu as the from entry, and either default or one of my recipient domains (e.g., example.com) as the to entry. In either case, low-scored spam from .icu sails on through. I could lower my spam score again, but I'm trying to avoid catching too much ham. I've also seen a forum posting on how to block/drop .icu mail, but I'd like to record all incoming spam just in case there's eventually a legitimate piece of mail from that TLD.
Am I setting up the blacklist wrong? Any thoughts?
Re: Blacklist TLD
Hello all,
Trying to do the same, so far unsuccessfull.
Any thoughts anyone ??
Regards.
JG
Regards.
JG
Re: Blacklist TLD
When I added a TLD I did not put a "." in front of it. example: I whitelist .gov so i added "gov" to whitelist. eFa 4.0
Citabria79
Re: Blacklist TLD
I just added a few domains and extensions to the blacklist using the web interface. This icu TLD I added as icu, without start or dot. It appears in the list on the page as icu default, but incoming icu messages are not marked as blacklisted (supposed to be a black line?). I restarted MailScanner, same result.
When does this blacklist gets in effect?
Citabria79
Re: Blacklist TLD
I actually do see mails getting through that are on the blacklist in the webconsole. How do they get in effect? I added icu without dot, like this:
https://localhost/mailscanner/lists.php
Blacklist:
icu default Delete
qq.com default Delete
space default Delete
top default Delete
xyz default Delete
Thank you
Blacklist:
icu default Delete
top default Delete
xyz default Delete
Thank you
Re: Blacklist TLD
yes you are correct the blacklist isn't blocking TLD's.
Re: Blacklist TLD
Seems we need to make a feature request for this. Also seems someone already fixed this for themselves, I have not tried this to see if it works so use at your own risk.
https://www.pokorra.de/2019/03/mailwatc ... blacklist/
Re: Blacklist TLD
EDIT: Deleted, though I thought I had a fix but looking further at source it appears TLD's should be supported. So it might jsut be a small syntax issue. I am working on it, doing some tests
Re: Blacklist TLD
I think i figured it out. For some reason mailwatch treats sub-domains (which TLD's fall under) different from normal domain blockingCitabria79 wrote: 05 May 2020 21:38 Hi,
Blacklist:
icu default Delete
top default Delete
xyz default Delete
Thank you
To block a TLD use syntax
*.icuand you have in your blacklist
b.comCode: Select all
*.b.comCode: Select all
*.a.b.comSo needless to say very confusing the way they did it!
Citabria79
Re: Blacklist TLD
Thank you for all your efforts. If I understand it correct I should update my list like this:
*.icu default Delete => will block all TLD mails from *@whatever.icu.
*.qq.com default Delete => will block all mails from domain *@qq.com, but not *@*.qq.com
*.space default Delete => will block all TLD mails from *@whatever.space.
*.top default Delete => will block all TLD mails from *@whatever.top.
*.xyz default Delete => will block all TLD mails from *@whatever.xyz.
Correct?
Correct?
Re: Blacklist TLD
Will delete every email from *@*.qq.com but will allow every email from *@qq.com.*.qq.com
